Author Topic: What's this please? (Component Advice)  (Read 1235121 times)
Offline Fluxed Matter
Re: What's this please? (Component Advice)
« Reply #750 on: April 06, 2015, 11:10:16 pm »
If you only have added razor
http://www.monsterscooterparts.com/e21.html?gclid=CjwKEAjw3YipBRDL2bHhjLmFkQsSJADtzktjO3hCds_y860zdMfPcaHzeTRuTBO3rW07Ka4uVAkXMhoCLeLw_wcB
Discontinued:
http://www.monsterscooterparts.com/ract5wicomoe.html
miguelvp, thanks I found that all over the internet too. I don't want the harness I want just the connector at the end
Have a Great Day!
Fluxed Matter
Offline mswhin63
« Reply #751 on: April 07, 2015, 04:27:16 am »
Looks like a generic Automotive connector. I have seen loads of different varieties at automotive shops. Not good at online stores though.
Offline Richard Crowley
  • KJ7YLK
« Reply #752 on: April 07, 2015, 05:02:49 am »
By "connector" do you mean the whole white plastic shell?  Or just the metal contacts?
They look like ordinary "spade lugs" (or rather the female part that slips over the male spade lug.)
« Reply #753 on: April 07, 2015, 03:04:04 pm »
@mswhin63 I have checked a few of my local auto parts stores but most carry the GM type which is not the same. But I will check a couple more in my area. Thanks
@Richard Crowley, Yes the whole white plastic shell with the metal contacts.
Have a Great Day!
Fluxed Matter
Offline Excavatoree
« Reply #754 on: April 07, 2015, 05:05:41 pm »
Hi All. I am look for the name of this type of connector and where I can order it. Anyone know who makes it and what it is called?
Thanks for the help.
Fluxed
Could this be it?
http://www.te.com/catalog/products/en?q=0-0172132-1
Offline AndersAnd
« Reply #755 on: April 08, 2015, 07:50:20 pm »
Context is always helpful.
Sorry, I should have explained better. The connector is used in an electric scooter. I had it but some bastard stole the old batteries with the connector still attached. I have new batteries now but I want to get proper replacement it, and I guess I will also need the contacts too.
tsmith35 thanks for the link,  The R&R kit may be the ticket.
Chinese Scooter Parts Wiring Harness Kit Plugs Terminals 3 pin battery connector
http://www.ebay.com/itm/22143896476
This ad is for 4 pieces of 3 pin female battery connectors with the brass ends..buy multiple purchases and only pay 1 shipping fee..
« Last Edit: April 08, 2015, 07:53:36 pm by AndersAnd »
Offline AndersAnd
« Reply #756 on: April 08, 2015, 08:01:17 pm »
10 Sets X 3 Pin 6.3mm 3P Connector Terminals Scooter Moped EBike Controller ATV
http://www.ebay.com/itm/321508387956
Offline AndersAnd
« Reply #757 on: April 08, 2015, 08:05:59 pm »
Nylon Latching Connector Pair 3-pin 6.3mm 1/4" Male/Female 18-14AWG #E37C
http://www.ebay.com/itm/261494574193
« Reply #758 on: April 08, 2015, 09:52:57 pm »
Excavatoree and AndersAnd thank you both very much. That exactly what I have been searching for.
Have a Great Day!
Fluxed Matter
Offline odessa
« Reply #759 on: April 13, 2015, 12:34:01 pm »
Can someone identify these please ?
I think they are BY509 HV diodes, if so does the small purple ring on the indicate the anode ?
Thanks
When  I die I want to die peacefully in my sleep like my Grandad ... Not all shouting and screaming like the passengers on his bus.
Offline android
« Reply #760 on: April 13, 2015, 01:21:17 pm »
According to datasheet archive it indicates cathode...if it's really a BY509. Purple is an unusual color and its location on the wire instead of the body is also unusual so your guess is probably good.
Lecturer: "There is no language in which a double positive implies a negative."
Student:  "Yeah...right."
Offline odessa
« Reply #761 on: April 13, 2015, 01:32:48 pm »
That's great, thanks very much  :)
Offline nitro2k01
« Reply #762 on: April 20, 2015, 11:40:01 am »
Are there any common or less common diodes where the anode is marked with a band instead of the cathode? Marking the cathode is the usual standard.
Online Vgkid
« Reply #763 on: April 22, 2015, 04:40:40 am »
A connector about 1.93mm in diameter, I'm thinking mmcx male
Offline TSL
« Reply #764 on: April 22, 2015, 05:40:01 am »
That's an SMP connector, fairly typical for tiny on board RF these days.
http://www.digikey.com/product-detail/en/SMP-MSLD-PCS/ARF1594-ND/1012555
regards
VK2XAX :: QF56if :: BMARC :: WIA :: AMSATVK
Online Vgkid
« Reply #765 on: April 22, 2015, 04:42:49 pm »
Before you  replied i was thinking u.fl connector.
Did some more research, and the mounting pad size specs matches the u.fl.
« Last Edit: April 22, 2015, 10:58:57 pm by Vgkid »
Offline TSL
« Reply #766 on: April 22, 2015, 11:03:04 pm »
Oooh yes, that looks closer to yours, they look very similar to the SMP's.
regards
Online Vgkid
« Reply #767 on: April 22, 2015, 11:59:12 pm »
^^^ The micronometer clued me into it.
You know it is tiny when it is the same size as the tip on your soldering iron.
Offline nostromo
« Reply #768 on: May 05, 2015, 10:06:19 am »
Can someone help identify this power connector? It's used in Nokia Flex Power Distributor, I couldn't find it anywhere.
Offline electr_peter
  • Country: lt
« Reply #769 on: May 05, 2015, 10:16:30 am »
Stick wires in and clamp it down with screws? You can use wire with spade terminal to plug in directly.
  • KJ7YLK
« Reply #770 on: May 05, 2015, 12:30:25 pm »
It is not a commodity component. It is a custom part made for that unit. Either kludge a DIY replacement or get an exact replacement from Nokia.
Offline nostromo
« Reply #771 on: May 05, 2015, 04:25:32 pm »
Yes, probably a specially designed connector for that part.
Well... I'll have to improvise something...
Offline abigbell
« Reply #772 on: May 09, 2015, 04:03:23 am »
 :wtf: why I cant see anything, the image are blocked!
haaaaappy life in china, they block every thing. |O |O |O |O
Offline IO390
« Reply #773 on: May 14, 2015, 07:03:41 pm »
Well I'm totally and utterly bamboozled by this one. It's a SOT-89 package and I'm pretty sure it's a LDO. The pinout is 1: Vout??? 2: GND 3: Vin
The markings are "M1" on one end and "31" on the other. I've spent a while googling but haven't found anything. The output is connected to an LCD via the connector next door. Anyone else got any ideas?
Full size image:
Offline tautech
Avid Rabid Hobbyist
