Author Topic: Fusion360 PCB copper text clearances  (Read 2721 times)
Offline SentinelBTopic starter
« on: March 20, 2025, 11:41:58 am »
Hey,
I'm getting tired of banging my head against the wall and the Fusion forums seem to be as lost as i am.
I'm trying to create a copper layer makers mark that i can simply add as a component to any pcb. The problem i'm having is that 'font: custom' seems so have it's own clearance rules when placed on a copper layer that ignores all other design rules.
Meaning, my polygon pour tries to avoid the text like it the plague and it seems like i can't do anything about it. I have the text inside a 'restrict top' frame and it's working correctly, as the pour has made it to one part of the makers mark outline.
I'm probably gonna make a simpler one using vector text but i kinda want to get this to work if at all possible.
Any good ideas or insights?
Re: Fusion360 PCB copper text clearances
« Reply #1 on: March 21, 2025, 07:15:10 am »
Right so i actually got a reply from the Fusion forums and it seems that i'm just SOL for the time being.
They mentioned that they should be releasing a SVG import feature soon™.
Guess i'll just use vector text and lines for now.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #2 on: March 21, 2025, 07:34:39 am »
You can already import bitmaps using an ULP. The image will then be build up by lines.
That should work, even as component.
The following users thanked this post: SentinelB
« Reply #3 on: March 21, 2025, 07:41:03 am »
Thanks for the tip.
I'll have a look and see what i can come up with.
Offline jgarc063
« Reply #4 on: April 02, 2025, 08:39:24 pm »
Just want to announce that SVG import has been released along with other improvements. See the announcement for March 2025
https://forums.autodesk.com/t5/fusion-electronics/what-s-new-in-fusion-electronics-march-2025/td-p/13405218
The following users thanked this post: Jeroen3
