I have 2 Hoover upright vacuum cleaners, and a cylinder electrolux as well. Did not buy any of them, got them all as broken or thrown out and simply did filter changes and new belts on them, and new hoses as needed. As the uprights use a paper bag filter, and I got a pack or two with each of them I did not need to buy new filters either, but the generic ones are ultra cheap, and work well. the cylinder just has to clean the washable filters in there, and clean the dust out of the internal HEPA filter packs, along with minor repairs. Did buy a pack of the large paper filters that it uses, along with an universal cloth filter bag so that I can use it as a wet vacuum as well as dry.
Then in the garage there are another 2 free vacuums, gotten as "not working" where they just needed the pleated filter after the cyclone cleaned, and the rest of the unit cleaned as well. They are the car interior vacuum cleaners, because they are small enough to get into the car easily. Funny thing is that in most vacuum cleaners the motor block is almost always one of 4 variants, and that they are available as spare parts from the appliance spares place for a lot cheaper than a new vacuum. Even more the power rating on the case has absolutely no relation to the motor power, they all are at around the 300-500VA level in the motor department, which you can see from the use of the thin cord on the vacuum.
