I'm so sorry, I took the only No that you included in your subsequent posts as a refusal to answer the question, you stating (erroneously) that I'd misquoted you. I only seemingly misunderstood, though the following observation seems to indicate you are being a little disingenuous...
...As you seemed to be questioning Paul Cotter when he stated the exact same thing, you saying ...
where is the error in that?
As I said, I do have problems with the nuances in the English languages, and I find American English different again...
Whether or not it is doable, I don't know. But it won't be as easy. So, why bother? Isn't that the point of your collective criticisms?
No it's not and let me explain why.
There have been threads, here and on other forums where people have presented ideas that have seemed to most on the surface as completely ridiculous and I've considered them and found they have merit, and defended them.
For example:
"Downwind faster than the wind" here, (possibly of no more than a curiosity). Then on another forum a method of using the power of electric motors on soak test to generate an offset to the cost of performing those tests, (my company took that one up from the 'inventor' he now has a comfortable lifestyle, and several motor manufacturers have benefited with operational savings).
However Chet, you keep bashing your head against the brick wall of criticism because of your following crackpot science, and unwillingness to explain things in simple terms, instead of your AI flowery wall of text method.
Personally I can't decide if you're a troll or just genuinely trying to find something special to leave behind for a legacy. I admit I've prodded you from all directions for a reaction. And I'm very good at gauging people as a rule. With you, I just can't tell!
I haven't seen anything yet of value, but you never know...
Here's a tip though: as much as I detest the legend of Tesla, in his early years he did do some original work, the hairpin circuit you've often mentioned recently, is a valid technology, though trying to get it, or any incarnation to work at low frequencies
for your prospective purpose, as you describe it is doomed to fail as its a resonant system, and works at a very high frequencies or very long tuned lines.
My heart felt advice is to stop chasing overunity, you are obviously not a trained engineer or academic, (and dont say that thing about dogma will you?), there's still lots of opportunities in energy harvesting for instance, which is a real thing you could succeed at, but of course it's your life...
Regards,
X
