Author Topic: Donut Lab alleged Solid State Battery launched at CES 2026  (Read 76708 times)
Offline shapirus
  • Country: ua
Re: Donut Lab alleged Solid State Battery launched at CES 2026
« Reply #150 on: January 30, 2026, 08:28:37 am »
Electric heating is okay for only as long as your power generation and distribution network is not bombed.
Once that happens, you understand that burning fossil fuels (and wood) is the best and most reliable solution. It must always be available at least as a backup, and you don't thoughtlessly keep electric heating as the only option. Unless you have tens of kW of on-site generation, of course.
Online Analog Kid
« Reply #151 on: January 30, 2026, 08:50:09 am »
Did someone set a bunch of bots on this thread for some reason? In that climate you use GSHP, you don't heat at COP 1 electrically.
COP 1? What is that?
I learned what GSHP stands for, didn't know before.
Any more acronyms you want to throw at us?
Offline Marco
« Reply #152 on: January 30, 2026, 09:07:19 am »
Natural gas gets pumped around by magical fairy farts?
As for prepping. Just set up lots of vertical solar and a big battery, superinsulate your innawood shack and leave the wood for when something breaks. Prepping is a rich man's hobby any way.
Offline shapirus
  • Country: ua
« Reply #153 on: January 30, 2026, 09:15:03 am »
Pumping gas requires much less energy than generating heat using electricity. It's feasible to do it with what little you have left and/or back it up using generators.
Blah blah. Come live here and see how things really work.
The following users thanked this post: TUMEMBER
Offline Marco
« Reply #154 on: January 30, 2026, 10:19:59 am »
Gas yards burn well.
That wasn't how it worked a year ago and not how it can work next year, it's not physics which limited/limits the targeting but military decisions.
The only defense for centralised infrastructure in total war with modern weapons is offense.
Offline TUMEMBER
« Reply #155 on: January 30, 2026, 01:02:23 pm »
:palm:
So how many of these nukes do you have in your inventory, "ready for use"? Because those "American ones attached to F-35s" don't count. The "Orange Emperor" will disable your operational codes, and you might as well attach concrete blocks to F-35s and attack Moscow. The deal with Putin has already been struck, wake up. So you're saying that winters in the Netherlands reach -30 degrees Celsius? So what, your shipping canals don't freeze over, and it's probably supposed to be that cold in Kyiv starting Sunday.
W życiu nie ma nic za darmo, są tylko różne formy płatności.
Wciąż płacimy okruchami własnego czasu.
Offline Marco
« Reply #156 on: January 30, 2026, 01:30:52 pm »
I'm saying modern medium range ballistic missiles and modern ground hugging drones/missiles can cripple gas distribution as easily as electricity. Electricity is harder to defend due to the HV grid, gas storage sites provide extreme centralisation and high value targets.
Deciding between these two on the basis of a total war is just silly. If it gets to that, you're just screwed.
Offline TUMEMBER
« Reply #157 on: January 30, 2026, 01:51:57 pm »
In the real world, decentralization of power sources (whether electric, gas, or solar panels + batteries) only provides "security" for "houses on the edge of urban areas." It has no real application for highly urbanized cities and "apartment complexes." How many solar panels + batteries can you place on the roof of an apartment building (weighting the ceilings) and still, a single drone missile will destroy the structure? It's economically viable to "hit" it even with a Kinzhal. However, "hitting" a single cottage in the countryside with panels + batteries with a Kinzhal is simply not economically or military strategic justifiable.
« Last Edit: January 30, 2026, 01:54:54 pm by TUMEMBER »
« Reply #158 on: January 30, 2026, 02:52:14 pm »
Seeing as no-one else can be bothered to answer your question: https://en.wikipedia.org/wiki/Coefficient_of_performance
Offline Marco
« Reply #159 on: January 30, 2026, 03:00:10 pm »
Gas pipelines being underground was not enough either in the end. Gas being out last and I hope promptly repaired in this specific case is not something to base energy policy on.
Some forms of seasonal storage could allow decentralised electricity generation even in cities. Chemical storage in iron or aluminium for instance. If you want the best disaster resilience, this would be it.
Offline Randy222
« Reply #160 on: January 30, 2026, 04:33:38 pm »
Re: Reply #145
Electricity has it's place. As example, getting natural gas to all the stoves in a hi-rise apartment building is monumental more difficult then amps going up. It's also less dangerous to not have natural gas pipes and tethers in every apartment in such building.
Everything electric is simply not feasible for some reasons.
