Author Topic: Sex on a stick: Clear resin encased amp  (Read 12042 times)
Offline olsenn
Re: Sex on a stick: Clear resin encased amp
« Reply #1 on: April 14, 2012, 11:38:28 pm »
I think soldering the pieces directly on to a copper wireframe and encapsulating it in resin is a bit much. A simple printed pcb in an altoids tin would have sufficed. Furthermore, I don't think that op-amp is the best; a AD8620 would probably be better.
Offline slateraptor
« Reply #2 on: April 14, 2012, 11:54:35 pm »
@olsenn: Picky picky. :P
That resin isn't thermally conductive, is it?
Offline Psi
« Reply #3 on: April 15, 2012, 12:18:24 am »
na the wireframe and clear resin is what makes it look cool.
oh right, you were joking.
Offline IanB
« Reply #4 on: April 15, 2012, 12:28:56 am »
It looks beautiful, but I do wonder about the required heat dissipation of the components? I think this construction method could only work for very low power circuits.
Offline olsenn
« Reply #5 on: April 15, 2012, 12:29:54 am »
It's a headphone amp... it won't get hot
Offline Mint.
  • Account is inactive now. Thanks everybody!
    • Personal Blog, Mint Electronics.
« Reply #6 on: April 15, 2012, 01:55:44 am »
That is amazing. However imagine trying to carry around something like that in your pocket ::)
Personal Blog (Not Active Anymore), Mint Electronics:
http://mintelectronics.wordpress.com/
Offline graynomad
« Reply #7 on: April 15, 2012, 04:27:53 am »
Not practical for various reasons, but one of the best things I've seen in a long time.
______
Rob
Graynomad, AKA Rob Gray www.robgray.com
Offline Psi
« Reply #8 on: April 15, 2012, 04:56:32 am »
Probably not the best thing to try and take onto a plane in the USA.  :)
Ironically if it was panted black so you couldn't see the components it would probably be fine.
Being able to see what's inside should be a good thing but somehow i doubt they would see it that way.
« Last Edit: April 15, 2012, 04:58:55 am by Psi »
Offline elliott
« Reply #9 on: April 15, 2012, 06:50:50 am »
It would still look very strange going through the x-ray.
Offline siliconmix
  • Country: wales
« Reply #10 on: April 15, 2012, 07:15:20 am »
i love it. ;D
Online amyk
« Reply #11 on: April 15, 2012, 07:36:58 am »
Looks very stylish, but if something breaks you're out of luck.
Potting an electrolytic cap sounds dangerous; they have vents for a reason.
Offline AntiProtonBoy
  • I think I passed the Voight-Kampff test.
« Reply #12 on: April 15, 2012, 08:22:32 am »
Hahah, missing the point much?
I probably wouldn't worry about that too much. I doubt those caps would build up enough pressure the blast the resin apart - worst case maybe crack it. But yeah, you are shit out of luck if something breaks down.
« Last Edit: April 15, 2012, 08:49:47 am by AntiProtonBoy »
Offline Bored@Work
« Reply #13 on: April 15, 2012, 09:18:13 am »
Not much different from a lot of modern consumer electronics.
Offline chrome
« Reply #14 on: April 15, 2012, 10:35:59 am »
Can somebody explain me why sex on a stick is supposed to be a good thing?
Sex is great.
Sticks are great too (I guess)
Having sex on a stick sounds probably the worst thing ever.
And the project looks nice but for this thing, where you basically have this in your pocket, it's a bit overdone, he/she should have made it smaller.
« Reply #15 on: April 15, 2012, 12:49:41 pm »
Nicely done, I have had similar amplifiers that were encased in resin ( made by OpAmp Labs) which were rather difficult to open to fix them. The steel case did not survive, and a lot of grinding and epoxy solvent eventually got the board inside out, enough to trace the circuit ( basically a LM709 with a output stage and little else really) and replace the 2 dead output transistors with new ones ( 2n2219 and 2N2905 wearing little heatsinks instead of the 2 plastic devices it had) and get it working again.
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #16 on: April 15, 2012, 12:58:57 pm »
Its an English expression "XXXX ... on a stick" means the XXXX is pleasurable and/or easy to obtain and often cheap.  It probably has roots from getting treats like hot dogs, candied apples, cotton candy, etc., "on a stick" from carnivals.
Sex is great.
Best Wishes,
 Saturation
Offline olsenn
« Reply #17 on: April 15, 2012, 01:32:24 pm »
If anyone is interested, here is a headphone amplifier that I put together; I've included the gerber files and eagle board/schematic files along with some other useful resources such as datasheets and photos.
I didn't have any dual pots at the time so this one doesn't include volume control in the device itself, but feel free to add it if you'd like. It sounds better than my JDS Labs Cmoy amplifier by a long shot, but I didn't bother with bass boost in this one... once again it is easy to add if you desire.
Download Link: http://www.freefilehosting.net/headphoneamp
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #18 on: April 15, 2012, 01:43:31 pm »
More specifically I think it's that "XXX on a stick" is an improvement on/better than plain old "XXX".
Day Job: Mostly LEDs
Offline koogar
    • Runaway Brainz Tech and Tinker Blog
« Reply #19 on: April 30, 2012, 12:39:03 am »
What a uninspiring comment.
maybe the cMoy will jump inside the tin after reading your comment  :D
and the use of which opamp is best is subjective.  ;D
It clearly states in the Analog Devices data sheet that the AD8620 should not be encapsulated  ;)
« Last Edit: April 30, 2012, 12:48:12 am by koogar »
Offline koogar
« Reply #20 on: April 30, 2012, 12:41:44 am »
@Mint
I never intended it for portable use as the plug on the wallwart would be harder to imagine in your other pocket  ;D
Regards
Rupert
Offline steve_w
« Reply #21 on: April 30, 2012, 01:32:36 am »
That stuff can be repaired, there was some stuff like that that I have worked on that was installed in an aircraft.
it was part of the flight controls and lived near the afterburner. The potting solved a lot of environmental problems, repair was difficult but not impossible.  The OEM made them as throwaway modules, but tightwad aussies said repair them so we did.
So long and thanks for all the fish
« Reply #22 on: April 30, 2012, 06:22:34 pm »
Yes, I know those modules. most common problem was the Socaplex sockets wearing out the pins from vibration, and getting so thin they would snap off in the socket, giving an intermittent pin. After around 20 pin changes the actual body of the unit would wear out and require replacement. A big pain as they were not the standard 19-9 keying, but were an alternate with the same basic part number, and were hard to order as most suppliers would only give the standard part without realising the special keying.
Offline M. András
  • Country: hu
« Reply #23 on: May 01, 2012, 06:07:57 pm »
where can you get this clear resin in europe? or any epoxy resin without an insane price
Offline koogar
« Reply #24 on: May 01, 2012, 07:20:22 pm »
I actually got it from http://www.mbfg.co.uk/casting-resin/1453.html
It was very reasonable I think I paid around £12 delivered for 500g of resin including the  catalyst  they also sell on Ebay
Regards
Rupert
