Author Topic: Whats your Work-Bench/lab look like? Post some pictures of your Lab.  (Read 2317323 times)
Offline lukier
    • Homepage
Re: Whats your Work-Bench/lab look like? Post some pictures of your Lab.
« Reply #2425 on: November 13, 2016, 04:59:51 pm »
Poor CSA7404 chucked in the back. With such rat's nest of cables I would worry I'd short everything to everything and let the magic smoke out :)
Offline Falkra
« Reply #2426 on: November 13, 2016, 05:28:41 pm »
Correct. It's secret metrology precision hack to keep wires not falling out of the jacks ^-^
OK, I thought it was against some kind of humidity (but... the others had no q-tips). Thanks for solving that mystery. ;)
Offline TiN
  • Country: ua
    • xDevs.com
« Reply #2427 on: November 13, 2016, 05:38:08 pm »
Just shows how often I power it on. You got me.  :-[
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #2428 on: November 13, 2016, 10:16:44 pm »
That's a damned clever idea!!   :-+ :-+  Will have to add that to my bag of tricks!
-Pat
Offline bitseeker
« Reply #2429 on: November 13, 2016, 11:28:44 pm »
That's a clever lab hack.
What's the story with the 10kOhm foam on the upside-down 3458A? If you flip it over, do you get -10kOhm or 1/10kOhm? :-DD
Offline McBryce
« Reply #2430 on: November 14, 2016, 08:34:54 am »
Here pig's lab in today's condition...
Any particular reason why your HP 3458A is upside down? Won't the electrons fall out?
McBryce.
Offline VK5RC
« Reply #2431 on: November 14, 2016, 10:00:12 am »
What do you mean ? That is not upside down! The rest of the Lab is.  ;D
Re Q tips, after a lot of cleaning (old Tek) I realised at age 54 that the two ends are wound in different directions, one is left hand the other right hand, you have to twist in opposite directions if you want to stop them unravelling! Don't ask me how many hundreds it took me to realise this.  :palm:
Offline george graves
« Reply #2432 on: November 14, 2016, 12:30:39 pm »
Sent into Hack-a-Day.  Too clever not to share.
Offline TiN
  • Country: ua
    • xDevs.com
« Reply #2433 on: November 14, 2016, 02:00:05 pm »
Exactly to keep them in place, as magical ADC board is on bottom side.
Interested people about 3458 might want to stop-by this thread about that unit. Beware, and wear anti-voltnut mask while entering, or you can pick that virus too.
I'm just doing some testing and need access to ADC and AC boards. 17kg and size of these meters aren't very friendly to flip them very often.
:o
It's just as Qtips like you call them fit shrouded bananas perfectly, keeping wire inplace.
They are not metallic, so there is no additional thermal mass which could slowdown thermal equilibrium during microvolt-level precision measurements.
Also not abrasive, so they don't ruin connectors like the metal post would do.
Also they are cheap and easy to replace once become wasted.
But yea, that's another reason why I like binding posts on 3458A's, just so much easier to get good connection every time without jerking around cables. Before I got 3458 I was thinking "shrouded bananas! Great connector, nice and robust".
Foam to reduce air drafts, which cause thermal EMFs :) There is resistor under foam.
« Last Edit: November 15, 2016, 04:25:22 am by TiN »
Offline ez24
  • L.D.A.
« Reply #2434 on: November 14, 2016, 09:22:46 pm »
I wished I knew what was clever?
Offline tautech
Avid Rabid Hobbyist.   Come visit us at EMEX Stand #1001 https://www.emex.co.nz/
The following users thanked this post: ez24
Offline GasGas
  • Country: br
« Reply #2436 on: November 30, 2016, 07:48:15 pm »
This is a new bench you built recently. I have a repair shop for electronic electronics, such as plasma TV, audio equipment, etc.
Offline lewis
  • Nullius in verba
« Reply #2437 on: December 01, 2016, 12:50:36 am »
^^ Lovely deep workbench - like it.
I will not be pushed, filed, stamped, indexed, briefed, debriefed or numbered.
« Reply #2438 on: December 02, 2016, 06:35:35 pm »
More changes to the bench. As I've mentioned before when not working on a project the bench was occupied by my laptop. It was proving to be unworkable. Moving it every time I wanted to work on something was becoming a PITA. Plus if I wanted to access a document or search on line while working the laptop was unavailable. No more. The laptop has been permanently moved to a space previously occupied by a Linux PC. That PC has been moved to another desk.
Before....
Current....
« Last Edit: July 18, 2017, 04:00:10 am by med6753 »
Offline rx8pilot
« Reply #2439 on: December 02, 2016, 06:36:19 pm »
The new lab is coming together......
Before.....and after getting the room prepped.
Next phase, building benches, running cables, etc....
Offline nanofrog
« Reply #2440 on: December 02, 2016, 06:54:31 pm »
It's looking good Carlos.  :-+
steverino
  • Guest
« Reply #2441 on: December 02, 2016, 06:54:55 pm »
You forgot the electrical outlets!  :(
Offline ez24
  • L.D.A.
« Reply #2442 on: December 02, 2016, 06:56:27 pm »
This will  be interesting, especially seeing where the Keysight will end up.
Offline rx8pilot
« Reply #2443 on: December 02, 2016, 07:07:44 pm »
All the cables are going into cable trays that are being installed in a ceiling grid. I have to be flexible distributing not only electricity, but also data, compressed air, vacuum. These trays are awesome and allow me to put anything anywhere without having to put cables on the floor or cut into walls.
Offline ez24
  • L.D.A.
« Reply #2444 on: December 02, 2016, 07:15:59 pm »
I never have seen them before - I like them
steverino
  • Guest
« Reply #2445 on: December 02, 2016, 07:43:30 pm »
Too cool.  Are these typically used in data centers?  Where does one get them?
Offline rx8pilot
« Reply #2446 on: December 02, 2016, 07:50:10 pm »
Really anywhere there are cables or hoses. I have worked in a myriad of factories, data centers, and machine rooms. The concept is older than dirt. I got these from
http://www.cableorganizer.com/cable-trays/
https://youtu.be/LydLnMXnbj8
Offline ez24
  • L.D.A.
Offline PartialDischarge
« Reply #2448 on: December 02, 2016, 07:57:05 pm »
google rejiband, pretty much the standard in factories
Offline nanofrog
« Reply #2449 on: December 02, 2016, 07:57:42 pm »
Google "power cable tray".  ;)
