Author Topic: When you need another pair of hands when soldering....  (Read 1087 times)
Offline BrumbyTopic starter
« Last Edit: December 08, 2018, 11:36:11 am by Brumby »
Offline tooki
Re: When you need another pair of hands when soldering....
« Reply #1 on: December 08, 2018, 12:09:07 pm »
1. The world deserves to see Simone Giertz attempt a version of these.
2. Dear god, I can barely coordinate the limbs I already have. If I had to control a soldering iron with my foot like in the video, I'd probably end up stabbing myself in the eye with the working end…
The following users thanked this post: SeanB, TiN
Offline German_EE
« Reply #2 on: December 08, 2018, 08:15:46 pm »
When I feel the need for an extra pair (or two) of hands I just reach out for these:
https://www.circuitspecialists.com/content/98947/zd-10f-0.jpg
One of the best tools I have ever bought, fabulous for soldering together cable ends and of you make the base a bit bigger it doesn't tip over as often. Extra points if you connect it via a 1M ohm resistor to your ESD ground.
Warren Buffett
Offline GlennSprigg
  • Medically retired Tech. Old School / re-learning !
« Reply #3 on: December 10, 2018, 11:35:11 am »
I'm sure (?) most others can do it, but I was impressed recently, watching 'bigclivedotcom'
on Youtube recently. Soldering-iron in one hand of course, but wires held between thumb
and forefinger, while holding the solder with the next two fingers. MY old hands struggle now !!
See 9:25 in video...
Diagonal of 1x1 square = Root-2. Ok.
Diagonal of 1x1x1 cube = Root-3 !!!  Beautiful !!
