Author Topic: EEVblog #751 - How To Debunk A Product (The Batteriser)  (Read 3096607 times)
0 Members and 17 Guests are viewing this topic.
Offline Jay_Diddy_B
Re: EEVblog #751 - How To Debunk A Product (The Batteriser)
« Reply #4600 on: February 27, 2016, 03:05:38 pm »
Hi group,
There is nothing new about the schematic. The application for battery life extension is stated on the LTC3526 datasheet published in 2007.
AAA implementation
I was successful in building a boost converter in the AA form factor. I wanted to see if the AAA form factor was possible.
(The PCB is 10mm diameter (2 Bs' D)
Here is my schematic:
And here is component placement for an AAA size boost converter:
It would be possible to route this arrangement without too much difficulty. I have reduced the size of the input and output capacitor to 0402. Digikey has 0402 4.7uF at 4V  X5R.
I used a 1.6mm x 1.6mm MAPI inductor from Wurth. This inductor has a DCR of 338m Ohms.
It is possible to build this circuit in the required space.
LTspice Model of the AAA solution
I constructed an LTspice model to see what kind of performance can be expected from this implementation.
Modelling Results
It works well enough to fool a VC monkey. The output is limited to 150mA with a 1.2V battery.
At 1.0V input.
Now I could probably squeeze a little more output with a larger inductor, but not much more.
Regards,
Jay_Diddy_B
« Last Edit: February 27, 2016, 03:07:59 pm by Jay_Diddy_B »
Offline Jay_Diddy_B
« Reply #4601 on: February 27, 2016, 03:16:02 pm »
Unless they really have developed a new chip that does something special, this horse is on its knees and ready for a faceplant.
In that case, shouldn't there be a patent request specific to the chip itself?
Chip manufacturers' will typically patent the features of chip that allows it to function in a specific application. They don't typically patent the application. They want to allow people to use the chips in as many applications as possible. They want to prevent other chip manufacturers' offering competing products. An 'Application' patent would be too narrow to be useful.
The application to specific problem is typically patented by the purchaser of the chip.
Regards,
Jay_Diddy_B
Offline Jay_Diddy_B
« Reply #4602 on: February 27, 2016, 03:24:35 pm »
The LTC3400 can be ruled out.
Regards,
Jay_Diddy_B
Jay_Diddy_B, can you do a constant power discharge of a fresh AA cell, plotting the discharge curve?
The Electrician,
What are you hoping to see? My HP load does not offer a constant power discharge mode. It could be done using the HPIB control to modify the current drawn as the voltage drops. I am not sure that it would have high enough resolution. It is a 300W load.
I have a accurate SPICE model of an AA battery that was made from measured data. This could be used to get a really good idea.
Have a look at this thread:
https://www.eevblog.com/forum/projects/modeling-an-alkaline-battery-in-ltspice/
in reply #4 I model a constant power discharge.
Regards,
Jay_Diddy_B
Offline Jay_Diddy_B
« Reply #4603 on: February 27, 2016, 03:31:16 pm »
I think I have earned a shot of 'Jolly Woker - Red Labia #1'. I have a copy of copy.. :-DD
Jay_Diddy_B
Offline Jay_Diddy_B
« Reply #4604 on: February 27, 2016, 03:44:26 pm »
Meanwhile on the Batteriser Facebook page we have:
Lakshimi Narasimhan is listed as a campaigner on IGG.
https://www.indiegogo.com/individuals/11057878
Jay_Diddy_B
Offline g.lewarne
« Reply #4605 on: February 27, 2016, 04:00:30 pm »
but again, its vague meaningless non-info
"shipping dates are coming soon!" could mean than in a month they will tell you they are going to ship in October.....
Offline WN1X
« Reply #4606 on: February 27, 2016, 04:03:23 pm »
I sure wish they would hurry up and ship the damn things. I am almost out of pop corn  :popcorn:
- Jim
Offline The Electrician
« Reply #4607 on: February 27, 2016, 04:08:45 pm »
The Electrician,
Regards,
Jay_Diddy_B
I was hoping to see exactly what your reply #4 shows in that other thread.  With a constant power load and high efficiency in the converter, the battery current rises rapidly as the battery life ends and there is no warning that the battery output is about to very rapidly collapse.  i gather that the Batteriser does allow the output voltage to drop a little as the battery is exhausted, but I don't think it is what typical devices will be expecting, and therefore their low battery indicator won't give a proper indication.
If the Batteriser people will have to come up with a new name, how about "Suck-it-dry"?
« Last Edit: February 27, 2016, 04:14:00 pm by The Electrician »
Offline PA0PBZ
« Reply #4608 on: February 27, 2016, 04:13:25 pm »
www.baterriser.com ?
