Author Topic: It's "sodder", not "soLder", damnit! (for us USAians)  (Read 14595 times)
PlainName and 15 Guests are viewing this topic.
Online PlainName
Re: It's "sodder", not "soLder", damnit! (for us USAians)
« Reply #75 on: September 17, 2026, 11:15:44 pm »
I'm sorry we put a (metaphorical) gun to your head and made you read this thread.
Just as the target of your ire made you watch (and listen!) to his video.
Not only that he made you whine about it!
The following users thanked this post: lowimpedance, thm_w, newbrain, Sorama
Offline Xena E
Offline Analog KidTopic starter
« Reply #77 on: September 18, 2026, 04:40:53 am »
Touché.
Offline krish2487
« Reply #78 on: September 18, 2026, 05:11:09 am »
Here's how that works, pal:
He's free to call "solder" any damn thing he pleases, with any damn pronunciation.
He's also free to insist that his way is "the correct way" to pronounce it, which it is not.
I'm free to push back against that here, and to point out how silly, effete and absurd his insistence is.
Freedom of speech all around.
See how this works?
why?
I mean why here? wouldnt it make infinitely more sense to settle it with the guy who triggered you? instead of ranting about it on another forum?
Dont get me wrong, I m not saying you shouldnt.. I just wondering why? It is not serving any purpose other than acting as  vent for you and (possibly) start a discussion about the quirks of pronounciation
« Last Edit: September 18, 2026, 05:12:52 am by krish2487 »
If god made us in his image,
and we are this stupid
then....
Online Sorama
« Reply #79 on: September 18, 2026, 05:50:42 am »
See how this works?
why?
Why?
Well, because it is his trademark to rant about everything and everyone.
« Reply #80 on: September 18, 2026, 06:05:03 am »
Dunno about "trademark", but I'll admit I do like to rant every now and then.
Who doesn't?
Online Sorama
« Reply #81 on: September 18, 2026, 07:47:29 am »
Who doesn't?
A lot of people.
it would make life here on EEVBLOG way more pleasant.
(Not ranting that is)
Offline tooki
« Reply #82 on: September 18, 2026, 02:18:59 pm »
Aren't silver solder and silver brazing rods truly the same material?
I was taught that fundamentally, the divide between soft and hard soldering/brazing is the temperature.
I also understand the difference between soldering and brazing as a process is about the temperature.
However, I think the composition of the filler material depends on the application:
Typical brazing rod is yellow/gold in color and is composed mostly of copper and phosphorus. Typical uses would be for mechanical joints in metal structures.
Typical silver solder is silver in color and is composed mainly of silver, copper and zinc. Typical uses would be for jewelry, HVAC and plumbing.
Right. But I asked “Aren't silver solder and silver brazing rods truly the same material?”. I did not suggest that silver solder and all brazing alloys are the same.
Online IanB
« Reply #83 on: September 18, 2026, 03:06:26 pm »
I didn't catch that. Silver soldering and silver brazing might well be the same.
What I have seen is that fabricators have tended to use a very hot oxy torch for brazing, but a more ordinary propane or butane torch for silver soldering. But this might depend on the size of the joint and the amount of heat needed.
Fundamentally, words only go so far, and for real applications proper training, skill, choice of process, selection of materials, and detailed knowledge are required. I can't claim to have any of those.
(When I was a fresh graduate engineer, one of the recommended skills development courses was pipe welding, to gain an appreciation for process and materials. Sadly, I never got the chance to do that.)
Online IanB
« Reply #84 on: September 18, 2026, 03:14:19 pm »
Another thing I have noticed is that when people are silver soldering, they tend to heat the whole workpiece up to soldering temperature and then let the solder flow into the joint(s).
Whereas when people are brazing, they tend to use a very hot flame to locally heat the joint, similar to welding, before applying the filler rod.
Offline tooki
« Reply #85 on: September 19, 2026, 12:43:31 pm »
Is that not more of a function of the size of the workpiece?
Online Zero999
  • 0999
« Reply #86 on: September 19, 2026, 02:39:10 pm »
You Yanks are weird.
 :box:
Not as weird as Brits and Aussies losing their minds each and every time they hear the American pronunciation of “soldering”! :P
(Upon which they then embark on an explanation of Americans “dropping” the L, giving an incorrect etymology, and often tacking on some rant about Americans “bastardizing” “their” language, when in actuality the British bastardized it more!)
The question is how did the L ended up in the word soldering in the first place, when the original French word souder lacks it? Could it be the British added the L which was silent in some dialects and pronounced in others, only for the silent version to be adopted by the Americans? Maybe it's because there were and still are more French speakers in America? It would certainly explain the silent H in herb and huge in most American English speakers.
Your assumption about the British bastardising English more than the Americans is incorrect. I suggest you watch some videos of 100 year old recordings on YouTube, of then American centenarians speaking English. You'll find that their accent, which is be over 180 years old now, since one's accent changes very little from their late-teens onwards, bares little resemblance to modern American English, often sounding more British.
