Assuming you are confirming you feel you understand the concept of false equivocation, its easy. Show me how your accusations are equal to the legal concept that was the subject of your commentary. This is simple science/math.
I take issue with your use of the word "accusations." I was offering a correction to your false statement that all forms of discrimination are illegal.
For supporting evidence, here is an excerpt from the Civil Rights Act of 1964:
All persons shall be entitled to the full and equal enjoyment of the goods, services, facilities, and privileges, advantages, and accommodations of any place of public accommodation, as defined in this section, without discrimination or segregation on the ground of race, color, religion, or national origin.
Emphasis mine. If your position were correct, the bolded words and the list of protected categories would not be included. As we are given an explicit list of bases on which we may not discriminate, it follows that discrimination based on traits or categories not mentioned remains legal.
And we have court cases upholding my position.
Rucho v Common Cause (2019) considers whether the 2016 North Carolina Congressional Plan is unconstitutional under the Equal Protection Clause of the 1st Amendment. (As I'm sure you know, the Equal Protection Clause was added to guarantee rights to black Americans, making this case relevant to the question of discrimination.) SCOTUS upheld the lower court's ruling that the 2016 plan violates the Constitution, which is irrelevant. What is relevant is their reasoning when making this decision. I trust you can follow along without any trouble, but I am worried that I might not reproduce the chain of logic very well (or may not do a good job of communicating it) so here is a link to the entire decision if you want to look it over yourself:
https://www.supremecourt.gov/DocketPDF/17/17-1295/44836/20180427114851513_17-1295%20Rucho%20v%20Common%20Cause%20Motion%20to%20Affirm%20by%20the%20Common%20Cause%20Appellees.pdfThe appellants argued that the District Court failed to adopt a "predominant intent" standard, which SCOTUS has applied in racial gerrymandering cases in the past, which is how this ties into our discussion about discrimination. There are two analytically distinct lines of racial-gerrymandering cases, and a "predominant intent" test only applies in one of them. One of these analytical lines is from
Gomillion v Lightfoot (1960,) the
Gomillion line, and the other is from
Shaw v Reno (1993), the
Shaw line.
In the
Gomillion line of decisions, SCOTUS has never applied a "predominant intent" standard, relying instead on an "invidious intent" standard. In the
Gomillion line, proving invidious intent is sufficient to make the inclusion of racial consideration a violation of the Equal Protection Clause.
The
Shaw line of cases require proof that the map-drawers considered race in the drawing of district lines, and that racial considerations were the predominant consideration. It is not required that invidious intent be proven in the
Shaw line, as race-based considerations are "uniquely odious," and they therefore prohibit even well-intentioned use of race (as the predominating factor) when redrawing voting districts.
SCOTUS rejects the appellants' argument regarding "predominant intent," as the appellants themselves openly admitted that they had invidious intent; therefore the predominant intent standard does not apply, and their case would fall under the invidious intent line.
Now we get to the important part:
The legitimate use of political classifications does not violate the Equal Protection Clause even if political considerations “predominate.” The District Court’s test, therefore, makes partisan gerrymandering claims harder to prove than racial ones. Racial-gerrymandering plaintiffs may show either invidious intent (Gomillion) or the predominance of racial considerations notwithstanding the absence of invidious intent (Shaw); partisan-gerrymandering plaintiffs can succeed under the District Court’s test only by proving invidiousness.
So there we have it. It is perfectly fine to discriminate based on political affiliation, so long as you are not discriminating with invidious intent.
