Author Topic: Model Trains  (Read 109173 times)
MarkF and 8 Guests are viewing this topic.
Online MarkF
Re: Model Trains
« Reply #175 on: February 08, 2024, 02:36:10 pm »
10x7 is a good size. I have space only for 9x4 usable area on a 10x4 board.  It has already taken half the room!
You can dull the LED surface if needed to reduce the brightness.
In the small railroad maintenance buildings, I painted the LED lens with TAMIYA Clear Orange to get more of an oil lamp effect.  In the industrial buildings, I kept the warm white color.  I have some cool white LEDs I'm going to try to use for street/parking lot lights.  They're not very bright though.
If you look at the Signal Tower, the upstairs is 'warm white' while the downstairs has the 'TAMIYA clear orange'.
Warm white LEDs have become difficult to find.  Most of the LEDs (Mouser / Digikey) just say white without specifying color or temperature.  Their datasheets are just as bad.  The datasheet lists that different color temperatures are available, BUT the part number doesn't reflect any temperature selection.
« Last Edit: February 08, 2024, 02:38:18 pm by MarkF »
Online tszaboo
Re: Model Trains
« Reply #176 on: February 08, 2024, 02:45:07 pm »
Here is what I made. Turnout decoder for DCC.
« Last Edit: February 08, 2024, 02:49:49 pm by tszaboo »
Offline andy3055Topic starter
Re: Model Trains
« Reply #177 on: February 08, 2024, 04:58:03 pm »
I am getting very jealous!  ;D
« Last Edit: February 08, 2024, 05:00:26 pm by andy3055 »
Re: Model Trains
« Reply #178 on: February 08, 2024, 04:59:57 pm »
Make a bunch and sell them.
Online MarkF
Re: Model Trains
« Reply #179 on: February 08, 2024, 05:05:23 pm »
I can't quite make out what it does.
I don't do DCC.  Just curious?
Does it just power the frog and diverging tracks?
Does it throw the points?
Is that a MCU to decode the DCC?
« Last Edit: February 08, 2024, 05:07:34 pm by MarkF »
Online tszaboo
Re: Model Trains
« Reply #180 on: February 08, 2024, 05:20:32 pm »
I tried, there was very underwhelming response from everyone. I gave away a bunch to friends and family for now.
It drives the solenoid based turnout motors like these:
The whole frog thing... Most European brands as I understand have been making insulated frogs for decades now, so I honestly don't know which brands have this issue. Maybe older layouts.
Online MarkF
Re: Model Trains
« Reply #181 on: February 08, 2024, 05:41:31 pm »
I believe most companies offer both insulated and electro- (metal) frogs.
My question would only apply to electro-frogs in which case the frog polarity
needs to change with the point positions.
The advantage of an electro-frog is to avoid loss of power going over the frog
for short locomotives or ones with only one set of pickups.
Most of my turnouts are Peco (who offers both types) with a few Shinohara.
The track is Peco flex track with brown ties.
Re: Model Trains
« Reply #182 on: February 09, 2024, 02:13:49 am »
for short locomotives or ones with only one set of pickups....
You should get a patent first. That is if it is a unique design.  Then, sell it to Atlas or Hornby or any other manufacturer.
Online tszaboo
Re: Model Trains
« Reply #183 on: February 09, 2024, 09:16:57 am »
I'm familiar with the issue. I just don't see track layouts where the electro frogs are used. The Piko layout I have has isolated frog that actually makes a contract when you switch it. Marklin, Fleischmann and other Europena brands do the same as I understand. Peco, Atlas and other American brands do different things. So I wasn't going to add this functionality, as I tried to keep it simple and small.
There isn't anything revolutionary about this, Marklin has turnouts that have the electronics built in, and as I understand Zimo accessory decoders for example can be programmed to do this. Al these companies have their internal engineering team, if they wanted something similar, they could do that easily. I mean it's a size of a loco DCC decoder with less functionality.
Offline joeqsmith
Re: Model Trains
« Reply #184 on: April 19, 2024, 04:24:43 am »
My Lionel 2-6-2.  Like my old Marx, these are not worth a lot.  If you want to repair one, you may find a whole new engine is cheaper than that one part you need.   :-DD
I found two Lionel tinder cars in my stash but both were plastic in rough condition.  More so than my other bits.
Re: Model Trains
« Reply #185 on: April 19, 2024, 04:48:16 am »
The 3 rail system!
Re: Model Trains
« Reply #186 on: April 19, 2024, 11:06:14 pm »
If you use a fiberglass pen, you can clean the wheels very well.
Offline floobydust
Re: Model Trains
« Reply #187 on: April 20, 2024, 03:03:07 am »
I wonder how much current the loco's use? Including the headlight and smoke generator.
