Author Topic: Whats your Work-Bench/lab look like? Post some pictures of your Lab.  (Read 2324908 times)
Offline Deathwish
  • Country: wales
Re: Whats your Work-Bench/lab look like? Post some pictures of your Lab.
« Reply #1600 on: December 01, 2015, 09:40:31 am »
The DSO is under the bench - Difficult place to view it? But you smoke matches?
McBryce.
Nothing wrong with that , I see a toughened glass pane inserted into the desk and room to get a hand under that to use controls in my head.
Electrons are typically male, always looking for any hole to get into.
trying to strangle someone who talks out of their rectal cavity will fail, they can still breath.
God hates North Wales, he has put my home address on the blacklist of all couriers with instructions to divert all parcels.
Offline McBryce
« Reply #1601 on: December 01, 2015, 10:40:26 am »
Mr. McBryce,
I roll my own and when the lighter fluid runs out, the matches save the day, but you can go through a box quickly.
That scope is so deep that it had to go under the bench and was a back breaker in both senses.
Peter
Yes, it's just that in the picture it looks like the ashtray is full of matches, but no cigarette butts.
McBryce.
Offline TerraHertz
    • It's not really a Blog
« Reply #1602 on: December 01, 2015, 11:03:40 am »
Here's my mess after an all nighter...
A 10-keyless keyboard, an old Nokia phone, a Tek 7000 rackmount scope, old tower PC... are you my long-lost brother?
Offline purpose
« Reply #1603 on: December 01, 2015, 11:17:32 am »
Quite possibly... my old dad did have a bicycle.
Offline Radio Tech
  • KC4UMO Buddy
    • Hobby Forum
« Reply #1604 on: December 01, 2015, 12:15:50 pm »
Looks about right for an all-nighter to me.
My shop looks like I pulled an all month long project.
Stuff torn down waiting parts on the bench:
2 hand held transceivers
3 solid state HF transceivers
5 tube transceivers
2 Oscilloscopes
1 signal generator.
I got to get busy
Plenty of YouTube material :)
Offline AF6LJ
« Reply #1605 on: December 01, 2015, 01:50:11 pm »
5 tube transceivers
2 Oscilloscopes
1 signal generator.
I got to get busy
Please Do I am running out of good things to watch.....
My bench is in gridlock for a couple of weeks while I work on a radio club project...
Sue AF6LJ
Offline PA0PBZ
« Reply #1606 on: December 01, 2015, 02:12:30 pm »
Offline AF6LJ
« Reply #1607 on: December 01, 2015, 02:28:32 pm »
Thanks...
Something to watch while I wait for the next installment of Road Kill.
Sue AF6LJ
Offline Radio Tech
  • KC4UMO Buddy
    • Hobby Forum
« Reply #1608 on: December 03, 2015, 02:53:46 pm »
If all goes well I may have 2 uploaded this weekend. And I feel the same way. Some repair vides I have watched twice or more.
Try this: https://www.youtube.com/user/MrCarlsonsLab/videos
I like his videos. Does a good job.
Also Peter TRXbench does some nice repairs.
Cannot add his channel here at work. YouTube blocks.
I did  a bit of redesigning my main bench yesterday.  I use this one the most out of all 4. But it was not deep enough with the 12 inch shelf . So I moved the section out and added 12 inches to the rear. Now have 32 inches of bench space. Also added a 32 inch monitor directly behind the bench. Don't know if anyone ever looked at schematics from Kenwood. This monitor helps! Here is a peek.
Offline AF6LJ
« Reply #1609 on: December 03, 2015, 03:37:20 pm »
Cool...
Sue AF6LJ
Offline Richard Head
« Reply #1610 on: December 04, 2015, 05:36:38 am »
With the ubiquitous HP8640 sig gen. I wonder if you've had broken gear issues with it also?
Offline GreyWoolfe
  • NW0LF
« Reply #1611 on: December 04, 2015, 01:43:55 pm »
Radio Tech, I have monitor envy.  I only have a 22" on my bench :palm:
Offline Radio Tech
  • KC4UMO Buddy
    • Hobby Forum
« Reply #1612 on: December 04, 2015, 04:28:30 pm »
Sure did, I had to repair mine when I got it. I chose to repair my gears instead of finding the guy that makes replicas.  My first 3 YouTube videos is on the 8640B.
# 001, 002, 003
https://www.youtube.com/channel/UCHJpeSrEjtVk1YtRU3FrpQQ/videos
For some reason video #004 did not record. It showed how I took the broken gears and glued them back together. I used a backing plate to reinforce the gears made out of a piece of perf-board. I then aligned the gear in my milling machine. Put the brass insert on a mandrel and heated it. Was able to put the insert back into the gear dead center and after it cooled there was no chance of it coming back out.
