Author Topic: Whats your Work-Bench/lab look like? Post some pictures of your Lab.  (Read 2337288 times)
Offline Psi
Re: Whats your Work-Bench/lab look like? Post some pictures of your Lab.
« Reply #4575 on: May 14, 2022, 11:12:14 am »
So many home labs are just full of more test equipment than seems usable.
Where as my lab is mostly full of production parts stock.
The following users thanked this post: Bobson, bd139
Offline Shock
« Reply #4576 on: May 14, 2022, 01:07:48 pm »
Depends what floats your boat, some people build their home labs up over decades and are into T&M (tits and muff Test and Measurement), experimentation, repair or electronics in general to support a radio or other hobby. Specifically to design, programming and assembly you have different requirements and repairing and servicing your own TE is also almost a hobby unto itself.
But you have a point, if you just brought a pile of stuff overnight for no particular reason you may have a compulsive problem that needs addressing. I don't personally get gear envy at all and it's a healthy place to be, but I'm also well setup to my specific needs and patient.
« Last Edit: May 14, 2022, 01:24:20 pm by Shock »
Offline PlainName
  • Country: va
« Reply #4577 on: May 14, 2022, 04:13:36 pm »
Perhaps your lab is set up to produce a specific product, so anything not aimed at that product is pretty pointless. A home lab may have seen vastly different things go through it over the years, so there could be a wider range of kit to suit. And I daresay some items would have been acquired for a specific purpose that hasn't cropped up again, or only get used every other year. For a production environment you'd probably hire the appropriate kit, whereas fixing up something off Ebay may be a lot cheaper.
Offline Wallace Gasiewicz
« Reply #4578 on: May 14, 2022, 08:53:38 pm »
Obviously Psi has not joined any TEA therapy group. However, there is always hope.
Psi, no insult intended, you are probably more sane that the rest.
Offline DL8RI
« Reply #4579 on: May 27, 2022, 07:36:40 am »
I guess, I do fall into that category?! And sanity was never an option....
My special interest is (very) high frequency stuff, so things that go into the two or three digit GHz range. So black magic in general. :)
That again needs a lot of general support electronics and a lot of TE that has to be repaired. And the latter opens Pondora's box on what stuff you will need (spiler: everything!).
Edit:
Sorry for the rotated images. Neither my phone, nor my pc, nor Instagram has an issue with that, only this forum here.
« Last Edit: May 27, 2022, 07:41:54 am by DL8RI »
The following users thanked this post: Smokey, Shock, Kean, HighVoltage, Howardlong, 4cx10000, capt bullshot, exor, bd139, NA5B
Offline Shock
« Reply #4580 on: May 27, 2022, 08:37:59 am »
That stack to the right of the monitor :o.
The following users thanked this post: SkyMaster
Offline jasonRF
« Reply #4581 on: June 12, 2022, 05:18:47 pm »
This is my desk in our attic.  I mostly do analog audio so can get by with basic gear like the cheapest model Picoscope.  I use the Scarlett Solo to measure distortion, and a tinySA to sniff-out oscillations (example in screen is from an opamp missing a bypass cap).  Soldering and construction are done in our garage 3-floors down.  I need the exercise anyway…
Jason
The following users thanked this post: exor
Offline PushUp
« Reply #4582 on: June 13, 2022, 02:04:27 pm »
Edit:
This happens, when people rely on "default settings", which is never good to accept, without having a closer look at all the settings manually; the picures are shown as if being rotated already, but in reality they are not!
As a linux user I don't say anything about windows' internal picture-software, which you probably use, as nothing is able to compete with the free XnViewMP-Software 1.0, where you have the option to do anything you like...
https://www.xnview.com/en/
XnView: uncheck "rotate pictures concerning EXIF-alignment"
ACDSee: uncheck "rotate JPEG- and TIFF-files automatically based on EXIF-alignment"
I always rotate my pictures myself, which is very easy to do with ACDSee on a windows PC or XnView on a windows and/or linux PC. With XnViewMP you are able to manipulate the settings the way, that it looks like an ACDSee-Clone, which is simply perfect - yes, it takes a while, but let me know, when you need some help to do so...  ;)
Cheers!  :)
The following users thanked this post: mcinque, jasonRF
Offline nfmax
« Reply #4583 on: June 13, 2022, 07:58:07 pm »
Edit:
Is that a B&K 2425 AC voltmeter I see on the shelf there? I have a one of those been in my repair queue since 1999. It's finally in bits on the bench: the negative power supply is u/s, but I need to trace the circuit out to progress further. B&K notoriously never provide circuit diagrams
« Last Edit: June 13, 2022, 09:08:33 pm by nfmax »
Offline SilverSolder
« Reply #4584 on: June 13, 2022, 08:59:08 pm »
You can look at images,  and rotate them, and crop them, in the Microsoft Paint app, which is extremely easy to use.
Offline andy3055
« Reply #4585 on: June 13, 2022, 09:08:34 pm »
It is a jpg. Just let it open on Microsoft photo viewer that is in Windows by default and rotate it. Not necessary to have any special software at all.
« Last Edit: June 13, 2022, 09:12:08 pm by andy3055 »
The following users thanked this post: TiN, xrunner, mcinque, 4cx10000, NA5B
Offline andy3055
« Reply #4586 on: June 13, 2022, 09:13:12 pm »
Very impressive stuff you got there!
