http://uk.farnell.com/pro-signal/psg01319/plug-xlr-free-black-5pole/dp/1280935XLR plugs 5 pole 15 for £5
http://uk.farnell.com/lem/htfs-800-p/current-transducer/dp/9135758Very handly AC/DC current transducer with onboard signal conditioning £5 each
http://uk.farnell.com/multicomp/spc15386/plug-d-high-density-pcb-78way/dp/156424478 way pcb mount high density D-type plug 10 for £5
http://uk.farnell.com/fct-a-molex-company/f25s1g1/d-sub-receptacle-db-25way/dp/243330325 way pcb mount D-type socket 10 for £5
http://uk.farnell.com/te-connectivity-amp/1658621-1/connector-receptacle-idc-2-54mm/dp/109849810 way IDC socket 50 for £5
http://uk.farnell.com/harwin/d01-9973242/socket-sil-32way-pc-board/dp/1023035SIL 32 way turned pin socket 20 for £5
http://uk.farnell.com/vishay-sfernice/eco78csa502w6817/potentiometer-5k/dp/1213262High quality rotational transducer 1 for £5
http://uk.farnell.com/fischer-elektronik/akk-127/heat-sink-to-3-14-c-w/dp/4621360TO3 heatsinks 10 for £5
http://uk.farnell.com/te-connectivity-amp/0-0881545-2/jumper-with-handle-2-54mm-2way/dp/4218176Those handy little 0.1" jumpers (with handle) bag of 1000 for £10
02 June additionshttp://uk.farnell.com/bulgin/mpi002-28-gn/switch-spst-0-05a-24vdc-green/dp/3248902Vandal resistant 1P66 illuminated push buttons 2 for £5
http://uk.farnell.com/multicomp/6601-84-pps-f6/socket-ic-plcc-tube-15-84way/dp/110386384 way PLCC sockets 16 for £5
25 July additionshttp://uk.farnell.com/vishay/mal209525152e3/cap-alu-elec-1500uf-350v-snap/dp/2342167Vishay 1500uF 350V capacitors 2 for £5
15 August additionshttp://uk.farnell.com/radiall/r317580000/rf-coaxial-shv-straight-jack-50ohm/dp/4196491RADIALL SHV Coax bulkhead jacks 50R, 10 for £5
http://uk.farnell.com/thermodisc/g4a01072c/fuse-thermal-72-c-10a-250vac/dp/476560Microtemp thermal fuse 72 degrees C, 100 for £5
http://uk.farnell.com/multicomp/mcos38008/switch-3a-250vac-spdt-blade/dp/1606956Cute little Emergency Stop buttons, 5 for £5
http://uk.farnell.com/omron-electronic-components/d3v-16-3c6/microswitch-spst-no-16a-pin/dp/2068257Omron microswitches 50 for £5
http://uk.farnell.com/saia-burgess/f5t8/microswitch-plunger/dp/1162613Very cute little microswitches, 20 for £5
http://uk.farnell.com/harting/09-18-564-7914/header-straight-s-latch-64way/dp/110676764 way PCB mount header 25 for £5
http://uk.farnell.com/neutrik/nke6s-10/cable-ethercon-cat6-10m/dp/1390161Neutrik 10m ethernet cables £5 each (only 3)
http://www.farnell.com/datasheets/390294.pdfRF Solutions Shadow Tracker GPS stalker thing £20 each (only 2)
http://uk.farnell.com/mentor/1322-1640/748-3mm-blue-hi-brightness-leds/dp/1773120M-Tube 750mm blue LED lighting strip 2 for £5 (only 7)
http://uk.farnell.com/multicomp/440005p/battery-connector-pp3-type-1-150mm/dp/11831239V battery clips pack of 10, 10 packs (100 clips) for £2.50
http://uk.farnell.com/nmb-technologies/3110kl-05w-b50-p00/fan-80mm-24vdc/dp/1012773Fan 24V 80mmx25mm, 3 for £5
16 August additionshttp://uk.farnell.com/tenma/72-10177/oscilloscope-pc-4-ch-60mhz-afg/dp/2146567Tenma 72-10177 60MHz 0.2GS/s 4 channel PC based oscilloscope / AWG 16 Mpts, demo stock £150 (1 only)
It's a rebadged Hantek DSO3064A 4in1 Oscilloscope Arbitrary Waveform Generator
http://uk.farnell.com/tenma/72-1016/multimeter-digital-bench-5999/dp/1196432?ost=1196432Tenma 72-1016 bench meter with USB and RS232, boxed as new with leads, demo stock, £50 (1 only)
Lots of most of these items available.
I'll keep adding to this list as and when I can be arsedShipping at cost, the more you buy in one go the better it is for everybody involved.
No VAT to be added to any of these prices, I'll sort all that out in my own way!