Note: what causes the gears to crack in the first place is over time the material the gear is made of shrinks. The brass insert does not shrink. With the set screw hole in the gear this creates a weak link and is where the gear breaks at.  If you glue the gear back together you can no longer install the insert since the hole is now undersized due to the shrinkage. This is why I heat the insert and force it back into the undersized hole.
Very time consuming but works fine.
I hear you  :-DD
But even 22 inches is better than most standard PC monitors. When I went to 32 inches things became much clearer.  :-+
Offline AF6LJ
« Reply #1613 on: December 04, 2015, 04:45:35 pm »
That is so common I wonder if someone has made a replacement..
Sue AF6LJ
Offline Radio Tech
  • KC4UMO Buddy
    • Hobby Forum
« Reply #1614 on: December 04, 2015, 05:25:42 pm »
Mr Hoffman shows how to cast replacement gears here:
http://conradhoffman.com/HP8640B_gears.htm
There was a guy on Ebay selling casted gears at one time. Although I have not seen a listing for quite some time now.
I am still thinking about searching for another 8640B to restore. I do not want to tear mine back down again. So if I can ever find another at a reasonable price I am going to try and duplicate the gears. Thinking about making them out of brass. One I get the pattern done I should be able to reproduce  a few sets.
Offline AF6LJ
« Reply #1615 on: December 04, 2015, 06:04:04 pm »
That would be a good deal, that's my all time favorite signal generator, used them hundreds of times. I haven't owned one just yet.
Sue AF6LJ
Offline jmsc_02
« Reply #1616 on: December 04, 2015, 06:18:18 pm »
Just I've finished my workbench. Total cost: Around 150€.
A little pic, before put all the instruments:
i am doing a great effort to get my english plugin up and running, but it has its bugs and "zero days" fails so please, help me to improve it!
Offline Radio Tech
  • KC4UMO Buddy
    • Hobby Forum
« Reply #1617 on: December 04, 2015, 07:07:37 pm »
Yes, I love the 8640B. Very solid generator and fairly easy to work on.  Got mine for 100 bucks non working. When I emailed the seller the next day telling him it was working I could tell his heart sank.
Nice start  :-+
Offline TerraHertz
« Reply #1618 on: December 04, 2015, 09:48:54 pm »
Ah ha! I have a nice chart recorder with gears broken for the same reason - plastic shrank, brass core did not. I've been looking for a solution other than setting up to machine new all-brass gears - which I could do but too lazy.
Heating the brass bit and forcing it in while centered on lathe did not occur to me. Thanks!
What did you use to glue the fractured gear? It's nylon isn't it?
Offline Radio Tech
  • KC4UMO Buddy
    • Hobby Forum
« Reply #1619 on: December 04, 2015, 10:10:48 pm »
As you know it is practically impossible to glue nylon together. This is due to it's thermal properties and is a very slick substance. But this can be beat.
All in preparation. You have to rough up the two parts with sand paper. Then I drill several tiny holes in the part. As many as possible. Now you have something for the glue to adhere to. Clean the gear with ISA. I used Quick-Cure 5 minute epoxy.
There is also a glue called "Liquid nails" that works pretty good.
« Last Edit: December 04, 2015, 10:15:04 pm by Radio Tech »
Offline TerraHertz
« Reply #1620 on: December 04, 2015, 10:28:41 pm »
Sure do! Most times when I have no alternative to 'fixing' a broken nylon part I use splints and rivets. Lots of small brass pins...
Some types of plastic can be heat-welded, using a soldering iron and some scrap same-type plastic bits.
ISA? Did you mean IPA - Isopropyl alcohol?
Also the rubbery contact cements can work for low stress large area joints on non-stickable plastic.
Offline Radio Tech
  • KC4UMO Buddy
    • Hobby Forum
« Reply #1621 on: December 05, 2015, 12:02:36 am »
Yes, Don't know why I typed that for. Brain fried for working on a TS-904 all day I guess.
That's good to know. May try that some day.
Offline Smokey
  • Not An Expert
« Reply #1622 on: December 05, 2015, 01:49:11 am »
That reminds me of an erector set.  Is it stable?
Offline FireFlower
  • Wish had a cabin in Lappland
« Reply #1623 on: December 05, 2015, 03:53:57 am »
Looks dangerous  :scared:
Offline jmsc_02
« Reply #1624 on: December 05, 2015, 12:15:50 pm »
Nice start  :-+
Thank you! I hope to enjoy it and fill it with dangerous prototypes.
It's made using parts of metallic (steel) shelves. It can hold my weight (90kg ~ 200lb) safely but yes, needs extra support to make it definitely stable because actually it's a little stagger.
https://www.google.es/search?q=metallic+shelves
haha... Don't be scared, man. The work bench is ugly but not dangerous. I need to buy some cable conduit to hide all the power cables (I hate to see a mesh of cables around the top table). and the structure is earth grounded (not neutral).
« Last Edit: December 05, 2015, 12:31:49 pm by jmsc_02 »
