Author Topic: Identify / hack this sensor...  (Read 4690 times)
Offline int2strTopic starter
« on: July 11, 2016, 04:28:45 am »
Attached is a sensor I pulled out of my car's windshield washer fluid reservoir.
So this essentially detects whether I have fluid in that reservoir.
The Inside what looks to be a sealed glass bulb are two "electrodes" that do not seem to be touching (capacitive?).
Anybody want to venture a guess on how it works?
I want to emulate it to keep the windshield washer light off on my dash (converting to race car)...
Online ataradov
    • Personal site
Re: Identify / hack this sensor...
« Reply #1 on: July 11, 2016, 04:46:35 am »
It is a reed switch.
Alex
Offline jh15
« Reply #2 on: July 11, 2016, 04:55:23 am »
Like a weather rock, can't you just look at the tank to see if it is dry.
Edit:
oh race car, just tape a magnet on it.
Tek 575 curve trcr top shape, Tek 535, Tek 465. Tek 545 Hickok clone, Tesla Model S,  Ohio Scientific c24P SBC, c-64's from club days, Giant electric bicycle, Rigol stuff, Heathkit AR-15's. Heathkit ET- 3400a trainer&interface. Starlink pizza.
Offline vk6zgo
« Reply #3 on: July 11, 2016, 04:59:02 am »
The glass thing looks in every respect like a reed relay.
These are operated by a magnetic field,either from a permanent magnet or an electromagnet.
How windshield wiper fluid changes a magnetic field,I do not know----are you sure the sensor is complete?
If it still works,fill the reservoir & look at the input connections with a multimeter.
First,check the resistance with the connection to the car electrical system unplugged,& record that,then with it normally connected,check what voltages w.r.t car chassis appear on each pin of the connector.
Empty the container & do the same tests-------what changes?
Online ataradov
    • Personal site
« Reply #4 on: July 11, 2016, 05:00:15 am »
I'm pretty sure there is corresponding floating magnet somewhere there.
Alex
« Reply #5 on: July 11, 2016, 05:04:29 am »
Tested with a magnet, reed switch it is - that was easy :)
That means I can just short the wire and be done with it.
Thanks guys!
Offline Brumby
« Reply #6 on: July 11, 2016, 05:39:53 am »
+1
Offline tszaboo
« Reply #7 on: July 11, 2016, 08:57:02 am »
No, washer fluid is ferroelectric. :-DD
Offline Kjelt
« Reply #8 on: July 11, 2016, 09:17:48 am »
Or the other way around keep it open, depending where the sensor is mounted and the corresponding floating magnet, if it is an empty indicator I would presume that the switch only makes contact when the level is low.  ;)
Offline amyk
« Reply #9 on: July 11, 2016, 10:20:33 am »
Why don't you just unplug/remove the light? Might even save some weight :P
Offline rrinker
« Reply #10 on: July 11, 2016, 03:08:27 pm »
  :-DD :-DD That was what I was going to say after I read the first post.
« Reply #11 on: July 11, 2016, 11:17:31 pm »
Given that the sensor is on my bench and the light is still on in the car, imma gonna go with it is normally closed to turn the light off :)
Offline vk6zgo
« Reply #12 on: July 12, 2016, 02:21:45 am »
Nice selective editing,Alex
The whole sentence was:-
"How windshield wiper fluid changes a magnetic field,I do not know------are you sure the sensor is complete?"
The last part implies that there must be some mechanism to move a magnet with water level,although it was not obvious from the pix.
I didn't think I had to "spell it out" on this forum!
Of course,you could heat the magnet above its Curie point,then cool it down with the water,but I very much doubted that would be the case! ;D
Offline jh15
« Reply #13 on: July 12, 2016, 04:17:19 am »
Many years ago, somewhat after 9/11 attacks, we (my avionics firm people) were life testing an oil level detector for a Cessna or some airplane.
The jig was running a magnet float over a reed switch.
A response from one of the magnet or switch vendor's asked: Are you building a bomb?
The test run of many months happened to terminate on 9/11 anniversary.
Now I know NSA just perked its ears at me.
