Author Topic: Keysight 34465A no power issues.  (Read 400 times)
Offline nexus1972Topic starter
« on: July 09, 2026, 02:20:51 pm »
Okay so I bought this a few months back then I moved it and it wont power on no standby, nothing.
There is scant information about this type of fault, and I've gone through the basic tests - I get the 15% +/- 25% (18v), but no 10V no 5V (which is fed from the 10v from what I see) and no 3.3v.
Does anyone know what is governing the power up sequence? I see a TPS 650701 on the front panel and it looks like its checking or generating 1.2/1.5/3.3v.
Is there a power management ic thats not turning on regulation?
Is the 3v3 generated on the main board or on the front panel and fed back - i see a big inductor on the 3v3 line on the front panel.
Is there a standby voltgae test point?
Does anyone have any work theyve done on psu startup before I start probing out every single component on the board trying to trace the 3v3 line and figure out the sequence.
Re: Keysight 34465A no power issues.
« Reply #1 on: July 09, 2026, 02:37:41 pm »
okay so a bit of an update if i scope 3v3 it switches on briefly for about 5ns so clearly a caps either shorted or something else is dragging it down is this likely to be the spear mcu?
Offline voltsandjolts
« Reply #2 on: July 09, 2026, 03:01:24 pm »
What colour is it, tan or newer black unit?
« Reply #3 on: July 09, 2026, 03:52:45 pm »
Its an older tan unit, but it had never really been used screen protector still on and was boxed up for years.
I also just realised ive posted this in the wrong forum area :-(
I'll repost in repair and close this one
