Author Topic: WTB: 40-50mw IR laser diodes  (Read 2917 times)
Offline SL4PTopic starter
  • There's more value if you figure it out yourself!
« on: May 02, 2015, 09:10:52 am »
Looking for a quality source (qty: 10) laser diodes
40-50mw output
Wavelength in 810-850nm range...  Infra-Red
Any suggestions at a reasonable price?
Don't ask a question if you aren't willing to listen to the answer.
Online Psi
Re: WTB: 40-50mw IR laser diodes
« Reply #1 on: May 02, 2015, 11:01:35 am »
For quality try  https://www.thorlabs.com
For price try http://www.aliexpress.com
For both try asking someone on the forum http://photonlexicon.com/forums/index.php  (someone there will likely have some good quality 2ndhand diodes they could send you)
There are people on that forum who know more about lasers than industry as a whole.
« Last Edit: May 02, 2015, 11:04:07 am by Psi »
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #2 on: May 02, 2015, 11:08:40 am »
http://www.roithner-laser.com/
If you can use 808nm, these are very common as pump diodes for DPSS lasers
Day Job: Mostly LEDs
« Reply #3 on: May 02, 2015, 11:22:39 am »
Ahh - ok
Thanks for both ideas.  808nm will be fine.
Offline mswhin63
« Reply #4 on: May 03, 2015, 02:25:58 am »
40-50mw output
Your in Australia, good luck importing them. I am also an amateur astronomer and many of the people on forum in Australia find it hard to import, even when they are allowed to import them. The maximum I am allowed to import is 5mW. Mine are green, Red is useless in my application.
Unless you have a licence you run the risk of importing what is considered a weapon in Australia. At best you will lose it at worst not sure if a fine at the most or depending on the power a conviction.
« Reply #5 on: May 03, 2015, 02:31:37 am »
The last time I looked, the 5mw law was applicable to handheld laser pointers.
I've been repairing / making safe (!) various technology lasers for people (stage, medical etc) and have had zero problems when importing 0-800mw visible parts...
No Laser 'pointers' though.
Interested to learn of any variations.
« Last Edit: May 03, 2015, 09:09:34 am by SL4P »
« Reply #6 on: May 03, 2015, 09:08:10 am »
Most laser regs only apply to complete products - there shouldn't be issues with components, but your avarage customs person is probably not going to know the difference.
Probably wise to ask the seller not to use the word "laser" on customs forms.
Offline kakureru
« Reply #7 on: May 03, 2015, 06:56:01 pm »
call them 'LEDs'   ;)
