Good acceleration is in fact useful and even a safety benefit, for example in overtaking on short straights on a 2-lane road.
And for that you need the acceleratiotn rate of an F1 car? People use those cars as weapons to take over other cars where you shouldn't but you do it anyhow because you can. Very safe indeed, well done.
750 kW of power. Did you take a calculator to calculate the losses at such redicilous power? You probably didn't. That's 2000 A at 375 V or 4 kW loss for every mOhm.
If you want I will calculate the cable requirements between a tesla running 2000 A trough a cable and a car limited to let's say 200 kW which is still about 260 hp. Anyone claiming you would need more than 260 hp for a passenger car is probably a fool. A 250 hp car would go from 0...100 in 6 sec and would only require 500 A with a battery voltage of 375 V.
The difference in I²R losses is not a small number.
Edit: If the goal is to save the panet like Musk claims, the answer lies in lightweight, propely sized 150–200 kW vehicles and cetainly not in a 2 ton killer rocket with battery cooling taken to extremes to support 2 kA. In order to achieve this, the batteries are packed in heat conductive epoxy. How on earth do you recycle this madness? You can't.
