Well what do you expect?
Read your posts in this thread from the top ... from the start of the thread it's kinda obvious you barely know what you're doing.
From the video, I can tell you have no clue because you're just talking crap and twisting the knobs and you fail to even hear the relays making contact, which means something connects various taps of the linear transformer together. But since you don't see any change on the displays ... it should tell you something. Either the relays trigger erratically (and then you'd follow the circuit to see what could trigger the relays which could tell you that something is faulty) or check other stuff in the power supply.
Then from your post ... you're just "jumping the gun" and assuming those indicators are faulty when in fact you don't know that. Then you think those are microcontrollers, which tells me you didn't even bother to search google for "ICL7106" to find out it's a 3 1/2 multimeter IC which would then further tell you that lcd display is a custom one and so on.
Then I don't see any mention of you actually mentioning the voltages in case one of the low voltages used by the circuit is missing... and i don't see a snapshot of the actual circuit board, just in case someone here on this forum may want to point you to check a particular IC, or tell you to see if a voltage reference is bad or not, or to see if a particular zener diode or plain diode is broken/shorted ...
Yeah, it's just much easier to make shaky videos and play (in a stupid way) with high voltage without any safety and make other people you don't know anything about douchebags.
Actually, the relays are pretty fucking obvious and those are switching in the taps for the voltage, and they were behaving the exact same way they did when the amperage display worked properly, also, I did not care about the voltage readout as that was working fine, and maybe try looking at the date the video was posted, I have checked further into this problem since then, checking voltages and diodes.
News flash, not everyone is at the same electronics knowledge as you, I have not worked with op amps, so maybe consider that people's experience may vary before being a prick. Considering these power supplies are made in china, I figured the controllers on the back of the LCD segment also handled reading the current/voltage in a similar way that other cheap amperage and voltage displays from ebay do, that is why I figured that is where the problem lies considering the connections were all in good shape and my multimeter showed a proper amperage reading when hooked up with a load.
Guess what, this thread was not about the production quality of the video, it was about an issue I found. You don't think I know it isn't great quality? Big fucking whoop you can see the results of whatever problem there is. If you have a problem with it don't watch it.
Apparently here there are stuck up pricks as well who think that just because someone knows less than them they know nothing at all, instead of taking the time to consider that different people may be at different levels.
And if you think I'm behaving badly bit whoop, I'm sick of the shit people hand out all the time, assuming shit and feeling all high and mighty about it and I'm tired of taking that shit from people so I'm going to speak my mind when someone acts like that.