O-scale train set I had, it was powered by a Louis Marx 1209 toy transformer. LV AC variac, no circuit breaker or fuse that I remember. It seems to have been a Marx train set, I'm not sure.
Made quite a few sparks on the tracks. Tried cleaning them with steel wool, uncle's idea. That lit up and started burning. Scared the shit out of me.
Then the figure-8 crossover shorted out intermittently and the track got red hot and smoked. The train set from hell lol. A manly model train, that's for sure.
Years later went N then HO and that was plastic baby in comparison.
Online tszaboo
Re: Model Trains
« Reply #188 on: April 21, 2024, 06:21:07 pm »
H0 is typically less than 1A on full speed. I don't know the smoke generators because I'm not interested in old locos.
Re: Model Trains
« Reply #189 on: April 22, 2024, 03:34:31 pm »
Those older motors may be taking a bit more than that. Also, the moving parts are heavier than that of newer models, adding to the load.
Offline floobydust
Re: Model Trains
« Reply #190 on: April 22, 2024, 11:29:48 pm »
I had two different controllers.  One was a small cube.  It would run hot and smell.  If it was shorted, inside it had a thermal circuit breaker that would cycle.  First time I tripped it and lost all power, I was scared I had just ruined the train.
The other controller was older and much larger.  It had a light bulb for short circuit protection.
Google search, looks like a lot more than I would have guessed.  Big layouts, lots of lamps....
https://ogrforum.ogaugerr.com/topic/what-is-a-good-estimate-of-the-max-amperage-that-would-support-most-o-gauge-trains
O-gauge is I think a brushed universal motor? No magnets that I can recall, and I thought AC.  In that thread they were saying up to 4A typical.
Offline joeqsmith
Re: Model Trains
« Reply #191 on: April 23, 2024, 12:53:50 am »
Mine are brushed with wound stator and rotor (no permanent magnets).   I have been running them with a DC supply but the old controllers were 0-18VAC to run the motors.  In other words mine will run with AC or DC.  I did not measure the current when I was running them but can tell you that my supply was limited to 5A and they broke traction before folding back.  I started out testing with my 2A supply and it would fold back.   So for my engines, somewhere between there.
Offline floobydust
Re: Model Trains
« Reply #192 on: April 23, 2024, 02:22:53 am »
I noticed the old Lionels have no reverse? most were from the era before diodes and it's a mechanical thing to flip the field coil around, or add a bridge rectifier.
Or the third rail was used for that hmmm.
Offline joeqsmith
Re: Model Trains
« Reply #193 on: April 23, 2024, 04:07:07 am »
All of mine had reverse.  Some had a bumper that would change the state of the switch (and rotate a little man on top) but most had the E-unit you show.  This includes all of the engines I have ran pull tests on.
The two Marx engines have forward and reverse.  That Lionel has forward, neutral, reverse, neutral.  It can also be locked into the last state as your drawing shows.
Re: Model Trains
« Reply #194 on: June 07, 2024, 04:55:41 am »
The village playground has a working merry-go-round.
Offline jonovid
    • JONOVID
Re: Model Trains
« Reply #195 on: June 30, 2024, 03:27:08 am »
add Cats to the mix  :popcorn:
Hobbyist with a basic knowledge of electronics
The following users thanked this post: abeyer
Re: Model Trains
« Reply #196 on: June 30, 2024, 03:28:28 pm »
Not a great idea as the hairs will clog the locos. Anyway, we don't have any animals at home. Less trouble for me.
Offline MathWizard
Re: Model Trains
« Reply #197 on: July 16, 2024, 04:52:20 pm »
All the makings for an early horror movie.
As a kid I had a little circle track/train set, and also the Turbo Train kit, that had magnetics and drove up a vertical section of track. I have some good memories of that stuff, but sadly it all got thrown out decades ago.
The 1st variable PSU I used to do stuff with was the one from the circle track/train. I took it apart at one point, way before I knew any amount of electronics. I can't remember what was inside, it, but not very much. I remember burning out an antique light bulb with it, it looked like a ball of cotton inside, and unfortunately it burned out like it was too.
Here's a really cool model museum in Hamburg, Germany
« Last Edit: July 16, 2024, 04:56:10 pm by MathWizard »
Re: Model Trains
« Reply #198 on: July 16, 2024, 11:03:50 pm »
I have been to the Hamburg one. It is amazing. Multiple floors and such details. There is a much smaller one in Berlin. It models the city of Berlin.
Offline EEVblog
Re: Model Trains
« Reply #199 on: July 17, 2024, 03:27:46 am »
I've been there, it's beyond awesome.