In reality both American and British English have diverged significantly. I would expect the first English-American speakers would have sounded more like the British upper class accents back then, since it cost money to emigrate. This is at odds with the idea British English is more posh, which has never, ever been the case, outside of the extreme upper class and privately educated. Unfortunately we can't go much further back than the 1840s.
Offline tooki
« Reply #87 on: September 19, 2026, 04:23:07 pm »
 :box:
(Let me preface this with a reminder that American English is my native language, and that I studied linguistics at university, and that my mother was a lifelong ESL teacher, so I have a very strong background in English and its linguistics and history.)
I already explained this in reply #23:
Amazing how a whole country can be wrong.
Soldering is something you do with a soldering iron.
Soldering and brazing were in use 2500-3000 years ago. The Romans used lead/tin solder in plumbing.
The English *word* comes from Latin solidare or solidus which clearly have pronounced 'l's. The verb soldering is recorded by 1466 (Paston Letters ... Norfolk gentry), before the Americas were (re)discovered.
Just one small problem with your etymology: it is incorrect. English got the word not from Latin, but from French, by which point the L had already been dropped. Then, after the US colonies were established, English in the UK underwent a wave of “re-latinization”, during which the L was added back. And that change never propagated to the US.
There was a trend among some UK scholars  in the 16th and 17th centuries to make English words look more like their presumed Latin (or Greek) origins. See https://en.wikipedia.org/wiki/English-language_spelling_reform#16th_and_17th_centuries
I don’t think so, but I’m not 100% sure.
Unlikely. Those French speakers were, and are, geographically quite concentrated, and mainstream America didn’t really embrace French. (I mean… look at how awful most Americans’ pronunciation of French words are: they think every French word ends in the “wah” or “ey” sounds. In my observation, the British benefit from their proximity to France in terms of proper French pronunciation, while Americans benefit from their proximity to Mexico (and immigration from all of Latin America) in terms of proper pronunciation of Spanish words, something the British tend to be terrible at.)
While “herb” does indeed have a silent H in American English, I don’t know where you got the notion that “huge” has a silent H in standard/mainstream American English. It most certainly does not; the H is pronounced by nearly all speakers.
Sorry, my friend, but you’re absolutely incorrect. First of all, it’s untrue, and second, it’s not an “assumption” of mine, it is well-established fact among linguists who have studied the history of English (including British linguists of English). Here’s how Reply #23 continued:
It's not unusual for pronunciation to drift in isolated communities such as the USA.
As a general statement, that is true. However, in the specific case of English, it is actually British English that drifted far more. This is well established by historical linguists of English (for example, the British linguist David Crystal, who has written several definitive works on the history of English, published by Cambridge University Press.)
The best summary of the situation is this: since British English and American English “split”, both dialects have evolved away from the common ancestor, but British English evolved away more. So where the dialects differ, there is a greater chance that American English retains, or is closer to, the original form.
(I studied linguistics at university, so I have a deeper background in this than the average Joe.)
However, your observation about how early recordings sounded…
…is correct.
But that’s because early recordings didn’t capture mainstream speech. Recording was expensive, so there was huge selectivity in what and who got recorded, and it selected for the wealthy and powerful. And as it happens, the upper class of the northeastern US spoke a very different dialect, one which has largely died out since: https://en.wikipedia.org/wiki/Northeastern_elite_accent
That very article’s lede includes the statement: “The late 19th century first produced audio recordings of and general commentary about such accents used by affluent East Coast and Northern Americans, particularly those in New York and New England.”
(And California was still unimportant at the time, so there was no equivalent Western elite accent. Elites would have used the Northeastern elite accent.’
So yes, the recordings sound more British, but that’s because they weren’t recordings of standard American English.
See also the Mid-Atlantic accent, the odd accent learned by actors and the like in the early 20th century (so called because of it being stuck somewhere in the middle of the ocean between USA and the UK, since it deliberately uses aspects of RP).
Yes, and I said that back in Reply #23: both have diverged from our common ancestral form. But British English diverged more on average.
Ummm…
While it was the wealthy who organized and financed early colonization, they brought with them large numbers of laborers. And after that, the majority of emigrants were not wealthy: there were various waves of laborers, farmers, indentured servants, and the deliberate export of the poor and of convicts.
So no, even from the very beginning, non-elite British English would have been dominant, as the elites were, numerically speaking, a tiny minority.
Yep. For sure, Americans have a very rosy, romanticized view of British English, assigning to it high status, but also historical mythology, practically. (Hence every historical drama, historical reenactment, history documentary, etc. using posh British English.) In reality, the English spoken by the masses on both sides of the pond was never dominated by RP.
(What Americans don’t realize is that the British most definitely do not reciprocate the positive sentiment that Americans have towards the British and their English!)
The following users thanked this post: Zero999, newbrain
Online negativ3
  • Country: th
« Reply #88 on: September 19, 2026, 04:32:36 pm »
There may be vanishingly small differences in genetic material but actual differences are obvious and measurable.
Tribes being tribes and all.
Offline tooki
« Reply #89 on: September 19, 2026, 04:38:00 pm »
What are you talking about?
