But, what do you do in the schematic and design phase, when the only thing the IC datasheet says about power delivery and bypassing is "1 μF and 0.1 μF bypass capacitors required for the power pins placed as close to the pins as possible", for an IC with a 50 MHz clock, 5V supply, and a 3.3mA active current draw?
I would not trust that datasheet regardless of what nctnico says.
Well, that is not what I wrote exactly.
It is how I read your position, causing the argument. You see, we are in full agreement that
"the manufacturer's information (datasheets, application notes, reference designs and support) is the first port of call". It definitely is! The problem is that for many MCU's, the datasheets and so on are just as lacking as for SiLabs EFM8BB50.
The disagreement happened because of your statements like
"No, do NOT ignore the manufacturer's recommendation. They very likely have done extensive simulations and testing to optimise power integrity as part of the chip design and that resulted in the recommended values." just do not match the quality of information in datasheets of many of the (cheaper end) microcontrollers I use and consider using, the EFM8BB50 just being a typical example. Your statement definitely applies to e.g.
Microchip PIC16F152 series datasheet (section 4, starting at PDF page 18), which describes the PDN in quite useful detail with practical advice and guidance easy to understand even for a hobbyist; but in my experience, among the cheaper microcontrollers, it is a rare good example, and not the norm at all.
Are there other ways to go about it? I do know of Fast Field Solvers that one can use to find the inductance and capacitance of conductor topologies [...]
That is overkill as it would take very carefull setting up of the circuit board model.
True, although I do suspect it would be possible to do a KiCad plug-in to export the PCB gerbers and vias — the basic geometry, in other words —, but the IC part (including legs for SMD and TH packages) would be simplified to a jumper wire. For comparative testing of options that would suffice, but it would not have any predictive power wrt. coupled, conducted, or radiated EMI. The reason I mention Fast Field Solvers, is because I have an extensive simulator development background, prefer using Open Source because of being just a hobbyist and having no budget to spare (but not ideologically opposed at all, even though Tux is my mascot), and this kind of stuff is much more familiar to me than EDA or CAD software, especially the high-end professional EDA/CAD stuff.
Higher end CAD packages have impedance simulations build in though and doing AC and DC PDN analysis are expensive extra options.
Ah, I didn't realize. I should have expected that.
I also haven't used the E. M. Workbench, the FreeCAD-based interface to some of the Fast Field Solvers, yet.
For a relatively simple circuit consisting of a microcontrollers and some auxilary chips powered by the same supply, [practical experimentation along the lines tszaboo described] should be doable.
Absolutely, and for the small microcontrollers with poor documentation, also
cheap enough even with a few test/experimental PCBs, as long as one has a decent (not that expensive) network analyzer, or even an oscilloscope with careful measurements (x1 probing for ripple/spectrum, x10 for noise/peaks) undestanding the effect of the probe capacitance, inductance, and input impedance.
All this just leads to one being very suspicious when first looking up a possible new MCU one might want to use. Again, the MCUs with poorly documented and likely un-characterized PDNs do seem to mostly rely on cargo-cult
throw these capacitors at it and it'll be golden "design principle", which easily leads hobbyists astray, and may even become an attitude one does not even notice enough to question... so even for hobbyists, knowing how to verify and do it better, would definitely be useful.
