My newly purchased ASUS Crosshair X870E Hero Motherboard only has 2 Audio HD Jacks on the Rear Panel. To use 5.1 or 7.1 Surround Sound, the AAFP (Analog Audio Front Panel) must be utilized for the additional Jacks. My Case has only a single Jack, and the manufacturer does not offer a replacement with 2 Jacks. Due to the curvature of the case, a typical AAFP module will not fit. My current plan is to purchase a 2-Jack module and mount it within the case internal cage, snip the appropriate wires from the current module to the MB Header, and splice in the new Jacks. This will allow the existing Power, Reset, etc. buttons on the front of the case to remain functional.
The onboard MB Audio has specs that meet or exceed the best SoundCards available, so I don't want to purchase one. ASUS brags of Audio Noise Reduction primarily due to the "Gold-Plated Jacks" and "Shielded Wires" on this MB. If I were to use the standard AAFP module, then half of my 8 channels (for 7.1 SS) would lose this important noise reduction.
I'd like to purchase 2 gold-plated HD audio jacks, and Shielded Wires. These items would replace what comes with the AAFP. Can anyone tell me what I need to know regarding the gauge and type of shielded wire I should use? Also, a recommended source for these items.
Thanks for any comments...
Tom
