Author Topic: EEVblog #306 - Jim Williams Pulse Generator  (Read 412609 times)
0 Members and 53 Guests are viewing this topic.
Offline rolfdegen
    • Degenerator Synthesizer/Sampler
Re: EEVblog #306 - Jim Williams Pulse Generator
« Reply #625 on: April 26, 2025, 11:04:34 am »
Next step is an HF case from https://www.meilhaus.de/tbrfh.htm
I want to install the circuit in the HF case. I hope it fits...  :)
« Last Edit: April 26, 2025, 11:10:41 am by rolfdegen »
Electronics developer
Offline rolfdegen
« Reply #626 on: April 27, 2025, 11:51:56 am »
I ordered ten 2n2369 transistors here in Germany. Two transistors didn't work in Avalanche mode. Now I've ordered ten BFR505s from Poland.
Today I'll expand the 2n2369 circuit with a pulse generator based on a small ATtiny404 processor and test it. The rise time of ATtiny404 is 1.5ns at 5 VDD. Better than a 74HC14 with 6ns.
I'm excited...   ::)
ATtiny404 Chip
« Last Edit: April 27, 2025, 01:04:22 pm by rolfdegen »
Offline rolfdegen
« Reply #627 on: April 27, 2025, 02:00:44 pm »
I found a smaller 20MHz ATtiny412 in my chip box. It only has 8 pins but the same electrical properties.
I programmed a pulse frequency of 10 kHz with a pulse width of 45ns on the ATtiny412. Is this OK for driving the 2N2369 avalanche transistor  :-//
My planned circuit..
« Last Edit: April 27, 2025, 02:43:25 pm by rolfdegen »
Offline rolfdegen
« Reply #628 on: April 27, 2025, 06:52:09 pm »
Result on a breadboard. It's not perfect. But is a liitle bit faster...  :-+
The supply voltage for the transistor was +50 volts. The Scope probe was 10x.
I'm going to solder it onto a small circuit board and measure it again.
New Measurement 660ps
Old Measurement 720ps
My breadboard
« Last Edit: April 27, 2025, 07:13:05 pm by rolfdegen »
Offline David Hess
  • DavidH
« Reply #629 on: April 27, 2025, 07:15:21 pm »
Breadboard construction is going to trash the rise time.  This is the type of circuit which should be built over a ground plane.
Offline rolfdegen
« Reply #630 on: April 27, 2025, 07:49:29 pm »
Yes you are right  :) Tomorrow, I'll solder the circuit onto a small circuit board and connect it with a BNC connector. Until then, good night, my friend :)
Offline gf
« Reply #631 on: April 27, 2025, 08:15:51 pm »
I assume that this generator is supposed to generate very narrow impulses? Then the "New Measurement" looks a bit weird. OTOH, the "Old Measurement" actually looks more like it could be the impulse response of the scope's frontend, which is expected to show up on the screen under the assumption that the true stimulus impulse is a very narrow one. The true shape of the stimulus impuse is likely not measurable with this scope anyway.
Risetime is a property of a step response. For an impulse response it is not really meaningful, IMO. You must integrate the impulse response to get the step response, if you want to measure the rise time.
Online tggzzz
« Reply #632 on: April 27, 2025, 08:35:16 pm »
Keep the inductors as small as possible. Rule of thumb is that 1mm is ~1nH, in wires or in components.
If you want to understand and measure a scope's risetime, a step wave is more useful than a badly characterised impulse. You can use a short transmission line to lengthen the impulse so that it can be considered a step.
Offline rolfdegen
« Reply #633 on: April 27, 2025, 08:43:02 pm »
Yes, a breadboard is not particularly suitable for high frequency measurements.  :-BROKE
I will solder it tomorrow on board with SMD components.
« Last Edit: April 27, 2025, 08:44:50 pm by rolfdegen »
Online tggzzz
« Reply #634 on: April 27, 2025, 09:13:12 pm »
Your scope trace appears to show an amplitude of 3.4Vpeak. Is that 10%, 50% or 90% of the peak voltage output by the transistor?
Another approach to the topic is to consider what peak amplitude would be seen on a 100kHz scope or 10GHz scope.
Offline David Hess
  • DavidH
« Reply #635 on: April 27, 2025, 10:12:35 pm »
I would replace C1 with a charge line.  Otherwise with limited bandwidth, the amplitude measurement and rise time are meaningless.
Online tggzzz
« Reply #636 on: April 27, 2025, 10:19:38 pm »
Precisely.
Mentioned earlier, but he didn't pick up the point.
Once the signal has been convolved with the scope's response, the scope's response cannot be determined by deconvolution unless the signal is known.
Offline rolfdegen
« Reply #637 on: April 28, 2025, 02:19:55 pm »
We're getting closer to the matter...
The square-wave generator with the ATtiny barely had any effect. I reused my old circuit (without the square-wave generator) and soldered a 35cm coaxial cable parallel to capacitor C1.
This produced a square-wave pulse. But it's still not optimal :-//
Is there any way to still buy the circuit board? Thanks  ;)
« Last Edit: April 28, 2025, 02:28:11 pm by rolfdegen »
Offline rolfdegen
« Reply #638 on: April 28, 2025, 04:48:40 pm »
Next step a liitle bit better ;)
I have now soldered the coaxial cable to the back parallel to C1.
Offline rolfdegen
« Reply #639 on: April 28, 2025, 04:58:56 pm »
Where can I still buy circuit boards for the Jim Williams Pulse Generator ?
Offline rolfdegen
« Reply #640 on: April 28, 2025, 05:23:04 pm »
I ordered the Fast Edge Pulse Generator 350 Picoseconds Rising Edge from AliExpress for comparison and testing. It costs €40.
I'm curious  :scared:
« Last Edit: April 28, 2025, 05:26:11 pm by rolfdegen »
Offline 6SN7WGTB
« Reply #641 on: April 28, 2025, 07:32:46 pm »
All interesting work, but presumably you’re not expecting to better 700ps or so on this ‘scope?
Offline rolfdegen
« Reply #642 on: April 28, 2025, 07:58:13 pm »
I think so too. According to the formula 0.4/700ps, my MSO5104 (350MHz hack) would have a cutoff frequency of 571MHz. 700ps would be a very good value. I'm curious to see if the Fast Edge Pulse Generator I ordered from AliExpress will produce better results. Unfortunately, my setup isn't optimal.
Offline rolfdegen
« Reply #643 on: April 29, 2025, 06:52:14 pm »
Wow... what a price. I'm not a millionaire  :--
Offline rolfdegen
« Reply #644 on: April 29, 2025, 06:57:08 pm »
« Last Edit: April 29, 2025, 07:04:13 pm by rolfdegen »
Online tggzzz
« Reply #645 on: April 29, 2025, 07:35:07 pm »
Low cost and simple and makes 510ps:-+
Low cost and simple makes ~250ps 2.5V into 50ohms. Need to be very careful with the PCB layout, lead length, and decoupling at those di/dt :)
https://www.eevblog.com/forum/testgear/show-us-your-square-wave/msg1902941/#msg1902941
The following users thanked this post: rolfdegen
Offline tautech
« Reply #646 on: April 29, 2025, 08:54:19 pm »
Uncharacterized, therefore 510ps is a product of the scopes rise time plus the pulser rise time.
I had one drawn up in Altium then twigged I had nothing to test it properly so instead splashed 50 Quid on Leo Bodnar's V1 pulser with a guaranteed RT of 40ps or better.
It arrived with a printed scope screenshot showing a 28ps RT....  :o
Avid Rabid Hobbyist