Oddly, adding explosive & toxic gases into homes is real. Look at where AC 'freon' is moving to. It was R22 forever, then morphed over to other lower greenhouse impact like 410a (lower GWP), but now all that is being migrated to even lower GWP gases, which makes them more dangerous to the local people. If only the push was for better equipment, etc. R22 btw is more efficient than lots of other gases when ambient is above 100F.
I have not yet even look at the efficiency profile of these newer gases, could be way less just so they can lower GWP, but witut any regard as to how the electric needed is generated w/o offsetting the GWP savings from the new gases.
Mobile gear that carries batteries does appear to be the dominant application for batteries. Having a supercap 9v batt for my smoke detector would be the end of replacing the "battery" for detectors that have util power and the batt is just backup. It's year 2026 and the detectors (the wired ones) don't all come with a small Li-ion pack for bkup reasons?
Vehicles need ample kWh to be useful. To help on supply side I can see where a util can store power from solar and use that to help offset the demand that comes at night, but there still is a transmission issue that needs to be solved.
Example, util rund 1GW solar for 8hrs and captures that into local storage (batts, other). It;s the PowerWall concept. Then at night the util uses that at night when demand from recharging vehicles comes online. 1Gw for 8hr is 28.8B kJ.  That enough to completey recharge 133,333 60kWh  Li-ion batts. If the batts are doing the 50%-100% charge, then you can dbl it to 266,000 vehicles. Sounds all good and dandy, but can such 1GW solar/batt plant scale in numbers to be able to handle 1.14B conversions from gasoline/diesel to battery? Maybe, you would need approx 5000 such util systems just to cover existing vehicle numbers. Util power also needs to scale because it's estimated around 2.5B vehicles will be out there by 2025, hence util must scale up by 200% by 2050 if it were able to handle the the 1.14B of today.
I see obvious major hurdles that says this stuff simply cannot scale. Now the question becomes, does it need to? Why go after everything, probably best to just offset fossil fuels with solar and nuke power to lower the fossil fuels use down to a level that can be managed. This is more of a plausible scenario.
I think the science is well understood and should be used by real scientists to figure out the solution, vs stupid decision by dumb idiot govt leaders and activists.
I do believe Donut and Chery and anyone else who does R&D in graphene caps, HFCEV, fusion reactors, are doing so in leading-tech manner, this stuff is the future. But it has to come in natural progression.
Solar is interesting. Many years ago 1st Solar was creating product that was getting almost 50% more efficient every 5yrs or so. Not sure where they are at today but there's always a limiting barrier to overcome to get more, but the Sun is free energy, we just need to learn how to capture and use it.
In reality, humans have just about 2.1B years on Earth if they do not destroy themselves completely, or Earth gets hit with another huge rock impact. The Earth is totally gone in about 4.3B years from now. Time is ticking. The probability of self destruction or big rock is actually rather high. The clock still runs.
Offline Marco
« Reply #161 on: January 30, 2026, 06:00:03 pm »
Propane generally has higher efficiency, lower capacity. Capacity doesn't matter much.
Offline rteodor
« Reply #162 on: January 30, 2026, 06:27:06 pm »
If I remember correctly, geologists say that life on Earth has only about 1/2 million more years to go. The planet's core is cooling and as it solidifies it will stop spinning so the magnetic field will be gone and the atmosphere will be stripped away by the solar wind.
Ironically, putting greenhouse gases in the atmosphere delays this event but only marginally.
Offline Randy222
« Reply #163 on: January 30, 2026, 07:23:57 pm »
Cooling core? It's slow, and that problem (time) is many times bigger than Red Giant.
Also to note, there is a lifetime(earth) worth of useable heat energy inside Earth for human consumption, so why do we keep trying to make energy from problematic systems?
Apparently we can currently drill into Earth to about the depth needed to just about match operational temp(min) of steam turbines (200-400C).
The primary barrier to deeper drilling lies in the extreme temperatures encountered at relatively shallow depths. For example, the Kola Superdeep Borehole, the deepest hole ever drilled, reached temperatures exceeding 180°C (356°F) at its bottom.
So, just make a bunch of bore holes, pump water down, up comes steam. "free" clean eternal energy.
« Last Edit: January 30, 2026, 07:34:48 pm by Randy222 »
Online Analog Kid
« Reply #164 on: January 31, 2026, 11:00:50 pm »
Thanks. From the look of it I thought it might be referring instead to the annual UN climate-change confab, Conference of Parties.
