Okay so I bought this a few months back then I moved it and it wont power on no standby, nothing.
There is scant information about this type of fault, and I've gone through the basic tests - I get the 15% +/- 25% (18v), but no 10V no 5V (which is fed from the 10v from what I see) and no 3.3v.
Does anyone know what is governing the power up sequence? I see a TPS 650701 on the front panel and it looks like its checking or generating 1.2/1.5/3.3v.
Is there a power management ic thats not turning on regulation?
Is the 3v3 generated on the main board or on the front panel and fed back - i see a big inductor on the 3v3 line on the front panel.
Is there a standby voltgae test point?
Does anyone have any work theyve done on psu startup before I start probing out every single component on the board trying to trace the 3v3 line and figure out the sequence.
