To fix the WIndows upgrade problem, I think I might just slip my boot drive into a another machine, let it update (hopefully), and then switch it back
I did see that for NVENC rendering, the Pascal Quadro's can do 9 streams of H.264 1080P high quality frames simultaneously or 21 streams of the Highest quantity of frames. For consumer GPU's, NVENC limits it to just 2 streams. Sounds like nVidia has crippled the non-Quadro Pascal based cards like the GTX 10X0 series.
High quality of course being relative for hardware encoding, if you can spare a few minutes x264 gives you more bang for your MB.
Once that's all sorted and the machine is purring properly, consider a refresh install of the latest version Vegas,
and see if the render biz has improved
Putting the drive into another machine worked! (i5 dumpster PC)
When the drive was put back into the dual Xeon it did the "Getting devices Ready" thing but froze at 70% on that.
A hard power down and it's now booted and running the latest version of Win 10
Xeons you use are meant to run server workloads (where reliability is more important) not really suitable for video rendering which is a compute oriented workload. Server machines are designed for reliability not speed. It is like MARATHON vs 100m SPRINT. It is no wonder your renders must be a MARATHON race . I'd suggest you can wait for Ryzen refresh (Ryzen+) getting released some time in april this year. Or otherwise you can invest in Threadripper (expensive but worth if you want to get rid of all the hardware bulk)
Ideally to keep it compact, I'd rather go for a small MATX Threadripper setup ()
All SSD/m2 storage for desktop and large NAS for archival, uploading to youtube and storage of clips.
for matching per-core performance of commodity desktop cpus (Ex: Intel 8700K) one would need to invest in serious Xenon CPU which costs in the $5 to $8K range (just the CPU alone). In that price one can easily purchase 8 x of 1950x best Threadripper CPUs.
For a casual video rendering (Not 24x7 rendering thats needed for a movie production house) like Daves requirement Xeons are simply not suitable from price performance comparison. What is needed - a reasonably priced machine which simply renders fast enough and uploads to youtube.
All that said - if you're going to do GPU acceleration I really don't see any point persisting with a giant dual Xeon machine..
It doesn't cost me anything to keep using what I'm using.
FWIW I found I massively improved the generla reliability and boot speed of my dual Xeon by switching to UEFI, it looks like you’re running legacy BIOS. You can do this in place, it takes about 15 minutes or so, but make sure you have a system drive image backup and copy of your BIOS settings before you do!
I hadn't realised you could use third party codecs in Vegas, but you can - using Video for Windows, pick any option, and then change the Video Format to x265vfw or whatever you have loaded. I did a quick test in Vegas 14 and the open source x264 codecs seem a little slower using the CPU rendering then say the Sony AVC codec.
If there is a stand-alone Windows codec that can use NVENC, that would be great. So far, I have only seen NVENC codecs embedded in packages.
