Other features of UK plugs which seems to have been missed here...
The earth pin is always on top (the L/N are "down" when facing the socket) and is exposed all the way to the plug body (not partially insulated). With the earth on top, anything that happens to fall down onto a partially withdrawn plug and into the gap is likely to sit in contact with the earth pin rather than a live one.
Particularly important with metal window blinds falling onto a power point...most other designs risk the blind being made live.
Another feature - the cable always goes in at 90 degrees, never straight. This prevents things like furniture pressed against the wall from straining the cable and potentially splitting the insulation. It also discourages pulling the plug out by the cord (which introduces a risk of pulling the wire out of the plug with habitual pulling).
What else...ah yes, the flat pins offer greater contact area with the socket electrics, increasing current carrying capacity - the round continental plugs dont allow for much practical contact area, making things hotter.
Brilliantly engineered, though from a users point of view, big and unwieldy!
