Author Topic: See what a home made 20Kw microwave oven can do!  (Read 2117 times)
Online BrianHGTopic starter
    • LinkedIn
« on: October 23, 2024, 07:15:21 pm »
 :scared: :scared: :scared: :scared: :scared: :scared: :scared: :scared: :scared: :scared: :scared: :scared: :scared: :scared: :scared: :scared: :scared: :scared: :scared: :scared:
Offline Alex Eisenhut
  • Place text here.
Re: See what a home made 20Kw microwave oven can do!
« Reply #1 on: October 24, 2024, 02:51:44 am »
Sure, OK, bet my  burrito is still frozen in the middle anyway...
Offline SiliconWizard
« Reply #2 on: October 24, 2024, 03:44:46 am »
It's all perfectly safe! ;D
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: October 24, 2024, 05:22:25 am »
If it's more than a couple inches thick, yeah. That hot pocket though!
Seven Transistor Labs, LLC
Offline Nominal Animal
« Reply #4 on: October 24, 2024, 06:24:41 pm »
"Look what I can do!"
 – Stuart, from Mad TV
Online tom66
« Reply #5 on: October 24, 2024, 09:22:31 pm »
I love this kind of insanity.  I'm amazed he didn't kill the magnetron with all of those arcs.
    • LinkedIn
« Reply #6 on: October 24, 2024, 10:14:43 pm »
6 seconds until a cup of water boils...
I usually prepare my tea 2 liters at a time and refrigerate.
I nuke a cup of tea at a time and it takes almost 3minutes to get it boiling.
That 20kw microwave would be a godsend for my tea fix...
Maybe I need to make some sort of huge bank LifePo battery pack with 20 1kw water boiling heating elements like those in small kettles and create my own instant hot tea machine.
« Reply #7 on: October 24, 2024, 11:11:32 pm »
i'm amazed he didn't kill himself.
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #8 on: October 24, 2024, 11:14:08 pm »
Slightly disappointed he didn't frankenstein twenty standard magnetrons together though..
Day Job: Mostly LEDs
The following users thanked this post: pardo-bsso, Exosia
Offline antenna
« Reply #9 on: October 24, 2024, 11:20:13 pm »
I'm amazed the camera worked that close to the oven door
Offline RJSV
« Reply #10 on: October 25, 2024, 05:18:39 am »
He says:  "oops;  cover came off,  but I don't want to fill the room with microwaves!"
   That,  actually,  might be cool, (entertaining) to watch, and plus the power level might be high enough to play around with (educational).
   Cook a dead cow...but that might take 7 minutes.   Warm up a HOT TUB ??
I'd try cooking a COUCH, ...if it was me.
For silliness,  try 'cooking a microwave oven'.
   You could,  also try cooking your 'Use Permit',  issued by local Fire Marshall.
Speaking of which:  at some point you would want a permit,  or need a permit,  ultimately.
Sneaking is ethical, I hear,  if you don't flaunt it.
Not 'getting caught' WAS the new morality.
At present,  the ethics could be:  "I'm not going to answer that."
Tell THAT to your local Fire Marshall.
Offline johansen
« Reply #11 on: October 25, 2024, 08:48:55 pm »
I've wondered for a while what the max power output of a household magnetron is.
at a minimum you should be able to double it because its running off a half wave voltage doubler.
then maybe double it again before it arcs over internally.
Offline thm_w
  • Non-expert
« Reply #12 on: October 25, 2024, 09:14:22 pm »
I thought it was going to be another video from this guy:
