Nome | address | size | File Off
.text | 0x00000000 | 0x0028C588 | 0x00000168
.rdata | 0x0028C588 | 0x00027270 | 0x0028C6F0
.data | 0x002B37F8 | 0x0002C780 | 0x002B3960
.sdata | 0x002DFF78 | 0x00000000 | 0x00000000 <--- empty
.lit8 | 0x002DFF78 | 0x00000000 | 0x00000000 <--- empty
.sbss | 0x002DFF78 | 0x00000000 | 0x00000000 <--- empty
.bss | 0x002DFF78 | 0x0002F598 | n.a.
Entry Point: 0x00023428
00000000 60 01 00 07 00 00 00 00 00 47 9F 94 00 00 01 13 00 38 00 06 01 0B 00 D6 00 28 C5 88 00 05 39 F0 `........G.......8.......(....9.
00000020 00 02 F5 98 00 02 34 28 00 00 00 00 00 28 C5 88 00 2D FF 78 00 01 AC AA 00 00 00 00 00 00 09 92 ......4(.....(...-.x............
00000040 00 00 2D 31 00 00 00 00 00 00 00 00 2E 74 65 78 74 00 00 00 00 00 00 00 00 00 00 00 00 28 C5 88 ..-1.........text............(..
00000060 00 00 01 68 00 30 F6 78 00 47 9F 94 AC AA 00 00 00 00 00 20 2E 72 64 61 74 61 00 00 00 28 C5 88 ...h.0.x.G......... .rdata...(..
00000080 00 28 C5 88 00 02 72 70 00 28 C6 F0 00 45 0E 70 00 00 00 00 09 92 00 00 00 00 01 00 2E 64 61 74 .(....rp.(...E.p.............dat
000000A0 61 00 00 00 00 2B 37 F8 00 2B 37 F8 00 02 C7 80 00 2B 39 60 00 45 81 48 00 00 00 00 2D 31 00 00 a....+7..+7......+9`.E.H....-1..
000000C0 00 00 00 40 2E 73 64 61 74 61 00 00 00 2D FF 78 00 2D FF 78 00 00 00 00 00 00 00 00 00 00 00 00 [email protected]............
000000E0 00 00 00 00 00 00 00 00 00 00 02 00 2E 6C 69 74 38 00 00 00 00 2D FF 78 00 2D FF 78 00 00 00 00 .............lit8....-.x.-.x....
00000100 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 00 00 00 2E 73 62 73 73 00 00 00 00 2D FF 78 .....................sbss....-.x
00000120 00 2D FF 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 2E 62 73 73 .-.x.........................bss
00000140 00 00 00 00 00 2D FF 78 00 2D FF 78 00 02 F5 98 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 .....-.x.-.x....................
00000160 00 00 00 80 00 00 00 00 27 BD FF E0 AF BF 00 18 AF B1 00 14 AF B0 00 10 00 80 88 21 8E 25 00 28 ........'..................!.%.(
00000180 00 00 00 00 10 A0 00 16 00 00 00 00 8E 22 00 3C 00 00 00 00 8C 42 04 28 00 00 00 00 14 A2 00 07 .............".<.....B.(........
000001A0 00 00 00 00 3C 04 00 00 8C 84 00 60 0C 00 00 00 00 00 00 00 08 00 00 1E 00 00 00 00 3C 10 00 00 ....<......`................<...
000001C0 26 10 00 60 8E 04 00 00 0C 09 6D 56 00 00 00 00 8E 04 00 00 8E 25 00 28 0C 00 00 00 00 00 00 00 &..`......mV.........%.(........
000001E0 8E 22 00 3C 00 00 00 00 8C 45 04 28 00 00 00 00 10 A0 00 09 00 00 00 00 8E 22 00 28 00 00 00 00 .".<.....E.(.............".(....
00000200 10 45 00 05 00 00 00 00 3C 04 00 00 8C 84 00 60 0C 00 00 00 00 00 00 00 8E 23 00 3C 8E 22 00 28 .E......<......`.........#.<.".(
(hexedit ... )0002347c 8c 44 00 cc: lw a0, 0xcc(v0)
00023480 3c 05 00 00: lui a1, 0x0
00023484 24 a5 13 50: addiu a1, a1, 0x1350 <------- WTF??!? 0x00001350 doesn not point to .rdata!!!!
