I have a HP 32S which I bought in 1987.
It was perfect at the time. It is still perfect, and is in permanence on my desk where I use it regularly.
Already nearly 30 years ago, I had come to the conclusion that it had reached a perfect form factor that could not be improved. You indeed need a keyboard, and a screen for the results. Although it has some programming possibilities, these are not what this calculator is good at.
All calculators that were competing for improved programming have been obsolete a long time ago. Why this one (as some others of the same form factor) stand up over the ages, is the quality of the keyboard. The numerous scientific functions directly accessible, and the fact that the battery last forever. I dont even remember if I changed it twice in 28 years.
Whenever I need more than a simple computation, I use my computer, where I have a very efficient computer algebra system, but for small computations, I take the calculator.
If I need to draw a curve, I will use the computer, and I believe as well that all graphic calculators are obsolete, unless you have some tight requirements like in some high schools for exams.
