Author Topic: Zero Mass Water  (Read 20156 times)
Online EEVblogTopic starter
Zero Mass Water
« on: September 17, 2017, 10:23:23 pm »
Not a crowd funder, but another solar powered water from the air project, but this one is shipping.
2L+ water a day claimed.
https://zeromasswater.com/
This guy reckons he's getting one installed:
« Last Edit: September 17, 2017, 10:25:34 pm by EEVblog »
Re: Zero Mass Water
« Reply #1 on: September 17, 2017, 10:42:17 pm »
Let's say it's got a 200W panel in it.
One of the best dehumidifiers on the market gets 1.83L/kWh
http://www.frigidaire.com/Home-Comfort/Dehumidifiers/FFAD7033R1/
That solar panel will produce roughly 1kWh/day over the year in say San Jose.
So if it's on par with good dehumidifiers then it's possible it may be able to get the claimed 2L/day under the best circumstances.
Will be interesting to see real world results.
Looks at the thing though, it's huge, and it costs $3700
Notice how they are careful not to tell you how much water it actually produces at their own HQ
Offline Avacee
Re: Zero Mass Water
« Reply #2 on: September 17, 2017, 10:48:27 pm »
In the Business Insider Puff-piece linked from their main page there is a claim of 5L/day
http://uk.businessinsider.com/zero-mass-solar-panels-2016-10?r=US&IR=T
Friesen* says that on average, one Source device can harvest 5 liters of water per day. Because of the device depends on solar power, he says, that number doesn’t vary too drastically between dry and wet climates — solar radiation is stronger in dry places where there are fewer water molecules in the air to absorb it, and water vapor is more prevalent in wet places where solar radiation is less intense.
* = Company CEO Cody Friesen, a material scientist and engineering professor at Arizona State University
and
Zero Mass Water boasts that one Source is able to produce enough clean drinking water each day to satisfy a family of four; however if all four members followed the 8-glasses-per-day rule, that family would wind up about 3 liters short.
But nowhere do any of the puff-pieces say how much water a family of four needs per day. It does mention a household in the US currently averages 100 gallons (note household so shower, washing machine, dishwasher, car wash, gardening, etc)
« Last Edit: September 17, 2017, 10:53:28 pm by Avacee »
Offline mc172
Re: Zero Mass Water
« Reply #3 on: September 17, 2017, 11:15:36 pm »
 |O What is wrong with these people?
Offline hayatepilot
Re: Zero Mass Water
« Reply #4 on: September 18, 2017, 06:25:43 am »
Those only make sense if you have a house far away from any water supply network and no rivers or lakes nearby, i.e. in the desert.
A very very niche application. But instead they decided to market it to those who are "worried about the water quality".  :palm: :palm:
Offline gonzo_the_great
Re: Zero Mass Water
« Reply #5 on: September 18, 2017, 08:27:59 am »
If it's water quality that is the issue, and you have sun, use a solar still.
If there is no ground water, then there is probably no useable humidity.
But if you want to make an easy $3700, this is the product for you! Assuming you are the seller.
Offline jpanhalt
Re: Zero Mass Water
« Reply #6 on: September 18, 2017, 09:23:02 am »
Source replied to the question about in what range of humidity it will work with saying it works in Scottsdale, AZ.   One interesting thing about Scottsdale is that it is at a relatively low elevation (1257 ft MSL) for Arizona and although it is further North than Tucson (elevation 2389 ft),  it is hotter and more humid.  Even places like Palm Springs, CA have lower humidity.  Why not supply real numbers?   Will it work outside in January in Minnesota?   ;D
Offline StillTrying
  • Country: Broken Britain
Re: Zero Mass Water
« Reply #7 on: September 18, 2017, 09:28:42 am »
I'm not sure he'll be a 100% independent tester. (that's the polite version  >:D)
"I've helped start a dozen companies, sold four of them, invested in more than fifty of my friend's companies, and am a mentor to many others.
If you're an tech startup in Austin or an email startup anywhere in the world, then I want to help you.
#austin #entrepreneur #startup #angel #investor"
https://about.me/joshuabaer
Online tszaboo
Re: Zero Mass Water
« Reply #8 on: September 18, 2017, 12:29:03 pm »
Lifetime of 10 years, 3700 dollar cost, that is 1 dollar/day, or 0.5 dollar/claimed liter. I dont think it is all that economical. Considering you need 2+ liters of potable water a day, you need to invest into 2 panels? Brita water filter: 6 EUR/month (yes, it became recently very expensive) or 0.06 cent per liter.
Before anyone asks, I cannot "just" drink the tap water here, it pretty much makes me sick.
Offline Mukrakiish
Re: Zero Mass Water
« Reply #9 on: September 18, 2017, 01:04:22 pm »
Heck, even here where I am, a Brita jug isn't sufficient for the tap water. We have to go get the RO stuff in the big jugs. $$$
Offline madires
  • A qualified hobbyist ;)
Re: Zero Mass Water
« Reply #10 on: September 18, 2017, 01:21:13 pm »
I wonder if all those water-from-air devices got major hygiene problems. Air carries all sorts of bacteria, spores and what have you. Most of that will happily flourish on the wet dehumidifier despite being cold. That means you would have to clean the device regularly and also have to add filtering. We got a proper dehumidifier for the winter garden and I see the nasty stuff building up with time.