Offline jippie
« Reply #4609 on: February 27, 2016, 04:28:30 pm »
<SNIP>
Jay_Diddy_B
Similar message on Twitter, but the communications department logged on with the right username.
Or maybe the guy on facebook is just enthusiastic and copied the message from Twitter.
« Last Edit: February 27, 2016, 04:56:59 pm by jippie »
Offline PA0PBZ
« Reply #4610 on: February 27, 2016, 04:36:17 pm »
But still the wrong url.
Offline jippie
« Reply #4611 on: February 27, 2016, 04:40:23 pm »
I mentioned it before: I just don't get it that news related to the campaign appears on secondary channels first.
Offline Nerull
« Reply #4612 on: February 27, 2016, 05:26:18 pm »
Batt=risfr? Baterriser?
"Your honor, we can't violate energizers trademark because we have no idea what our product is called."
I wonder if they're desperately trying to rebrand but no one is on the same page as to the new name.
« Last Edit: February 27, 2016, 05:27:55 pm by Nerull »
Offline rrinker
« Reply #4613 on: February 27, 2016, 06:58:37 pm »
 Yes, that 9V design is just fail button worthy. The ONE place I actually could use a boost converter like that, it would never fit. The throttle unit for my model railroad DCC system was unfortunately designed to use a 9V battery AND it's very voltage sensitive. It doesn't actually draw a lot of power, but when the voltage falls to about 8.4V it gets flakey - which almost totally rules out using standard '9V' rechargeables. I would ne nice if they redesigned the thing to use a low voltage micro so it could run off a pair of AA batteries. There IS room inside if I build a small converter though....
 And of course the obvious DANGEROUS fail was already pointed out, when people whack them into smoke alarms and it defeats the low battery warning.
 Probably these latest notices are because they said March, and it's almost March now, thus "coming soon!" SO, what will be the next excuse? There needs to be a reworked Magic 8 Ball with potential Batteriser excuses on the faces so we can randomly generate one. Anything going on in China after the end of the New year celebration? More landslides? Will this be the time they trot out the "persecuted by Big Battery" excuse? Stay tuned for the next episode of "As the Battery Discharges"
Offline Jay_Diddy_B
« Reply #4614 on: February 28, 2016, 02:39:32 am »
Is just me or has this message on the Batteriser Facebook gone already?
If has gone, it would seem that Dr. Bob does not want any mention of a ship date.
Regards,
Jay_Diddy_B
Offline ChunkyPastaSauce
« Reply #4615 on: February 28, 2016, 04:07:12 am »
Well they are promising to ship in 30 days batteriser.com for people ordering today
« Last Edit: February 28, 2016, 04:09:01 am by ChunkyPastaSauce »
Offline ez24
  • L.D.A.
« Reply #4616 on: February 28, 2016, 05:33:05 am »
Now we will see how many days "30 days" are, like 800 %
We should take bets.
Offline jippie
« Reply #4617 on: February 28, 2016, 07:35:40 am »
<SNIP>
Batteriser's Twitter entry is gonski too. Luckily we still have the pictures.
Offline EEVblogTopic starter
« Reply #4618 on: February 28, 2016, 08:45:16 am »
Can't even get their own URL right  :palm:
Domain not even registered.
Online Fungus
« Reply #4619 on: February 28, 2016, 09:47:42 am »
Somebody register it, quick! We can can put our own message board up there.
Offline timb
    • timb.us
« Reply #4620 on: February 28, 2016, 02:50:17 pm »
Done. (Seriously. I've got it for a year. One advantage of having a well funded account with eNom, from my days in the hosting business.)
Should I redirect it to Goatse, 2G1C or Lemon Party? Decisions, decisions...
Oh! Maybe I could photoshop Energizer batteries shooting out of the Goatse man's gaping chasm!
Offline Kean
    • Kean Electronics
« Reply #4621 on: February 28, 2016, 03:01:29 pm »
While tempting, those are all a bit childish.
Seems like the best thing to do is redirect it to EEVblog 751 on YT, or alternatively to this forum.
Offline jancumps
  • New Low
« Reply #4622 on: February 28, 2016, 03:22:29 pm »
Should we go back to electronics and stop these games? It makes the blog look like trollcentral.
Offline meeder
« Reply #4623 on: February 28, 2016, 03:54:39 pm »
Linking to the debunking video is the best option.
Offline Brumby
« Reply #4624 on: February 29, 2016, 12:22:56 am »
An understandable sentiment, but we - and the rest of the world - are STILL WAITING for the electronics to make it's debut!
So what do we do while we wait ... ignore the matter???
I'm sure Bob would like us all to let it fade into a foggy memory.
« Last Edit: February 29, 2016, 12:24:30 am by Brumby »
