Author Topic: Whats your Work-Bench/lab look like? Post some pictures of your Lab.  (Read 2344802 times)
Offline DTJ
Re: Whats your Work-Bench/lab look like? Post some pictures of your Lab.
« Reply #3300 on: February 05, 2018, 01:13:31 pm »
My bench...in need of some cleanup.
What's that type of big scope above the curtain rod?  :-DD
All those horizontal lines, it's got to be a logic analyser.
Offline AF6LJ
« Reply #3301 on: February 05, 2018, 01:24:18 pm »
Nice benches folks.
Sue AF6LJ
Offline Insatman
  • Country: ph
« Reply #3302 on: February 06, 2018, 03:27:28 am »
Thats an external monitor for my TEK784D oscilloscope which if you look close is on the bottom of that stack.   I have a replacement LCD screen kit on order.
Retired Pulsed Power Engineer/Physicist...now I just dabble in electronics
The following users thanked this post: hwj-d
Offline Insatman
  • Country: ph
« Reply #3303 on: February 06, 2018, 03:28:42 am »
Nope, TEK784D with waveform and FFT display active (Pink hashy line).
Online georges80
« Reply #3304 on: February 06, 2018, 05:39:41 am »
Joke seems to have missed - probably a language barrier.... Anyhow, they're talking about your airconditioner :)
cheers,
george.
The following users thanked this post: hwj-d, Insatman
Offline Insatman
  • Country: ph
« Reply #3305 on: February 06, 2018, 07:36:47 am »
cheers,
george.
Now that I re-read the post and see it's above the curtain rod rather than below I get it.....doah.... :P :clap:
Offline netdudeuk
« Reply #3306 on: February 06, 2018, 08:55:20 am »
Thanks for sharing. It looks like you have some homebrew stuff (with the keypad, for example).  What are they ?
Offline Insatman
  • Country: ph
« Reply #3307 on: February 07, 2018, 02:34:43 am »
There are two homebrew items with keypads in the picture.
One is a precision frequency reference based on a GPS (NEO 7 i think) receiver.  It is capable of output from 1Hz to 12MHz.  A PLL stabilizer is active between 4.6 and 11.7MHz to reduce the phase noise you get from these kind of sources.   It's all run by an Arduino Nano and has a built in frequency counter.   It was a fun project...my first using a PLL, and my first where I used an Arduino in a permanent project.
This project was inspired by one of Skulcom's projects but I added the PLL and an output low-pass filter.  Also the software was largely re-written but credit to Skulcom where credit is due.
The 2nd chassis is an electronic load.   This was also inspired by one of Skulcom's projects.  Major changes were made to the analog circuitry and software however.  The unit is working well in it's core functions but I am still tinkering with the software to make it work better for automated battery discharge testing and transient load testing.  Tested max specifications are 70VDC, 100W, 4A.
In the photo are also two homebrew pulse generators.  One is described here: https://www.eevblog.com/forum/projects/avalance-jw-charge-line-pulser-for-step-waveforms-~45v-out/msg1405898/#msg1405898.  It is a avalance charge line pulser with <600ps Trise.   The second pulser is a reed switch based device with an even faster Trise of approx 400ps.  It has adjustable output voltage but is not particularly stable as the performance of the reed switch isn't as good as I had hoped.  Still it's a nice testbed for future reed switch testing.
Also high in the photo are two homebrew precision current sources.  A 1A unit which can be dialed down to 10mA or so and a 50mA unit which can be dialed down to 50uA or so.   Both units have a full-scale calibrated position.  The 1A unit is accurate to +/-50uA after 5 min warmup.  The 50mA unit is accurate to +/-2uA.
There are more projects as well.  I've been busy this past year.
Offline bitseeker
« Reply #3308 on: February 07, 2018, 02:44:00 am »
Do you have a link or more info on the PLL part? I have one of those GPS modules waiting to be built into a frequency reference and it'd be great to add a stabilizer.
Offline Insatman
  • Country: ph
« Reply #3309 on: February 07, 2018, 04:03:43 am »
Here is the schematic of the as-built unit.  Hit me up with questions if you want.
Offline bitseeker
« Reply #3310 on: February 07, 2018, 06:58:10 am »
Thanks. That's pretty cool. I think I got how it all works. One question: Is P2 one of those 7-segment LED display frequency counter modules?
Offline Rémi
« Reply #3311 on: February 07, 2018, 11:05:11 am »
Lot of nice benches around here, I'm currently planning to build one with the help of a friend.
