Author Topic: Audiophile network switch.  (Read 4712 times)
Offline Helio_CentraTopic starter
« on: November 02, 2022, 07:53:17 pm »
The following users thanked this post: MrMobodies
Offline MrMobodies
Re: Audiophile network switch.
« Reply #1 on: November 02, 2022, 09:35:45 pm »
This sounds great... by using components from audophile technology... it has achieved quantum leaps
in signal quality...
04:54
"Additional modification of the SE version:"
We ask for your understanding that we will not give you any details here :bullshit:
The sound quality of expectation cannot be judged blah blah blah.
Joke: Our opinion is right... if it doesn't sound as expect to you then your hearing must be wrong.
The enclosures are holo sealed and all modifications are covered with a resin compound.
All above reminds me a bit like of this:
Conductor Material:  U.S. laboratory grade precious metal alloys, proprietary formulation
12.33 I see it looks like that would have fitted without cutting the fins.
What if they cut the fins off to make it look like they put the crystal in there but then that isn't going to matter as they glue over the screws and not many would want to drill them out.
Another audiofool company at it as well:
https://dcs.community/t/upnp-disconnects/1705/33?page=2
Anupc Anup Aug '21
Oops, just realised that that Ansuz Ethernet Switch is in fact a modded D-Link DGS-108 6 - an unmanaged switch, but has IGMP Snooping that apparently can’t be turned off.
I’d return that switch and put the Cisco back in :neutral_face:
Ansuz Switch;
Dlink DGS-108 REV.C6
Offline Jr460
« Reply #2 on: November 02, 2022, 09:47:27 pm »
Switches can make difference in Pro Audio setups.   Dante for example.  Lots of articles about what switches to avoid.
https://usa.yamaha.com/products/contents/proaudio/docs/dante_network_design_guide/101_network_switches.html
Some list have brand names that have inconsistent packet delay times that are to be avoided.
All that said, a wrong switch and it will either drop the realtime auto streams or force you to configure for longer latency.   It will sounds the same.
Offline Ranayna
« Reply #3 on: November 02, 2022, 10:00:43 pm »
I remember another audiophool network switch. I need to check tomorrow evening if i can still find the images.
It was de-branded by the sellers, but they showed an image of the board. The switch was recognizably a modded small Cisco desk switch. They replaced a couple of electrolytics, added a few in the area of the voltage regulators, and they replaced the crystal of the CPU. Just looking at the pictures the seller themselves posted, and these were quite blurry, the shoddy soldering was quite obvious.
I think they sold it for more than ten times it's normal off the shelf value.
Offline MrMobodies
« Reply #4 on: November 02, 2022, 10:12:23 pm »
Looks like they had been doing this for some years and they used this generic one without a filtering cap.
https://audiophilestyle.com/forums/topic/44002-xxx-uncensored-us10-upgrade-for-aqvox-usb-power-supply-generic-wall-wart/
XXX Uncensored: US$10 Upgrade for Aqvox USB Power Supply = Generic wall wart?
By DM, June 14, 2018 in DAC - Digital to Analog Conversion
Posted June 14, 2018
After this upgrade:
Better ripple rejection (15dB more)
Better output filtering
Better transformer (better DC noise resistance)
They look 90% the same, but there are some differences:
a. The ZIP R4W005-100 uses Sharp PQ30RV21 regulator, the AQVOX uses PQ30RV11.
From here: http://www.sitsemi.ru/analog/pq30rv1_e.pdf
The PQ30RV21 is rated 2A and the PQ30RV11 is rated only 1A; also the PQ30RV21 has higher ripple rejection performance (15dB better), so the PS with the PQ30RV21 will have much less noise.
b. The ZIP R4W005-100 uses 6800uF filtering capacitor regulator, the AQVOX uses 4700uF only,
So the ZIP R4W005-100 will have less ripple on the output and can withstand current spike better, ~50% better.
c. The ZIP R4W005-100 has an extra filtering capacitor before the Sharp regulator
C(IN) in the schematic, the little blue cap in the photo; this increase performance and stability of the regulator.  It is recommended in the Sharp datasheet, but the AQVOX one doesn't have it.
d. ZIP R4W005-100 has a better transformer
The core of the ZIP R4W005-100's transformer is alternatively stacked, the AQVOX one is butt stacked. Usually butt stacked is cheaper to make and has lesser performance.
« Last Edit: November 02, 2022, 10:31:11 pm by MrMobodies »
Online SiliconWizard
« Reply #5 on: November 02, 2022, 10:55:12 pm »
There's a good reason for that and people will need to learn about Dante to understand what it is - distributed multi-channel digital audio with no world clock, so fully asynchronous, which is a pretty tough endeavor and requires strict timings and non-trivial algorithms to resynchronize/resample audio.
But it has almost nothing to do with what is shown here: a simple ethernet switch for basically streaming audio from a single source to a single destination with no mixing.
Online Monkeh
« Reply #6 on: November 02, 2022, 11:38:50 pm »
It's almost like using the wrong communication interface for realtime audio can cause problems for realtime audio.
The following users thanked this post: zzattack, Helio_Centra
Offline mcinque
  • I know that I know nothing
« Reply #7 on: November 03, 2022, 08:21:57 am »
sarcasm: well, it's a scam, but at least the modifications are state of the art.
Offline Haenk
« Reply #8 on: November 03, 2022, 08:27:42 am »
Funny thing: They state "Made in Denmark" - which is a lie. And certainly means a legal issue (competitive regulations).
Also lacking CE mark on the PSU, so it's illegal to sell in EU. Plus not matching manufacturer, so using the GS mark might be illegal as well.
Offline mcinque
« Reply #9 on: November 03, 2022, 10:29:08 am »
All is a lie: country of origin, mods done, improvements, EVERYTHING is a lie.
The fact is that these people often get away with it.
If I were D-Link I would sue them for using my brand name and packaging for something like that.
Also, in addition to the scam issue, I think that whoever makes that thing is really crazy since he also took the trouble to put "special" stickers underneath the glued part.  :-//
« Last Edit: November 03, 2022, 10:31:36 am by mcinque »
« Reply #10 on: November 03, 2022, 10:39:51 pm »
Maybe they are meant to stop radiation; protect your precious audio stream from the 5G and WiFi?
Offline mcinque
« Reply #11 on: November 03, 2022, 11:05:16 pm »
the only purpose they have is to show how crazy the person who conceived that thing is. It's not just a scam, I fear he really believes that.
The following users thanked this post: newbrain, MrMobodies
Online themadhippy
« Reply #12 on: November 03, 2022, 11:50:31 pm »
But be prepared to navigate at least 9 circles of hell whilst you try to get your desks,processors and amplifiers to all play nicely together.
The following users thanked this post: Helio_Centra
