Author Topic: Why don't modern ovens keep their time after mains power failure?  (Read 6659 times)
Online xrunner
  • hp>Agilent>Keysight>???
Re: Why don't modern ovens keep their time after mains power failure?
« Reply #25 on: September 01, 2018, 12:42:04 am »
I guess some people look at it that way, but I don't see how it would help the regular consumer?
I've had two brief power failures in two weeks due to wind/weather and other than "oh great, the power went out", I don't know when it occurred or for how long. It's not really all that useful.
I was mainly joking but actually I have left the house for a couple of hours and come back when a small power failure has occurred. Everything is back on when I come home but I notice the oven clock is flashing, it does tell me that a power failure had occurred. Not very useful I admit but it does tell you something happened.
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #26 on: September 01, 2018, 01:12:20 am »
It's a power-failure notification feature. If you are gone from the house, you will know if a power failure happened. Important information easily displayed for you.
I agree with this concept, what if you went away for a few days and came home to discover that all of your expensive meat in the freezer had suddenly gone bad because the fucking power was off for a long period. Unless you have a security system which is configured to notify or report an AC failure then you would be none the wiser and perhaps put it down to a dodgy butcher.
If the utility company failed to give advance notification of a prolonged outage due to routine maintenance then the customer might be eligible for compensation. Winner, winner we are now having steak for dinner instead of fish fingers.   :P
Offline BrianHG
« Reply #27 on: September 01, 2018, 01:14:01 am »
IOT appliances, our future:
The following users thanked this post: Alex Eisenhut
Offline HalcyonTopic starter
  • Global Moderator
« Reply #28 on: September 01, 2018, 01:26:56 am »
Sure, but how would you know if the power went out for 15 seconds or 15 hours? Would you throw out all your food "just in case" ?
A small bag or container of ice with a hole in the bottom would be a far more effective indicator; If the ice has melted, your freezer got too warm.
Online xrunner
« Reply #29 on: September 01, 2018, 01:37:02 am »
Very simple (I just tried it to make sure ). The time when the power is restored starts where it left off. It remembers the time when the power went off and starts counting again at that point. So you can very easily see how many minutes or hours have elapsed by comparing the oven time to your correct time. So we know it remembers the time at the point of power failure - at least my oven does.
 :popcorn:
  • Cursed: 679 times
« Reply #30 on: September 01, 2018, 01:47:23 am »
You wouldn't know to check the defrost status of your ice indicator without first being alerted of the AC outage by the flashing 12:00 on your oven. Furthermore, a quick conversation with the neighbour would normally be a good idea after such an event to give a proper indication as to what happened, this is particularly important for those who have a hobby farm or rural weekend retreat and are not there permanently.
  • Global Moderator
« Reply #31 on: September 01, 2018, 02:16:45 am »
 :popcorn:
Ahh well done sir.  :-+
Offline Berni
  • Country: si
« Reply #32 on: September 01, 2018, 07:01:49 am »
There is a trick for that. Take a small plastic bottle, fill it up 1/4 of the way with water and mix in something colorful, put it in the freezer upside down to freeze and then turn it upright again. If the stuff stays in the top of the bottle then your freezer is fine, if you find the liquid in the bottom of the bottle then it defrosted.
But it does take a really long power cut before a proper freezer defrosts itself. It will reach 0°C fairly quickly but once it gets there the ice on the walls (Cause lets face it you been meaning to scrape it off 3 months ago) will start to melt first and hold the temperature at 0°C for as long as there is still ice there and due to how much energy it takes to transition water between states this makes it last a long time. Additionally modern freezers come with sub zero cold packs in the top . These packs are filled with a liquid that freezes a good deal lower than 0°C (Not sure what it is but even just salty water would work) so when the fridge fails that liquid starts to thaw out first and will keep the insides from even reaching 0°C for a very long time (over 12h)
  • Global Moderator
« Reply #33 on: September 01, 2018, 07:16:32 am »
The only issue I have with that is that your freezer (or rather the water in the bottle) might defrost just enough for the ice block to slide down the bottle but not actually fully defrost. You would want your "indicator" water to either flow into another container through a hole or escape completely into the freezer cavity, that way there can be no ambiguity.
