Yes, I know those modules. most common problem was the Socaplex sockets wearing out the pins from vibration, and getting so thin they would snap off in the socket, giving an intermittent pin. After around 20 pin changes the actual body of the unit would wear out and require replacement. A big pain as they were not the standard 19-9 keying, but were an alternate with the same basic part number, and were hard to order as most suppliers would only give the standard part without realising the special keying.
