Author Topic: Led tester  (Read 2694 times)
Offline robimarkoTopic starter
  • Country: hr
  • High Shool electronics hobbyst
Led tester
« on: July 20, 2014, 11:11:20 pm »
Hi.what do you think about this "Simple LED Tester"?
https://www.kickstarter.com/projects/955316598/simple-led-tester-every-lab-should-have-one-0
It is way too simple to cost that amount of money.
Basically 3V battery and pads for different led sizes
Offline Monkeh
Re: Led tester
« Reply #1 on: July 21, 2014, 01:02:35 am »
I can do that with my multimeter.. Except for some of the white LEDs, which won't work on that, either.
"Not soldering iron friendly", because 0805s and a small battery holder are so hard.
Offline Kdog44
Re: Led tester
« Reply #2 on: July 21, 2014, 07:20:38 am »
I think its a neat toy, but from a practicable  standpoint it is useless. Some suggestions to make it better (in my opinion)
- was credit card sized
- to make it thinner, use a smaller; custom metal coin cell holder and coincell.
- used all smd parts to make it easier to assemble.
- used some sort of a component holder for different LED sizes or made the contacts larger.