Online negativ3
  • Country: th
« Reply #90 on: September 19, 2026, 05:02:10 pm »
Too much lead in your sodder?
Offline tooki
« Reply #91 on: September 19, 2026, 05:03:49 pm »
Online negativ3
  • Country: th
« Reply #92 on: September 19, 2026, 05:38:19 pm »
Changing the spelling to match the phonetic is gnawing as an evolutionary step.
Offline TimFox
« Reply #93 on: September 19, 2026, 05:39:30 pm »
Yes, Colonel!
The following users thanked this post: Analog Kid
Online IanB
« Reply #94 on: September 19, 2026, 05:47:38 pm »
On the general subject of linguistics and pronunciation, there is another interesting phenomenon happening.
Traditionally, words like yolk, folk and salmon are pronounced without the L: yoke, foke, sammon, etc.
But an increasing number of younger people are putting the L back, so you will increasingly hear foLk and saLmon these days.
Online negativ3
  • Country: th
« Reply #95 on: September 19, 2026, 05:51:16 pm »
Lieutenant, a word the British looked at, saw absolutely no f, and confidently pronounced ‘leftenant’ anyway
Online IanB
« Reply #96 on: September 19, 2026, 06:47:55 pm »
There are words where the historic pronunciation has fallen out of step with modern spelling.
The "u" in lieutenant, hundreds of years ago, is documented to sound interchangeably like a "v" or an "f" (think of der Vogel in German, and note that the letter w -- a double v -- is still called "double u" in English today).
Basically U and V have a complicated history and often swap places.
Online negativ3
  • Country: th
« Reply #97 on: September 19, 2026, 07:06:26 pm »
This has been proposed as part of the explanation for British lieutenant becoming “leftenant” but the origin of the f pronunciation isn't known with certainty. The German Vogel doesn't establish it either. German V having f in native words is the result of German's own spelling history, it doesn't demonstrate that medieval English/French u could freely represent f.
Online Zero999
  • 0999
« Reply #98 on: September 19, 2026, 08:23:16 pm »
@tooki Thanks for your post. It was very informative. Regarding the H in huge, I noticed it in a YouTube video. People are programmed to notice differences. No doubt I've heard many Americans pronounce huge with the H and wouldn't have noticed, hence me falsely generalising.
I still dispute that American English has changed less than British English. History is written by the winners after all, so it shouldn't be surprising it's what you've been taught, given the fact the USA is a dominant cultural power. I have also informatively studied some social science, although not linguistics and I take some of it with a grain of salt, because it isn't a matter of right or wrong as is the case for hard sciences such as engineering. It isn't as though there are recordings from 250 years ago to prove one way or the other.
[EDIT]
Thinking about this again. It depends on what is meant by British English?  There are many variants.
Lets just focus on England, sticking to the main population centres which are London, through to the Midlands and Northwest. The main differences between our accent and the American ones are:
We lost the R sound, which was preserved in the US i.e. English-English is non-rhotic.
The Americans lost most of the you sound, drop the yod, in many words which we preserved, i.e. tube is t-you-b, assume = ass you m etc.
Some A sounds are only pronounced as ah in Southern and Eastern England. In Manchester they say ask, the same as the Americans do, rather than ah sk.
Scottish and Irish English have as much in common with English-English as American English, sometimes to the point of being difficult to understand.
Then there are numerous examples in England where the Rs live on such as the South-West and much of Lancashire and parts of Eastern England and where yod dropping is more common than America Engish, so we get moo sic instead of m you sic and who ge, rather than h youge.
Finally the language is changing. In English-English, yod dropping and rhoticity are dying out.
[/EDIT}
Anyway, I did a bit more research into old videos of interviews with the elderly and found this, which includes people from other parts than the North East.
Yes you are correct that people who are from the North East sound upper class British, but there are, or perhaps were, many accents which differ significantly from modern American English. It does seem to me that older American English often sounds more like a mix West Country and Irish, than it does today.
Accents aside. I found that video a joy to watch. I'm impressed at how well elderly people looked and spoke (clearly and articulately) back then.
« Last Edit: September 19, 2026, 10:11:47 pm by Zero999 »
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #99 on: September 20, 2026, 06:59:26 am »
Pronunciation varies over even relatively small distances. I once heard a BBC program where the presenter set out to find out at what point in thew country going from south to north the word house started to be pronounced "arse".
"upper class" English is meant to be uniform with no way of telling where the speaker is from. The reason is obvious, people have prejudices about everything including where you are from, the first thing that gives that away is your accent.
There is an old film called my fair lady, it's about a man that could tell what street you were born on in London by your accent. I don't know if this was ever possible but I expect the rate in distance at which accents change is probably down to how much people moved around, as we have become more mobile accents have averaged out over a wider area. Many very localized accents were probably never "discovered" as so few people spoke them that by the time anyone who cared would have got there to hear them their accent would have merged with the wider population.
when I lived in southern Italy there were old folk that had never gone more 100 miles away. Each town had it's own language not long ago and there were still old people who did not speak Italian, so never mind their accent, they could not even talk to the majority of the town never mind be able to go anywhere beyond.
