Author Topic: Any experience with Aoyue Int2702  (Read 6076 times)
Offline hacklordsniperTopic starter
  • Country: hr
  • Don't turn it on, take it apart!
    • HackLordSniper
« on: July 25, 2011, 05:50:04 am »
Basically what i need to pay for a old model ZD - 915 desoldering gun locally i can buy this 3in1 station from abroad.
SO before i buy, any experiences with it?
Oh, the joy of sending various electronics to silicon heaven
Offline PsI-On
Re: Any experience with Aoyue Int2702
« Reply #2 on: July 25, 2011, 09:31:58 am »
I had one of these and the main transformer went on fire leaving me with no tools at all. The quality of these Chinese stations is not good, I would spend a little more and get separate tools that way you won't get caught out if one explodes!
-PsI
  • Country: hr
    • HackLordSniper
« Reply #3 on: July 25, 2011, 10:07:04 am »
-PsI
Well as expected. I have all tools except desoldering tool, i will have to dig deeper to find one then
Offline gregariz
« Reply #4 on: July 25, 2011, 05:37:41 pm »
-PsI
I too would prefer separate tools rather than these all-in-ones. Dave did a review of the Atten unit on one of his vids. I use a Sirocco hot air unit which I believe is made by Aoyue.. you can find them on ebay maybe.. just search for Sirocco hot air.... or I get mine locally at circuitspecialists
http://www.circuitspecialists.com/csi-6028.html
IMO these are the sorts of things I expect to throw in the bin every few years
  • Country: hr
    • HackLordSniper
« Reply #5 on: July 25, 2011, 06:15:20 pm »
Thats not the type of desoldering tool i was thinking about. Im in search for heated gun with suction.
Offline gregariz
« Reply #6 on: July 25, 2011, 07:14:14 pm »
Not sure if its any good.. but the price is right...
http://www.circuitspecialists.com/csi474a.html
  • Country: hr
    • HackLordSniper
« Reply #7 on: July 25, 2011, 08:15:08 pm »
Looks nice, i could order one for review but its 110 VAC
Offline Joebeazelman
  • Country: yt
« Reply #8 on: March 09, 2025, 03:54:19 pm »
Some Aoyue stations use 110V/220V transformers. It's a matter of rewiring the primary side of the transformer.
« Last Edit: March 09, 2025, 04:35:43 pm by Joebeazelman »
Offline u666sa
  • Miami, FL
    • Codernov Electronics Repair
« Reply #9 on: May 02, 2025, 08:09:59 pm »
2702 is 2 in 1. You get solder iron and hot air. 2703A+ is 3 in 1. I have Int2703A+ and had it for over 10 years, since 2014. Great station!!
However, in 2025 it's old technology.
T12 (WQ) tips are old tech.
Hot air is weak compared to newer hot air stations.
Solder sucker is not needed with the advent of new mechanical suckers.
If you can get int2703A+ from eBay broken or used for around $50. That's a good deal. However paying $385 for a brand new unit is not worth it. In such a case there are better deals on Aixun T420D and H314.  :-+
  • Country: yt
« Reply #10 on: January 17, 2026, 07:24:49 pm »
Fifty dollars for a functioning used Aoyue all‑in‑one station is an absurd deal. I would happily buy yours at that price. They may not be state of the art, but they are more than adequate for basic through‑hole work. You can certainly buy better equipment as separate units, but it will cost a lot more and take up far more bench space.
I have to disagree about the value of a desoldering gun. I have gone through several types and brands of mechanical solder suckers and they all perform poorly. A desoldering gun makes removing components incredibly easy and genuinely enjoyable. Aoyue’s gun function is probably its strongest feature and holds its own against any competitor in the same class.
The hot air function is solidly midrange. It cannot match the performance of higher end models that cost more, but the internal air pump makes it more powerful, safer, and more comfortable to use than the cheaper units with the blower integrated into handle. Dave even demonstrated one of those cheaper models catching fire a few years back.
The soldering iron is probably the weakest part of the Aoyue lineup. The old 936‑style irons found on the Int 968A+ are pretty awful. The T12‑style irons used in the Int 2700 series are a huge improvement, but not on the level of the newer JBC designs.
Even so, you can always pair the Aoyue with a dedicated station for the function you use most often and still spend less and use up less desk space than you would on several separate high‑end machines.