00023488 0c 00 00 00: jal FUN_00000000 <------- this "should be" a kind of "printf()" or something ...
0002348c 00 00 00 00: nop
.text{Offset inside .rdata} = 0x0028D520 - 0x0028C6F0 = 0x000E30
If .rdata were to be mapped in RAM starting at 0x00000520 (or if we account for typical 32-byte alignment/padding of literal pools), the string would land exactly at 0x00001350, matching the addiu offset perfectly.
There should be a relocation table for your .text section (referenced from s_relptr and s_nreloc fields in the section header) with entries that each contain an offset into the .text section, an offset into the symbol table, and a type that tells the loader how to combine them to do the relocation.
gnu binutils can handle them (easiest if you can get something like the debian -multiarch build, that has all targets/architectures compiled in... otherwise you may have to mess around with building against one architecture on another, which I recall being painful last time I had to do it.) If you ask for both relocation and disassembly from objdump, it will annotate the relocations inline with the instructions. You'll likely see a REFHI and REFLO relocation on the lui and addiu instructions in your example.
The easiest fix is likely to do a loader script that walks that table and patches the bytes in .text as it's loaded. If you don't care about proper support for everything, that simplifies it, as you can scan the relocation types used in your binary and just support those specific ones rather than all the possibilities. The logic for them all can be found in binutil's bfd definitions in https://git.sr.ht/~sourceware/binutils-gdb/tree/master/item/bfd/coff-mips.c
my_hack/Ghidra/tekxpress-v8.1 # mips-sony-bsd-objdump -r guineapig/dtwm
mips-sony-bsd-objdump: guineapig/dtwm: File format not recognized
Code: [Select]my_hack/Ghidra/tekxpress-v8.1 # mips-sony-bsd-objdump -r guineapig/dtwm
"eCOFF" is not the same as "COFF"![]()
That quote looks like you're using a build that's expecting a bsd ecoff
00000000 60 01 00 07 00 00 00 00 00 08 46 d0 00 00 00 b4 |`.........F.....|
00000010 00 38 00 06 01 0b 00 d6 00 04 be a8 00 00 c6 50 |.8.............P|
00000020 00 00 24 00 00 01 12 e0 00 00 00 00 00 04 be a8 |..$.............|
00000030 00 05 84 f8 00 00 32 a3 00 00 00 00 00 00 01 0f |......2.........|
00000040 00 00 04 02 00 00 00 00 00 00 00 00 2e 74 65 78 |.............tex|
00000050 74 00 00 00 00 00 00 00 00 00 00 00 00 04 be a8 |t...............|
00000060 00 00 01 68 00 05 aa 60 00 00 00 00 32 a3 00 00 |...h...`....2...|
00000070 00 00 00 20 2e 72 64 61 74 61 00 00 00 04 be a8 |... .rdata......|
00000080 00 04 be a8 00 00 9c 30 00 04 c0 10 00 08 0a 04 |.......0........|
00000090 00 00 00 00 01 0f 00 00 00 00 01 00 2e 64 61 74 |.............dat|
000000a0 61 00 00 00 00 05 5a d8 00 05 5a d8 00 00 2a 20 |a.....Z...Z...* |
000000b0 00 05 5c 40 00 08 16 b8 00 00 00 00 04 02 00 00 |..\@............|
000000c0 00 00 00 40 2e 73 64 61 74 61 00 00 00 05 84 f8 |[email protected]......|
000000d0 00 05 84 f8 00 00 00 00 00 00 00 00 00 00 00 00 |................|
000000e0 00 00 00 00 00 00 00 00 00 00 02 00 2e 6c 69 74 |.............lit|
