Author Topic: What does a crappy digital audio cable actually sound like?  (Read 3613 times)
Offline Homer J SimpsonTopic starter
« on: August 16, 2019, 12:47:07 am »
Offline maginnovision
Re: What does a crappy digital audio cable actually sound like?
« Reply #1 on: August 16, 2019, 01:05:49 am »
Why would you save so much crappy cable? Geez...
Offline Richard Crowley
  • KJ7YLK
« Reply #2 on: August 16, 2019, 01:32:50 am »
Since it took 3x more cable than the "limit" to start demonstrating muting from signal distortion, perhaps you need to define what YOU mean by "crappy".
You don't happen to sell botique, snake-oil cable, do you?   :-DD
Offline ArthurDent
« Reply #3 on: August 16, 2019, 03:20:10 am »
If, like in the video, you're still using a 20 year old computer, audio cable probably isn't your only problem.  8)
Offline MrMobodies
« Reply #4 on: August 16, 2019, 03:38:51 am »
I remember those cables more than 20 years ago and I didn't have to roll them up wrong for them to break.
They were in most shops and didn't seem to last long.
I didn't see much choice in those days and I didn't know any better.
I like that IBM keyboard with the touch pointer never seen one of those before other than on laptops.
« Last Edit: August 16, 2019, 03:43:43 am by MrMobodies »
« Reply #5 on: August 16, 2019, 08:57:03 pm »
Tons of (un)shielded single conductor cable... How many places are you going to use that with those connectors?
Offline Cyberdragon
« Reply #6 on: August 16, 2019, 09:43:06 pm »
Exactly what he said they were for...direct amp to speaker connections. :palm:
EDIT: Also, again, it clearly doesn't bother digital audio, even with a crappy old ADC soundcard.
« Last Edit: August 16, 2019, 09:44:39 pm by Cyberdragon »
*BZZZZZZAAAAAP*
Voltamort strikes again!
« Reply #7 on: August 16, 2019, 11:40:04 pm »
Ok, just for you two... It was a joke. You don't like it, that's fine.
Offline fzabkar
« Reply #8 on: October 26, 2019, 07:34:08 am »
I'd like someone to try substituting a digital audio cable with a wet string.
Offline SL4P
  • There's more value if you figure it out yourself!
« Reply #9 on: October 27, 2019, 02:03:23 am »
Poor quality cable in digital installations will cause the bits to be ‘bent’, digital/binary doesn’t accommodate bent bits.
You probably need a pin ‘straightener’...
Don't ask a question if you aren't willing to listen to the answer.
