Replace 3 AAA batteries in a flashlight - simple task? Nope.
The original AAA batteries were from China, named "Malt Max". Malt Max? Ummm, whatever ...
sounds like some sort of Quick Stop branded beer ...
Replacing with new Duracell AAA, flashlight did not turn on. Thought
- did I put them in backwards? Nope. Checked with DMM - seem good.
Dug back out the weak original batteries from the trash can, put them back in, and presto - flashlight works!
Lets compare side-by-side. Ohhhhh, what have we here! As you can see in the close-up, we have a difference in not only positive pole mechanical design, but the overall battery length is not the same (in the close up the other end of the batteries has been set equal).
From what I can tell (I can't get the other part of the flashlight off - yet) The 'Malt Max" batteries work because the positive end fits farther into the assembly due to it's longer positive tip (even though the battery is really shorter - this is compensated for by the spring at the other end). There seems to be some sort of plastic molding down there that only lets the positive pole extend down to the electrical tab.
This what I love about standards - there are so many to choose from.