Offline Berni
  • Country: si
« Reply #34 on: September 01, 2018, 07:50:02 am »
That is a feature that gives it "high sensitivity". As soon as the temperatures goes over 0°C it will turn a thin layer on the walls to water and let it drop down. Once its down there it will keep the bottle neck shape, but if continues melting then the bottle shape is lost and you get a varying level of flat liquid at the bottom. So the chunk dropping means it reached above 0°C and how much it melted out of shape on the bottom shows the duration of the fault.
To disable the high sensitivity feature you can throw in some thin rope or twine and let the ends dangle out when putting the cap on so that it grabs them. The twine gets bunched and tangled all trough the liquid before it freezes and keeps it from falling so the only stuff that makes it to the bottom is liquid.
The following users thanked this post: Halcyon
Offline SparkyFX
« Reply #35 on: September 01, 2018, 09:25:55 am »
My freezer´s interiors are covered in 1/2 inch thick ice that accumulated over time from humidity that got in when opened. If that melted i´d notice my wet feet before i want to check the clock.
Support your local planet.
Online xrunner
« Reply #36 on: September 01, 2018, 12:14:25 pm »
The built-in clock paradigm is fading out. The new Spectrum boxes don't have a clock any more nor a channel display.  :(
  • Global Moderator
« Reply #37 on: September 01, 2018, 12:50:08 pm »
That is a feature that gives it "high sensitivity"... *snip*
To disable the high sensitivity feature...
 :-DD Love it!
Offline Eka
« Reply #38 on: September 02, 2018, 07:19:07 pm »
Every appliance I've owned with some form of backup, from a pool filter timer to a standard oil heater has required repair or replacement of the backup source (battery or capacitor) long before the appliance might have reached the end of its useful life. The sort of intervention that had I not been handy with a soldering iron, would have seen it on the kerb and the wife off to buy a new one.
I'd rather have an appliance last >30 years and suffer the inconvenience of having to set the clock a couple of times a year.
A simple 0.1F super capacitor would handle most power outages, but it and it's charging circuit costs money. If kept cool it would also last at least as long as the power supply capacitors in the appliance will, unlike a lithium battery.
I've powered the RTC in a NXP ARM chip with a 1F super capacitor for 36 hours. I haven't formally tested longer power outages yet. At 6 to 7 days the RTC clock was still running, but had lost an hour. The exact same super capacitor would power a DS3231 RTC chip for 4+ days with temperature corrections still being applied and a week or longer without them being applied after the voltage drops to low for the temperature correction circuits to run. It did that without loosing any time. My charging circuit is in series a resistor to set a reasonable charging current, and very low leakage current diode to keep the supper capacitor from trying to power the 3.3 VDC rail after the power turns off. It only charges up to 3.0V, but that is enough to keep the RTC clock circuity running after the 3.3 VDC rail fails. My 1F super capacitor cost $5 in single quantity, and the diode cost about a dollar in single quantity. A 0.1F super capacitor would ride through most power outages I see. I get a few short 1 to 5 second long power outages nearly every thunderstorm, and a few 1 to 4 hour power outages every year. I live near the edge of the service area of a rural electric cooperative.
Online tom66
« Reply #39 on: September 02, 2018, 08:23:46 pm »
Good.  We have on screen displays for channel info, smartphones and watches for the time.  Why do we need yet *another* clock / indicator on a product, adding cost and power consumption for no apparently good reason?
Offline Mr. Scram
  • Display aficionado
« Reply #40 on: September 02, 2018, 09:53:37 pm »
I just noticed my microwave has a power outage indicator. It resets the clock all the same, so I'm not sure how useful that addition is.