Offline jasonRF
« Reply #4587 on: June 14, 2022, 04:17:18 pm »
When I have posted from my computer the images have always been correct, but somehow I screwed it up when I posted from my phone and they came out sideways.   Given my technology skills, I should move photos to the computer and post from there in the future.
Jason
« Reply #4588 on: June 14, 2022, 08:43:50 pm »
Jason
I do but primarily to put them through an editor to reduce their size as a nod to times when we had slow internet that some poor souls might still have.
« Reply #4589 on: June 14, 2022, 09:30:21 pm »
To note, jpeg rotation is a shit show. There's a rotation metadata chunk which some software respects and some doesn't at edit time and view time. When you rotate stuff, some software actually rotates the image pixels and some just changes the metadata. This leads to all sorts of non-determinism and having to hold your laptop like a retard just to work something out  :-DD
Offline purfield
« Reply #4590 on: July 25, 2022, 07:51:05 pm »
Here's a shot of part of my home lab while I'm in the process of rearranging things.  Highlights not shown in the picture include some LPKF equipment, Universal Laser Systems CO2 laser cutter/engraver, Faxitron DX-50 X-Ray, and Haas OM-2A CNC mill.
The following users thanked this post: daqq, Zucca, Kean, bd139
Offline Zucca
  • EE meid in Itali
« Reply #4591 on: July 26, 2022, 02:28:49 am »
Faxitron DX-50 X-Ray, you bastard!  :-*
The following users thanked this post: purfield
Offline coppice
« Reply #4592 on: July 30, 2022, 07:34:50 pm »
In general image file metadata is a shit show.
Offline Jester
« Reply #4593 on: September 14, 2022, 12:46:16 am »
I tweak my setup every once and a while. The stack is a bit narrower now, so easier to reach the instruments on RHS. I Added the BK9130 triple power supply and the 3 vertical power outlets to fill the gap adjacent to the two DC loads
I'm going to part with the two B&K instruments on top; DC supply and load (more than 3 DC loads might be encroaching on TEA territory);-)
The mess on the bench on the RHS mostly out of view
The following users thanked this post: xrunner, edavid, trophosphere, Kean, 4cx10000, richnormand, capt bullshot, exor, bd139, NA5B
Offline strawberry
  • Country: lv
« Reply #4594 on: September 14, 2022, 04:11:04 pm »
only some test gear displayed (different location)
33120a 34401a WSD80 WS80 4328a pm5770 fluke1507 34970a fluke80k40
Offline wn1fju
« Reply #4595 on: September 17, 2022, 04:24:18 pm »
OK, I can't resist...  Here is a montage.
Everything works (almost all of it repaired/restored by me).  Obviously, most of it is left unplugged and unused until I really need it.  Everything is accessible from the rear for power and cable attachments.  As one gets closer to my little work area (bottom center of photo), that's where the frequently used pieces are.  Approximately 45 things are permanently plugged into AC power, but obviously I dare not turn them all on at once!
Believe it or not, all of this fits in a relatively small corner of my basement.  Have fun identifying all of the pieces from the photo - I'll bet a lot of you have many of them too.
The following users thanked this post: edavid, bd139
Offline paulca
« Reply #4596 on: September 28, 2022, 02:22:53 pm »
Is there a monthly prize for the most messy work-bench/lab?
I took these because, enough is enough.  I've started sneezing and I've be joined by a few small flies, suggesting the rule about "no organics in the bin" has been broken!
Offline paulca
« Reply #4597 on: September 28, 2022, 02:24:02 pm »
Offline zitoune
  • Country: sg
« Reply #4598 on: October 02, 2022, 07:56:47 am »
Hello,
Some picts of my little bench.
1604779-0" alt="" class="bbc_img" />
1604785-1" alt="" class="bbc_img" />
1604791-2" alt="" class="bbc_img" />
« Last Edit: October 02, 2022, 08:02:29 am by zitoune »
The following users thanked this post: edavid, trophosphere, 4cx10000, BU508A, Mortymore, exor, Detlev
Offline Voltage
« Reply #4599 on: October 04, 2022, 04:49:37 pm »
Noob here, I just finished building a double decker electronics work bench and was going to build the simple little stand to put all my test equipment into. I have all new stuff in boxes and waited until my last purchase so I have all the dimensions so now I can start. Of course after finding this topic I had to register as there are so many options which is of course, messing with my plans a little. I think I will just do the small bookshelf approach for starters as I m somewhat a noob and my projects will be more hobbyist in nature. I have a Rigol DS1104Z-S Plus 100 MHz Digital Oscilloscope, an OWON XDM5031 DVM, and a  couple of DC power supplies (one switching, one linear) so far as the rest is soldering equipment and a trinocular scope. The bench is 32" deep and the lower layer is for electronics and the upper for 3D printing. I added a pegboard on the bottom layer but some of it will be covered by parts bins etc. The bench is so big (8 feet long) that I can't even get the whole thing in a pic from the doorway walking into the ex-garage. Here is a pic of where I am at: It was a lot of work and it weighs in at a ton :)
« Last Edit: October 04, 2022, 04:51:18 pm by Voltage »
