Author Topic: Stock Electronic Image FAILS  (Read 228325 times)
Offline Delta
Re: Stock Electronic Image FAILS
« Reply #75 on: August 21, 2015, 11:46:06 pm »
Some soldering absurdity...
I also like to warm up my screwdriver before I work, it helps get the screws out faster!  :-DD
You are joking, but in some situation, heating a screws can help to remove it, especially if it was rusty
I did not think of that - have never done it. I suppose you would want to heat a rusty screw directly though, rather than heating the screwdriver first.
Heating a screwdriver is a good way to remove screws that have been painted over.  Not sure that happens much with electronics, but it's handy when you're doing a bit of work around the house or garden. :-)
Offline Bud
« Reply #76 on: August 22, 2015, 12:42:51 am »
Thermaltake Golden Orb CPU fan, a.k.a Gorb, was very popular back in...early 2000s ?
The girl must be married by now
Offline Bud
« Reply #77 on: August 22, 2015, 12:56:24 am »
Out of all the pictures posted, this kid is the only one who is holding a hot iron right!!!
Yep, she is
Offline free_electron
    • SiliconValleyGarage
« Reply #78 on: August 22, 2015, 02:04:43 am »
I had to.
I made my own.    :D
now post it mirror image. that's what the real pro's do ...
« Reply #79 on: August 22, 2015, 02:08:33 am »
You'd think Mythbusters would know better. but no.
They still have a shot in the intro sequence of someone trying to solder a high density BGA style pcb with a horrible iron and making an awful mess
whats with the short between pin 4 and 7 ?
Offline timofonic
  • Eternal Wannabe Geek
« Reply #80 on: August 22, 2015, 02:35:39 am »
That is also a Right Handed screw driver she is holding in her left hand.
What? I'm lefty and it's a pain in the ass with some stuff. I need to get used to a world against me!
Are there lefty screwdrivers?
Anyway, I found the joke...
https://en.m.wikipedia.org/wiki/Snipe_hunt
Are you referring to this or the sexual one? Well, she's nice if you like MILFs ;)
« Last Edit: August 22, 2015, 02:52:53 am by Circuiteromalaguito »
Offline Stonent
« Reply #81 on: August 22, 2015, 05:26:50 am »
I had to.
I made my own.    :D
You need to adjust your x10 compensation cap.
Offline Falcon69
« Reply #82 on: August 22, 2015, 06:13:44 am »
That's what the Torque Wrench is for.
And the Sharpie is to redraw the readout on the O-Scope.  :-DD
The hammer is there if things catch fire, He can beat everything to death.
Offline miguelvp
« Reply #83 on: August 22, 2015, 03:43:14 pm »
I thought he did that on purpose in reference to the batteriser.
Offline Red Squirrel
« Reply #84 on: August 22, 2015, 10:07:37 pm »
I am always prepared.   ;D
Offline ataxica
« Reply #85 on: August 22, 2015, 10:44:16 pm »
i think it might be dangerous to measure a high voltage disposable camera capacitor charger circuit when the DMM is switched to the resistance range...
At least this one is actually testing the resistor with it on the resistance setting.
Sent from my SAMSUNG-SM-G750A using Tapatalk
Offline rickselectricalprojects
« Reply #86 on: August 23, 2015, 12:47:35 am »
Oh i didn't see that
Oops
Offline VK3DRB
« Reply #87 on: August 23, 2015, 12:45:10 pm »
Amazing, Simply Amazing.
Long Long ago there use to be a television show called Hawaii 50, the main character had a habit of talking into the back of the microphone in his police vehicle. I use to get a good laugh out of that.
Hawaii Five-0. I remember one episode where they are doing to match a finger print to a suspect... the detective used a standalone 029 card punch machine, a card was punched and... voila! they got their suspect. Whenever an American show features random beeps as data is appearing on a monitor, or there is a WHOOSH sound as a spaceship is passing, it's time to walk out of the cinema and ask for your money back.
Offline Godzil
    • My own blog
« Reply #88 on: August 23, 2015, 12:58:13 pm »
BTW have you saw that each hot air gun they use are the Atten 858D+ ? (or a clone of it ^^)
When you make hardware without taking into account the needs of the eventual software developers, you end up with bloated hardware full of pointless excess. From the outset one must consider design from both a hardware and software perspective.
-- Yokoi Gunpei
Online tom66
« Reply #89 on: August 23, 2015, 01:22:20 pm »
In the Weird Al video "White and Nerdy", Al has a soldering gun, with a handle...
That always bothered me. Would be really hard to use.
Offline wagon
« Reply #90 on: August 23, 2015, 01:42:27 pm »
I just showed some of these fails to my missus, who is a student of graphic design.  I told her to let her class know to consult someone technical should they do 'technical' 'drawings'.  She tells me most of the population wouldn't pick the fails.  That's probably how they get away with it.
Hiding from the missus, she doesn't understand.
Offline Paul Moir
« Reply #91 on: August 23, 2015, 04:46:26 pm »
You can let it stop bothering you now:
http://www.princessauto.com/en/detail/35w-pistol-grip-soldering-iron/A-p3412426e
Perhaps if we were taught to write with pistol-grip pencils, we would find the other style is difficult?   :D
Offline redwire
« Reply #92 on: August 25, 2015, 04:14:44 pm »
From Bosch's BME 280 environmental sensor advertising.  Low humidity...
Offline sunnyhighway
« Reply #93 on: August 25, 2015, 07:06:34 pm »
I have no clue why the readings are off.
I really like this new solder wire dispenser, but these new lead free solder compounds takes ages to melt:
The following users thanked this post: BrianHG
Offline McBryce
« Reply #94 on: August 25, 2015, 08:19:16 pm »
It says "Relative Humidity" on the screen, so it's relative to some other reading that they made in a Sauna, Green house or somewhere else with higher humidity.
McBryce.
Online tom66
« Reply #95 on: August 25, 2015, 11:49:12 pm »
Relative humidity is a standard measurement, it doesn't go negative
https://en.wikipedia.org/wiki/Relative_humidity
Offline apis
  • Hobbyist
« Reply #96 on: August 26, 2015, 12:26:34 am »
Yeah it's the amount of water vapour in the air relative to the maximum amount at that temperature so it can't be negative. This is in contrast to absolute humidity which is simply the amount of water vapour in the air.
Offline McBryce
« Reply #97 on: August 26, 2015, 07:33:33 am »
Oh. Learnt something new there. Humidity isn't something I have anything to do with or ever have to measure.
McBryce.
Offline AF6LJ
« Reply #98 on: August 26, 2015, 02:35:53 pm »
Another classic fail that people who worked in commerical two way radio always laughed about was on the television series The Highway Patrol. The series was based on the California Highway Patrol back in the late 1950s. The main character would open his trunk to get something out, usually flaires or a shotgun.  In the trunk there was no T/R package for the radio he used.
This was long before dash mount radios, the box in the trunk should have been about 3 cubic feet, and should have been accompanied by the sound of a Dynamotor, since this was before transistors that could handle DC to DC converter service. (they didn't have large enough vibrators back then to handle the 35-40 amps those two way radios drew.
An old friend did police and fire equipment installations back in the fifties and they had to find a way to fit a second generator and a second battery.
Television is rife with all kinds of electronic fails.....
Sue AF6LJ
Offline ADC-1995
« Reply #99 on: March 29, 2016, 01:28:54 am »
I had to.
I made my own.    :D
Using the bread board is a nice touch....
