I always wondered how/if in Australia we have a heater, or clothes
drier or air-cond, running on 240v and drawing 15A, then on 120v in the U.S. then it must be
drawing 30-Amps!!?? That never sounded right??
And yes, outlets without 'Switches'?? Why??
If you are in the US and you have an heater in a room, (e-g- an electric stove), it will be powered via a ridicolus plug at 120 V. The plug will overheat and a fire will start, in the standard US home built with wood.
When I was in Seattle 20 years ago, I noticed a lot of firetrucks passing by, a lot more than was usual in Europe.
My US friend said: it's normal, Christmas is coming...
That is just wrong! I can't even imagine an oven or stove top that isn't running on 240V. A typical stove top might have 2 ea 3kW heaters and 2 ea 1kW heater for a total of 8kW, probably more. This would take at least 33 Amps at 240V and the typical circuit is probably 50A. Based on 80% usage of circuit breaker ratings, a 40A circuit would be too small so it's usually 50A. The clothes dryer is probably 30A at 240V. Well pump, pool filter, HVAC also run on 240V. I'm not talking about window mounted AC units, I'm talking central air and perhaps a 3200 square foot house.
Throw in a 1200W microwave, a 5 kW air conditioner, maybe a few kW for an arc welder plus, of course, the automotive EV charger and 20 kW wouldn't be a surprise. That's the reason most service panels are 200A. For a single family dwelling, 100A might prove to be too small. I know I missed (or misstated) some of the loads. It's a fact that people used to have me replace their 100A panels with 200A. I didn't like doing residential work but sometimes the people were friends of friends, that kind of thing.
ETA: I forgot to add in another 5kW for the oven!
The reason that the European countries have such low demand limits (the US has none, I have installed 400A residential panels) is that the system is underbuilt. What's a 'contract'. We connect to the utility (actually, they connect to us) and we use whatever we want. If our load is too high, and there is some legitimate reason, they will simply run a bigger drop and probably install a bigger transformer. They're in the business of selling electricity, not telling their customers that they buy too much.
When I had solar power (different house) an 8 kW array provided all the energy we needed. At the end of the year (known as settle-up), I owed the utility nothing for electricity other than a non-negotiable meter charge of $5/month. It's pretty clear that we exceeded 8 kW during the heat of the day but it all averaged out.