000000f0 38 00 00 00 00 05 84 f8 00 05 84 f8 00 00 00 00 |8...............|
00000100 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
00000110 08 00 00 00 2e 73 62 73 73 00 00 00 00 05 84 f8 |.....sbss.......|
00000120 00 05 84 f8 00 00 00 00 00 00 00 00 00 00 00 00 |................|
00000130 00 00 00 00 00 00 00 00 00 00 04 00 2e 62 73 73 |.............bss|
00000140 00 00 00 00 00 05 84 f8 00 05 84 f8 00 00 24 00 |..............$.|
00000150 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
00000160 00 00 00 80 00 00 00 00 27 bd ff d0 af bf 00 28 |........'......(|
00000170 af b1 00 24 af b0 00 20 00 80 80 21 08 00 00 0d |...$... ...!....|
00000180 00 a0 88 21 00 05 2e 00 0c 00 00 00 00 05 2e 03 |...!............|
00000190 14 40 00 07 02 00 10 21 26 10 00 01 82 02 00 00 |.@.....!&.......|
000001a0 92 05 00 00 14 40 ff f7 02 20 20 21 00 00 10 21 |.....@... !...!|
000001b0 8f bf 00 28 8f b1 00 24 8f b0 00 20 03 e0 00 08 |...(...$... ....|
000001c0 27 bd 00 30 27 bd ff e0 af bf 00 1c af b2 00 18 |'..0'...........|
000001d0 af b1 00 14 af b0 00 10 00 80 80 21 16 00 00 0b |...........!....|
000001e0 00 a0 90 21 3c 02 00 00 8c 42 00 f8 00 00 00 00 |...!<....B......|
000001f0 14 40 00 06 00 40 80 21 24 02 00 16 3c 01 00 00 |.@...@.!$...<...|
00000200 ac 22 00 00 08 00 00 43 00 00 10 21 02 00 20 21 |.".....C...!.. !|
macmini2 devchain-baremetal-2022-2025/mybuilder-2025 # ./mybuild binutils mipsecoff
building mipsecoff-binutils-2.12 ...
binutils/2.12, checking source ... ok
binutils/2.12, checking build ... touching ... success
binutils/2.12, machine=mips-ecoff
binutils/2.12, preparing myconfigure ... success
binutils/2.12, configuring#2 ... success
binutils/2.12, building() ... success
binutils/2.12, installing ... success
binary fixing(mips) no file
mips-ecoff-binutils, checking binaries ... success
what a modern version of `file` says about it, would be interesting to see.
# file guineapig/*
guineapig/olwm.coff: data
guineapig/mwm.ecoff: MIPSEB ECOFF executable (impure) not stripped - version 2.11
Can you share the file?
macmini2 # mips-ecoff-objdump -i
BFD header file version 2.12
ecoff-bigmips
(header big endian, data big endian)
mips
ecoff-littlemips
(header little endian, data little endian)
mips
srec
(header endianness unknown, data endianness unknown)
mips
symbolsrec
mips
tekhex
mips
binary
mips
ihex
mips
ecoff-bigmips ecoff-littlemips srec symbolsrec tekhex binary
mips ecoff-bigmips ecoff-littlemips srec symbolsrec tekhex binary
ihex
mips ihex
my_hack/Ghidra # mips-ecoff-objdump -h guineapig/olwm.coff
mips-ecoff-objdump: cavia/olwm.coff: File format not recognized
my_hack/Ghidra # mips-ecoff-objdump -h guineapig/mwm.ecoff
guineapig/mwm.ecoff: file format ecoff-bigmips
Sections:
Idx Name Size VMA LMA File off Algn
0 .text 00188e20 00000000 00000000 000000f0 2**4
CONTENTS, ALLOC, LOAD, RELOC, CODE
1 .rdata 0002a850 00188e20 00188e20 00188f10 2**4
CONTENTS, ALLOC, LOAD, RELOC, READONLY, DATA
2 .data 0000f0e0 001b3670 001b3670 001b3760 2**4
CONTENTS, ALLOC, LOAD, RELOC, DATA
3 .bss 00007744 001c2750 001c2750 00000000 2**4
ALLOC
Sure, but I can only share the "demo" version.
Attached here, it's a MIPS-BE "coff" file for VxWorks v5.
