Author Topic: Whats your Work-Bench/lab look like? Post some pictures of your Lab.  (Read 2312928 times)
Offline Rbastler
  • Wörk Wörk
    • Rbastlers Blog
Re: Whats your Work-Bench/lab look like? Post some pictures of your Lab.
« Reply #2825 on: July 28, 2017, 07:50:53 am »
https://m.banggood.com/Fishing-Glove-LED-luminous-Men-Outdoor-Auto-Repair-Lighting-Artifact-Half-Finger-Glove-p-1064000.html?rmmds=search
I like the idea of such "Glove lights". I might just buy them for fun.
No need to wrap youreself into led lights [emoji14] But if you do, I recommend RGB :D
Sent from my A0001 using Tapatalk
http://rbastlerblog.jimdo.com/
Gamma spectrometer works. Now some yellow crystals need regenerating and testing.
Offline bitseeker
« Reply #2826 on: July 28, 2017, 10:32:40 pm »
Yes, lots of lights everywhere! The under-bench ones are also useful since the workbench depth allows for storage of repair queue items.
Offline jhenderson0107
    • Elk Engineering
« Reply #2827 on: August 15, 2017, 05:42:41 pm »
Replaced the closet with an electronics workbench in the den.  Fold-down table for solder/rework in the garage.
« Last Edit: May 28, 2023, 06:47:03 pm by jhenderson0107 »
Offline aargee
« Reply #2828 on: August 16, 2017, 06:26:49 am »
Nice kilt you've stuck to the wall!  :)
Not easy, not hard, just need to be incentivised.
Offline mtdoc
« Reply #2829 on: August 16, 2017, 07:05:02 am »
Nice gear - but no power supply?
Offline McBryce
« Reply #2830 on: August 16, 2017, 07:59:26 am »
I can see two Rigol DP832 PSUs on the left side of the first shelf. However, the tartan wallpaper would drive me nuts.
McBryce.
« Reply #2831 on: August 16, 2017, 09:50:54 am »
Perhaps adding some "Prilblumen" will improve?  ;D
And for those, who do not know what a "Prilblume" is:
The following users thanked this post: nugglix
Offline McBryce
« Reply #2832 on: August 16, 2017, 11:29:16 am »
Aaarrgggh, my eyes!! Make it go away!
McBryce.
Offline Rbastler
  • Wörk Wörk
    • Rbastlers Blog
« Reply #2833 on: August 16, 2017, 11:36:55 am »
My now finished "holiday lab". With a PM3251, a TS100 powered by a 16V laptop PSU, Fluke 8050A, SDG1025, PE1540. In the cabinet there is a Fluke 25.
Offline mtdoc
« Reply #2834 on: August 16, 2017, 12:26:49 pm »
Ah, just the edges. Well spotted!
The Scott in me loves the tartan. After all, if it's not Scottish, it's .... ;D
    • Elk Engineering
« Reply #2835 on: August 16, 2017, 02:37:01 pm »
...However, the tartan wallpaper would drive me nuts.
Helps distract me from those voices in my head.
Offline hwj-d
  • save the children - chase the cabal
« Reply #2836 on: August 16, 2017, 05:07:06 pm »
omg  :palm:
All german >50y remembers ...  :-DD
Offline hwj-d
« Reply #2837 on: August 16, 2017, 05:12:57 pm »
Some nice stuff in there  :-+
Offline 128er
« Reply #2838 on: August 16, 2017, 07:50:47 pm »
omg  :palm:
And the younger ones which have seen them on the tiles, in the kitchen of their grand parents ^^
Offline hwj-d
« Reply #2839 on: August 16, 2017, 11:44:11 pm »
omg  :palm:
The german answer to woodstock  ;D
Offline Sceadwian
  • Beware those that tell you the way the world is.
« Reply #2840 on: August 17, 2017, 01:19:21 am »
Here's a link to a few imgur albums of my current setup (will be changing in a move soon no idea what I'm gonna end up with overall)
http://imgur.com/a/Vt3eY
http://imgur.com/a/boAlI
A few other images under my profile of miscellaneous little projects.
-Because I be, what I be. I would tell you what you want to know if I could, mum, but I be a cat. And no cat anywhere, ever gave anyone a straight answer.-
Offline Sarajouksa
  • Country: no
« Reply #2841 on: August 21, 2017, 10:04:03 pm »
Have only been into electronics for a couple of years, but this is what my living room looks like right now,  in the middle of a project :D
Offline takahidehimself
    • Thorntwig Technologies
« Reply #2842 on: August 22, 2017, 06:59:59 am »
Linnmon, Omar, Helmer and a Surface Pro 4... Very similar to my man cave setup :)
Sr. R&D Electronics Engineer @ 33 4d 20 50 65 6c 74 6f 72 20 52 26 44
Electronics Designer @ Thorntwig Technologies
Offline JustSquareEnough
« Reply #2843 on: August 23, 2017, 01:39:47 am »
nice simple yet functional setup, i like it!
Offline gamalot
  • Correct my English
    • Youtube
« Reply #2844 on: August 24, 2017, 05:24:13 am »
Keithley 3706 system switch / multimeter  :)
ooops, this should be in the other thread, sorry  :(
Offline TheSteve
  • Living the Dream
« Reply #2845 on: August 24, 2017, 05:33:33 am »
FieldFox  :-+ :-+ :-+
VE7FM
Offline VK5RC
« Reply #2846 on: August 24, 2017, 10:48:29 am »
Mmmmmmmmm  FieldFox.  - don't like the price though. Nice set up jhenderson. :-+
 - but how come you guys' benches are so neat! Where are all your cables, connectors, adapters, cutters, solder and general stuff?
Offline little_grey
« Reply #2847 on: August 24, 2017, 02:20:57 pm »
well, this will be my work space...eventually.
i do need to think seriously about how to keep it insulated and damp free.
tough when its only going to be a 'wiggly tin' roof.
Offline nanofrog
« Reply #2848 on: August 24, 2017, 08:57:10 pm »
You might want to look into the following:
  • Rigid Foam Insulation, then cover with heavy duty plastic sheeting to seal out moisture. Not sure where you're located, but I suspect this would be the less expensive option.
  • DIY Spray Foam Insulation Kit
Install some wood strips directly to the brick in order to attach a wall covering (peg board sheet, laminate sheet, or sheet rock/drywall for example).
There's also paints/coatings that are made for sealing brick and concrete walls & floors that might eliminate the need for plastic sheet.
The following users thanked this post: little_grey
Offline little_grey
« Reply #2849 on: August 25, 2017, 11:24:48 am »
much my thinking at the moment.
first point is to get the windows and roof on.
my hope is to use board insulation on the roof as it will be easier to fit that way.
Then depending on costs glad the roof with a cavity for insulation to go into. but that is no small job.
nice to know i wasnt too far off.
(based in the UK BTW - nice and damp)
