Hello there,
I have been getting that "Bad Gateway" error message when trying to log into EEVBlog now and then.
Any idea what causes this, and was the site down a few hours ago?
I've been having the bad gateway error for almost a week now.
It mostly happens if I follow my bookmark that sends me to
www.eevblog.com/forum (can get around this by adding /index.php to the end) or if I click on the "Show new replies to your posts" link at the top of the forum.
You can also try hitting F5 if this happens.
Welcome to the strange club of bad gateway people. It's a mystery even to Dave/gnif)
I've been seeing it a lot today
It happened a number of times yesterday. I did try all the browser tricks, but no help. Checked on other browsers and devices - same error 502, even on Internet Explorer that I have never used before to access the EEVblog forum. When the PC had error 502, so did my phone.
At one point, the forum returned but it took few minutes for the authentication to work - I guess someone restarted the forum. When the authentication started working again , so that login worked, I was getting some brief 502's for a while. I would click on a link and get the 502. Reload the page and it worked. After 15 minutes, it settled down again and mostly worked normally.
I don't know if it would help to change the "Bad Gateway" Error 502 page to something that contained a bit more diagnostic information.
Richard
I have had it a lot recently. 502 error.
Fraser
I would simply modify it so as to display "Good Gateway", how hard could it be anyway ?
Yeah, ha ha, or "Spank that dang bad gateway" :-)
F5 by itself doesn't do the trick, at least not in Firefox. You have to hit ctrl-F5 (or is it shift-F5?) to invalidate the cached copy of the page.
The effect, at least until I remember the ctrl/shift-F5 trick, is to make it appear that the forum is down for several days in a row. Someone should look into that...
clear cache fixes it for me.
Re-installing Windoze fixes it for me, except on the occasions when I'm too quick and the server's still down.
It seems, for now, I will be doing EEVBlog in IE instead of Chrome. I have tried all the suggestions and nothing has worked. IE is working fine.
502 - Bad Gateway
We are sorry for the inconvenience that this error may be causing you. We are aware of the issue and are working to resolve it, please be patient.
There is no need to report this error.
Thank you for your patience,
Dave & gnif
24th March 2017: We are performing some database changes, please bear with us.
Currently I find all page loads fail with the above error page then load *VERY* slowly on a retry.
Have the database changes *REALLY* been underway for the last four months?
Perhaps it should link to a server status page or blog (possibly externally hosted) where Dave, Simon and/or Gnif could keep us informed of any known outages, scheduled maintenance etc.
Same problem here for the last week or so. Flushing the cache helps sometimes, but only temporarily. After a cache flush the page loads extremely slowly.
555555555555555555 000000000 222222222222222
5::::::::::::::::5 00:::::::::00 2:::::::::::::::22
5::::::::::::::::5 00:::::::::::::00 2::::::222222:::::2
5:::::555555555555 0:::::::000:::::::02222222 2:::::2
5:::::5 0::::::0 0::::::0 2:::::2
5:::::5 0:::::0 0:::::0 2:::::2
5:::::5555555555 0:::::0 0:::::0 2222::::2
5:::::::::::::::5 0:::::0 000 0:::::0 22222::::::22
555555555555:::::5 0:::::0 000 0:::::0 22::::::::222
5:::::50:::::0 0:::::0 2:::::22222
5:::::50:::::0 0:::::02:::::2
5555555 5:::::50::::::0 0::::::02:::::2
5::::::55555::::::50:::::::000:::::::02:::::2 222222
55:::::::::::::55 00:::::::::::::00 2::::::2222222:::::2
55:::::::::55 00:::::::::00 2::::::::::::::::::2
555555555 000000000 22222222222222222222
It's completely broken.... I'm going to have to go and do something useful now.
It has been happening on and off for me over the last week and today is particularly bad. For each page load I get the bad gateway error, I then have to flush my cache (a several step process), reload the page which is very slow and then start all over again to look at the next page!
Using an old version of the K-Meleon browser (based on the Firefox 3 rendering engine) a simple reload gets there eventually, though it may take several tries, and when it succeeds takes up to a minute to load a simple short topic like this one. Flushing the cache doesn't appear to help.
I can barely use the forum this morning. Clearing the cache does nothing. I have to refresh the page every time I try to move around.
It's horrendous today. Every time I refresh or try and load a page I'm getting it.
Same experience here. Whatever is causing this problem appears to be getting worse.
I get it on my ipad, my android phone and also my PC on both IE and Firefox.
The only reliable? fix for me is if I turn off my internet router at the wall and leave it a few minutes and then restart it. Then all three devices start working again on Eevblog without the gateway message and the forum pages change quicker too.
I'd say that's placebo. It's completely random when you refresh and don't get the error.