Online xrunner
« Reply #41 on: September 02, 2018, 11:02:53 pm »
OK great idea - oh but wait - are you aware that the boxes don't ever truly turn off when the consumer turns them "off" with the remote Tom66? Like the one in the picture? See my thread here -
https://www.eevblog.com/forum/chat/cable-box-rant-related-to-power-consumption/
I've measured the power consumption. They use 13W when on and 12W (probably more like 12.5W) when "off". I put the "off" in quotes because the box isn't off by a long shot. And it's almost too hot to touch at the coax connector when it's "off" because the coax connector and cable is probably being used as a heat sink by design to save money, as one person suggested. The thing is chugging away doing it's thing on the backbone for the sole purpose of being ready to turn on just a touch faster for those impatient consumers. It's only off when the power plug is yanked out of the back.
So you want to reduce cost and power consumption? Why do they let it burn 12 to 13W 24/7/365 when the average consumer thinks they are turned off when they aren't?  Suddenly the clock and or cable channel indicator isn't such a big deal :-//
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #42 on: September 03, 2018, 09:50:36 am »
In the case of cable boxes  they're not always doing nothing - updating code and EPG for example. They could in principle have an on/off cycle to do this but synchronising that would get complicated - due to the huge numbers of them, anything that caused a tiny percentage of issues  would affect a significant number of customers.
Even issues like thermal cycling could become significant, so for reliability, leaving them always on apart for the display is probably the best approach.
Day Job: Mostly LEDs
Offline tooki
« Reply #43 on: September 03, 2018, 10:02:48 am »
I've powered the RTC in a NXP ARM chip with a 1F super capacitor for 36 hours. I haven't formally tested longer power outages yet. At 6 to 7 days the RTC clock was still running, but had lost an hour. The exact same super capacitor would power a DS3231 RTC chip for 4+ days [...]
The issue is that it wouldn’t be adding only a supercap. Oven clocks don’t have an RTC, they are mains-clocked. So adding only a supercap would allow it to remember the time, but the time wouldn’t advance! So at the end of the power outage, the clock would be slow, which is arguably worse than being blank. (A clock that’s 10 minutes behind after a 10 minute power outage that happened while you were out, and thus unaware of, could have you arriving at an appointment late.)
(Remember the European line frequency problem earlier this year? That’s when we all learned that ovens don’t have RTCs and are in fact line-frequency-clocked.)
Online RoGeorge
« Reply #44 on: September 03, 2018, 10:33:40 am »
  means it's time to check the food in the freezer.  ;)
Online xrunner
« Reply #45 on: September 03, 2018, 12:37:01 pm »
Well Mike I certainly respect your opinions here. But let's look at it this way - we were talking about saving costs of production, as the other person said
"yea eliminate the display parts". As I found out, the thing is not really turned off unless the plug is pulled. It uses 13W on and 12W "off". My Killawatt is really flickering between 12W and 13W so I'd give it 12.5W when "off". It's probably because of the points you raised.
So why do they even have an "off" function (button) on the box? Why spend money on an "off" hardware button? Why not just design it so the cable installer plugs it in and it's on all the time (which for all practical purposes it is anyway). The old boxes were the same way, they were always really on, except they had a clock at least for the people to use if they wishes.
I forgot this point last time I responded. When my 85 yr old mother was alive and messed up the settings of her cable box or TV she'd ask me to come over and fix it. She'd always say "Make sure the cable boxes (she had two) are showing the time!". Those were her clocks. Now you can come back and say "Your mother needs to get with it and get some other clocks!"
The point is, even though you and I can get along with technology changes some senior citizens want things the old way. They do not like changes even as small a thing as removing the clock from the cable box. When I asked the cable installer about the missing display he confirmed that many of their older customers did not like the display removed.
Point is, let's let little things be for a while longer until an older generation passes, before we save a few cents and remove little things like clocks they like to use from their lives. Is that really too much to ask?
Online NiHaoMike
    • Facebook Page
« Reply #46 on: September 03, 2018, 12:43:11 pm »
I recall Fran Blanche covered how one of the old time clock chips covered that issue - switch to a RC oscillator when running on batteries.
