Author Topic: Android VPN sharing, Wlan relay questions...  (Read 2496 times)
Offline hap2001Topic starter
« on: October 09, 2023, 04:07:24 pm »
Hi friends, I want to share my VPN on Android phone to other devices. Now I'm using a proxy APP, it works but I'm not satisfied.
1. I want the clients to use the VPN without setting proxy. In other words, the shared hotspot should be a "full" VPN envirenment. Seems that need a rooted device, correct?
2. Is it possible to share the VPN without using mobile data? I want the phone to be a normal client of a existing Wlan router, while broadcast a hotspot with VPN, is that possible?
Thank you everyone.
Offline abeyer
Re: Android VPN sharing, Wlan relay questions...
« Reply #1 on: October 09, 2023, 06:38:11 pm »
Given that you don't want to use the phone functionality, wouldn't this make more sense to not run on a phone and use proper router on your network, rather than try to root android to force it to do what you want?
« Reply #2 on: October 10, 2023, 11:26:49 am »
Because the VPN is an APP and only works well on Android.
It does have instructions for running on modded router firmwares, but works poorly.
It doesn't have to be a phone, an Android tablet would be good either.