I just loves it when people sprinkle their posts with acronyms (or initialisms) that they assume everyone else knows what they mean ...
Offline Bud
« Reply #165 on: February 01, 2026, 08:29:27 pm »
Industry called it a scam. Update from The Electric Viking
Offline LogicDudeTopic starter
« Reply #166 on: February 04, 2026, 05:58:20 pm »
WHOOPS!!!
Delivery has been postponed to late this year or the beginning of 2027.
Buddy, can you spare a dime?
Online sleemanj
  • Professional tightwad.
« Reply #167 on: February 04, 2026, 11:28:36 pm »
WHOOPS!!!
That has been claimed  to be a misunderstanding, they are saying if you order now, the queue extends to Q4 earliest...
https://insideevs.com/news/786388/verge-motorcycles-donut-labs-solid-state-battery-ev/
Update: "First orders received last year for Verge Motorcycles will start in Q1 as previously mentioned," Verge Motorcycles CEO Tuomo Lehtimäki told InsideEVs. "New U.S. orders received now can expect a bike delivery in Q4. To clarify, when anyone is ordering a bike now, that bike is landing at Q4 2026 if they are making the order today. There is a queue and orders made last year will be delivered first. Verge Motorcycles deliveries will start in late March and bikes ordered now will be delivered later this year as planned."
Offline Bud
« Reply #168 on: February 05, 2026, 06:10:17 am »
Bullshit. They announced the "battery" at CES on Jan 6. What last years orders they are talking about, especially so many of them that they would be unable to fulfill new ones until Q4?  /Bullshit.
Offline rteodor
« Reply #169 on: February 05, 2026, 08:32:46 am »
The battery yes, it was announced this year, but the Verge motorcycles were announced 2 years ago as far as I know with pre-orders coming in before CES.
i.e. the 'solid state battery' marketing campaign worked, pre-orders are piling up.
« Last Edit: February 05, 2026, 08:37:04 am by rteodor »
Offline Siwastaja
« Reply #170 on: February 05, 2026, 04:55:16 pm »
What a surprise!
But it can't be a scam! I mean, they are not getting any money, right? And they are delivering soon! It exists!!
Offline Electrodynamic
  • Power Engineer
« Reply #171 on: February 05, 2026, 05:34:01 pm »
My god it must be a scam and sounds like Tesla.
Didn't Tesla fake the self-drive feature by remote control then receive huge sums of money on advanced orders based on technology they did not possess at the time?. I mean without the self-drive feature it was just an average EV and few would have invested. Funny how that works.
As well, if I remember right countless people who ordered a Tesla EV were pretty mad they had to wait so long. The first cybertrucks were delivered four years after it was unveiled and advanced orders taken. Some waited even longer because of limited production and scheduling issues. As they say, there is a sucker born every minute. Imagine waiting four years for a vehicle then have the body panels falling off, oh the horror :-DD.
« Last Edit: February 05, 2026, 05:36:04 pm by Electrodynamic »
Offline Bud
« Reply #172 on: February 06, 2026, 12:21:03 am »
I am fairly certain they said in that commentary the last year orders for motorcycles with the new battery.
Makes me wonder who knew about the new battery last year. The thing smells BS.
And how many orders they got from last year that has crippled their production capacity until Q4?  Two ? Looks the right number to me judging on how comical the story is.
« Last Edit: February 06, 2026, 12:25:23 am by Bud »
Offline rteodor
« Reply #173 on: February 06, 2026, 09:43:17 am »
The motorcycle already made some buzz by winning a record for the longest distance traveled on a single charge by an EM (*). Plus reservation its only 100USD on their promo material for a 34900USD. I do not know if they may have other fees later. So its not hard to imagine that there were a couple more orders. Which can rapidly cripple their production especially if that production capacity is presumably very small.
To me SSB looks like a bad marketing stunt that is about to backfire soon. Announcing delays can be a strategy to deal with that.
*) my sources are my own memories from ./ and yt so I could be wrong on that.
  • Power Engineer
« Reply #174 on: February 06, 2026, 04:05:12 pm »
Bud
Compared to what?.
The Tesla cybertruck was delayed four years after advanced orders were taken, met none of the original specs and most agree is of inferior quality to what was promoted. BS my any measure.
On the other hand BYD is getting very good reviews.
https://insideevs.com/reviews/769113/byd-seagull-good-video-drive/
An $8000 EV?, Tesla is going to get totally destroyed. I think most people are tired of Tesla's bs.