Here is a quick sketchup plan I made. I would be happy to have your opinion about my design, would you change something in terms of dimension, space between shelves etc.. ?
Thank you.
Rémi
« Last Edit: February 07, 2018, 11:25:48 am by Rémi »
Offline lapm
« Reply #3312 on: February 07, 2018, 11:23:29 am »
1.5 m width? Put horizontal bracing under the shelf's and desk, otherwise those shelf's will start sagging over time.
Electronics, Linux, Programming, Science... im interested all of it...
Offline Rémi
« Reply #3313 on: February 07, 2018, 11:32:38 am »
Yes the width will be 1.5m. Indeed I was thinking of building a frame for the desk and the two shelves. Something like in the picture below but with the bracings along the 1.5m dimension....
Offline nanofrog
« Reply #3314 on: February 07, 2018, 07:10:17 pm »
You could consider a bench built like the one in the image below (specifically the bottom half that makes up the frame for the table top). As per table bracing, just complete the rectangle just below the table top; front to back bracing won't be necessary IME. Leave the bottom framing as-is, as you'll be able to get a chair beneath it.
The following users thanked this post: Rémi
Offline Insatman
  • Country: ph
« Reply #3315 on: February 08, 2018, 02:43:21 am »
Yes...one of those cheap PIC based units I had lying around.  This one was nice because it went all the way down to 1Hz whereas the other cheap counters usually have a minimum frequency.   I think I paid something like $5 for the kit.
Offline Insatman
  • Country: ph
« Reply #3316 on: February 08, 2018, 02:57:25 am »
Another Design built using 2x4s and plywood.  The top is made from two pieces of 3/4" marine plywood laminated together for a solid bench.  The edges are painted for looks.  The entire assembly breaks into four pieces with just 4x  5/16" bolts for easier transport.  The width is 1" narrower than the door frame in my house and the length was chosen to fit the space.   The shelfs are made from 3/4" plywood and just sit on the top with a bit of rubber glued to the base for non-slippage.  Note the pockets on the underside of the bench for meters and other small items.   Finish is marine varnish.
Offline hamster_nz
« Reply #3317 on: February 08, 2018, 03:56:18 am »
I recently made this from three inexpensive hollow core doors (2 x 540mm + 1 x 900mm for the top), two strips of dressed wood and some castors. Works really well and is very inexpensive if you want a bench that is as long as a door is high.  ;)
« Last Edit: February 08, 2018, 03:59:35 am by hamster_nz »
The following users thanked this post: BillyD, Rémi
Offline ez24
  • L.D.A.
« Reply #3318 on: February 08, 2018, 05:26:24 pm »
Nice job
Offline awallin
« Reply #3319 on: February 11, 2018, 10:20:54 am »
A mere ~3months  ::) after moving to a new place I setup the lab-table again.
Ikea table 120cm wide and 80cm deep.
Top shelf on 40cm legs, 40cm deep.
HPAK E3640A powersupplies, 2-ch 62MXs-B 600MHz scope, SDG2042X siggen, HPAK 34401A and Fluke 177 DMMs, Olympus SZ51 microscope with LED ringlight, Hakko FA-400 and FX-888D, SR620 counter.
AC-outlets are now below the top shelf, but I think it's cleaner to mount them below the main table at the back.
Might build a wider (2-2.4 m?) similar lab table in the future.
The following users thanked this post: JustSquareEnough
Offline Gary350z
« Reply #3320 on: February 12, 2018, 12:03:17 pm »
Is the top shelf from Ikea? If so, do you have a name or part number? Thanks.
Offline awallin
« Reply #3321 on: February 12, 2018, 02:07:37 pm »
Nope, top shelf is a pine gluelam board from the DIY store, and the 40cm legs also. The legs had M8 adjustable feet which I removed and instead bolted the shelf from above to the legs with M8 countersink bolts.
Offline AF6LJ
« Reply #3322 on: February 14, 2018, 09:36:29 pm »
A new picture of the workbench and lab here.....
« Last Edit: February 14, 2018, 09:39:58 pm by AF6LJ »
Sue AF6LJ
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #3323 on: February 14, 2018, 09:46:07 pm »
Very nice, Sue.   :-+ :-+
-Pat
The following users thanked this post: AF6LJ
Offline Mr. Scram
  • Display aficionado
« Reply #3324 on: February 14, 2018, 09:46:15 pm »
The Mallet of Healing:
Persuasion +10
Magic smoke -5
Frustration -5