) :xpwm.coff: MIPSEB-LE ECOFF executable not stripped - version -42.0
~/tmp/tekxp$ objdump -h xpwm
xpwm: file format ecoff-bigmips
Sections:
0 .text 000153f0 00000000 00000000 00000168 2**4
1 .rdata 00000cc8 000153f0 000153f0 00015558 2**4
2 .data 00000bd8 000160b8 000160b8 00016220 2**4
3 .sdata 00000000 00016c90 00016c90 00000000 2**4
ALLOC, LOAD, DATA, SMALL_DATA
4 .lit8 00000000 00016c90 00016c90 00000000 2**4
ALLOC, LOAD, READONLY, DATA, SMALL_DATA
5 .sbss 00000000 00016c90 00016c90 00000000 2**4
ALLOC, SMALL_DATA
6 .bss 000004b8 00016c90 00016c90 00000000 2**4
ALLOC
00000000 01 60 00 07 00 00 00 00 00 01 F3 14 00 00 00 A1 00 38 00 06 01 0B 00 D6 00 01 53 F0 00 00 18 A0 00 00 04 B8 00 00 03 54 .`...............8........S............T
00000028 00 00 00 00 00 01 53 F0 00 01 6C 90 00 00 09 ED 00 00 00 00 00 00 00 50 00 00 00 76 00 00 00 00 00 00 00 00 2E 74 65 78 ......S...l............P...v.........tex
00000050 74 00 00 00 00 00 00 00 00 00 00 00 00 01 53 F0 00 00 01 68 00 01 72 B0 00 00 00 00 09 ED 00 00 00 00 00 20 2E 72 64 61 t.............S....h..r............ .rda
00000078 74 61 00 00 00 01 53 F0 00 01 53 F0 00 00 0C C8 00 01 55 58 00 01 E9 CC 00 00 00 00 00 50 00 00 00 00 01 00 2E 64 61 74 ta....S...S.......UX.........P.......dat
000000A0 61 00 00 00 00 01 60 B8 00 01 60 B8 00 00 0B D8 00 01 62 20 00 01 ED 8C 00 00 00 00 00 76 00 00 00 00 00 40 2E 73 64 61 a.....`...`.......b .........v.....[member=123300].[/member]sda
(xpwm.coff.hacked is "xpwm.coff" with the first two byte swapped, swap(byte0, byte1))my_hack/Ghidra/guineapig # mips-ecoff-objdump -b ecoff-bigmips -m mips -x xpwm.coff.hacked
xpwm.coff.hacked: file format ecoff-bigmips
xpwm.coff.hacked
architecture: mips:3000, flags 0x00000133:
HAS_RELOC, EXEC_P, HAS_SYMS, HAS_LOCALS, D_PAGED
start address 0x00000354
Sections:
ALLOC, LOAD, DATA
ALLOC
ALLOC
mips-ecoff-objdump: xpwm.coff.hacked: Bad value
It might help if people understood the goal/question, too...
so far here you shared one binary and output on a few others, but they didn't all seem to be the same format
and sounded like maybe none of them were the one you actually cared about but couldn't share.
Is this still part of your trying to get a browser to run locally but write its files to a remote system without nfs?
If anything, we've discovered that newer versions of the NCD firmware do not use the same binary format used by Tektronix.
- Tektronix uses a custom VxWorks COFF format <------ my target
- NCD uses a standard eCOFF format (the header was hexdumped in the first post)
C:\>hexcalc 168+153f0
0x15558
C:\>hexcalc 168+153f0+cc8
0x16220
C:\>hexcalc 168+153f0+cc8+bd8
0x16df8So your 3 segments are already packed contiguously as they would be loaded into memory.I've worked with Qualcomm xbl's (Android) which have lots of segments.
I just "flatten" them to a single contiguous image internally padded with zeroes where necessary.
Then you can analyze the single raw image using the correct offset.
(I don't use Ghidra much.)Code: [Select]C:\>hexcalc 168+153f0So your 3 segments are already packed contiguously as they would be loaded into memory.
0x15558
0x16220
0x16df8
Take your coff and copy from 0x168 to 0x16df8 (size 0x16c90)
Then you have your memory image.
Ok, so where are the relocation entries then?
I'm wondering if any retired engineers who worked for Tektronix in the 1990s read this forum, and if so, if they can help me with the xterminals.
I also posted on the VCF forum, but couldn't find anyone![]()
and it seems like no one cares about these xterminals ...
... except for some "creepy dudes" on eBay asking 300-600-1000 euros
Sounds about right for ebay stuff that has no practical use but appeals to hobbyists/collectors with plenty of money to spend.
