Author Topic: Micro Cap Help needed  (Read 10591 times)
Offline paffiiTopic starter
« on: February 12, 2024, 07:03:31 pm »
Hello,
this post can be closed. I did mistakes in shorting some wires in components, error found :-)
Hello,
i am a beginner in spice and only a little hobbyist in electronic. I want to simulate a schematic from a book. In real it works fine but in Micro cap the output is not real.
It is a booster from 12 to 200V and maybe here is someone who is working with Micro cap to view my schematic? This would be nice..in the attachement my files
Greets
Andreas
« Last Edit: February 14, 2024, 02:33:37 pm by paffii »
Re: Micro Cap Help needed
« Reply #1 on: February 12, 2024, 08:02:05 pm »
sorry, i forgot the schematic..
Online thm_w
  • Non-expert
« Reply #2 on: February 12, 2024, 10:07:28 pm »
Its working as you uploaded, just the voltage is not that high? Is that what you are worried about?
Where did the schematic come from, any reason you didn't use this configuration: https://theorycircuit.com/boost-converter-circuit-555/
« Reply #3 on: February 12, 2024, 10:21:10 pm »
oh, i made a big fault, sorry. I saw that the Diode D1 is wrong (shortened). I have to change this error at once..
« Reply #4 on: February 12, 2024, 11:12:21 pm »
i removed the error, but still there is no output voltage..
Offline kashinath
  • Country: in
« Reply #5 on: March 06, 2024, 07:51:47 am »
You have Drain and Source of mosfet shorted. Check the corrected circuit. How do you know that the output will be 200 V ? it is approx 110V.
« Reply #6 on: March 06, 2024, 09:35:46 am »
oh, thank you very much :-) The error was in the schematic "under" the mosfet. I saw it now as i magnified.
Now the output voltage is super, about 170Volt