Online thm_w
  • Non-expert
Re: Zero Mass Water
« Reply #11 on: September 21, 2017, 10:21:55 pm »
Scottsdale does have relatively low average humidity, but yeah without hard data it is meaningless to say it "works year-long".
http://www.city-data.com/city/Scottsdale-Arizona.html
« Last Edit: September 21, 2017, 10:41:14 pm by thm_w »
Re: Zero Mass Water
« Reply #12 on: September 21, 2017, 11:45:01 pm »
Brita filters are not going to sterilise water. Just take out some of the hardness. (At least the ones sold in the UK)
If the water has pathogens, just boiling it is the cure-all.
If it has contaminents, then you have to start looking at carbon filters, or distilation.
Online thm_w
  • Non-expert
Re: Zero Mass Water
« Reply #13 on: September 22, 2017, 10:03:26 pm »
Brita filters are not going to sterilize water. Just take out some of the hardness. (At least the ones sold in the UK)
If it has contaminants, then you have to start looking at carbon filters, or distillation.
Brita is a carbon filter though.
https://images-na.ssl-images-amazon.com/images/I/71Z7iT5WCbL._SL1300_.jpg
Online tszaboo
Re: Zero Mass Water
« Reply #14 on: January 12, 2018, 03:43:29 pm »
I've just read about this system again.
Apparently, it is a huge success. With the usual marketing strategy:
Make your target audience the clueless idiots.
It produces "raw water" which is apparently very popular in the USA. "Raw water" is sold at about 40 dollar per 2.5 gallon. And it is "pure".
Re: Zero Mass Water
« Reply #15 on: January 14, 2018, 10:50:54 pm »
Brita filters are rubbish when it comes to reducing hardness. I have worked on plenty of coffee machines that have been the victims of them.
Water purification and modification is a complete science and needs to done based on what the water source and what the intended use is on a case by case basis.
Offline Cyberdragon
Re: Zero Mass Water
« Reply #16 on: January 15, 2018, 10:56:26 pm »
They do now! In the middle of their page it says XXX Liters produced. (Currently 511) If that's their total for all systems thus far... :-DD thanks for debunking yourselves! A small neighborhood would use that up just taking a shower!
EDIT: I bet it rained more than that in those places this whole time!
« Last Edit: January 15, 2018, 10:59:06 pm by Cyberdragon »
*BZZZZZZAAAAAP*
Voltamort strikes again!
Online thm_w
  • Non-expert
Re: Zero Mass Water
« Reply #17 on: January 17, 2018, 11:45:38 pm »
They were on Ask This Old House, which is slightly disappointing because they are a decent source of home repair/DIY information (other than the gimmick/useless gadgets like this).
Why they would capture water on a house that has access to city water makes no sense. He went over the usual bullshit, and even implied it would be cleaner water.. Would have been much more useful to have a solar water heater, or use the solar panel to power the home.
« Last Edit: January 17, 2018, 11:47:48 pm by thm_w »
Offline Yansi
Re: Zero Mass Water
« Reply #18 on: January 31, 2018, 09:41:20 pm »
I think you can have a ground drilled for water, for as much as a couple thousand buck, can't you? Not sure what the drilling costs really are in the US.
Offline Gallymimus
Re: Zero Mass Water
« Reply #19 on: March 12, 2018, 02:49:02 pm »
What's funny is that this is actually legit technology and a legitimate company!
Offline nuclearcat
  • Country: lb
Re: Zero Mass Water
« Reply #20 on: June 06, 2018, 01:13:18 am »
Returning dead thread to life. One friend sent me link with this project, and a bit deeper study and seems this project is not totally "one more dehumidifier with peltier/compressor scam".
Take a look in one of creator patents: https://patents.google.com/patent/WO2016081863A1/en?oq=Cody+Friesen
So basically math equation dave is doing, related to basic dehumidifier model powered by electric solar panel, which is not highly efficient (due solar panels electricity generation efficiency), but here, seems they use large panels for heating, and probably if they absorb humidity from air to some sort of desiccant, overnight or morning(when air humidity also higher), they they can use sun heat to do desorption, and let's say evaporate this water and get hot, dense water vapor in chamber, which is much easier to condensate by just cooling it down to environment temperature. I guess in such case energy equation is quite different.
They say something about regeneration liquid, so it looks like even more advanced than i thought.
Still, operating cost of device is way too high.
Re: Zero Mass Water
« Reply #21 on: June 06, 2018, 01:21:28 am »
I reckon a rock and a bit of plastic would be as effective but it's harder to market a humble rock :palm:
Offline nuclearcat
  • Country: lb
Re: Zero Mass Water
« Reply #22 on: June 06, 2018, 04:09:33 am »
I dont think it is going to work at very dry places(30-35% humidity), where everything dried up during long rainless summer+.
This is also why traditional dehumidifiers also not very efficient in such conditions, as source of water, because dew point temperature is quite low with such humidity.
Offline hayatepilot
Re: Zero Mass Water
« Reply #23 on: June 06, 2018, 09:50:04 am »
This works very well on the beach where there is plenty of water but it is not drinkable.
Offline PlainName
Re: Zero Mass Water
« Reply #24 on: June 06, 2018, 05:30:56 pm »
Why would it not be drinkable? If it's condensate, what's polluting it?
