# mpv sample.mpg
[ffmpeg/demuxer] mpegvideo: Estimating duration from bitrate, this may be inaccurate
(+) Video --vid=1 (mpeg1video 320x200 23.976fps)
Xlib: extension "XVideo" missing on display "192.168.1.12:0.0".
[vo/xv] Xv not supported by this X11 version/driver
[vo/x11] Warning: this legacy VO has bad performance. Consider fixing your graphics drivers, or not forcing the x11 VO.
VO: [x11] 320x200 yuv420p
[vo/x11] Shared memory not supported
[vo/x11] Reverting to normal Xlib
[vo/x11] X server image format not supported, use another VO.
Could not initialize video chain.
Video: no video
Exiting... (Errors when loading file)
# mplayer sample.mpg
MPlayer 1.4-11.2.0 (C) 2000-2019 MPlayer Team
Playing sample.mpg.
libavformat version 58.76.100 (external)
MPEG-ES file format detected.
VIDEO: MPEG1 320x200 (aspect 1) 23.976 fps 0.0 kbps ( 0.0 kbyte/s)
Xlib: extension "XFree86-VidModeExtension" missing on display "192.168.1.12:0.0".
[VO_XV] Sorry, Xv not supported by this X11 version/driver
[VO_XV] ******** Try with -vo x11 or -vo sdl *********
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
libavcodec version 58.134.100 (external)
[mpeg1video @ 0x3f2c45489ab0]Requested frame threading with a custom get_buffer2() implementation which is not marked as thread safe. This is not supported anymore, make your callback thread-safe.
Selected video codec: [ffmpeg1] vfm: ffmpeg (FFmpeg MPEG-1)
Load subtitles in ./
Audio: no sound
Starting playback...
Movie-Aspect is undefined - no prescaling applied.
VO: [x11] 320x200 => 320x200 Planar YV12
[swscaler @ 0x3f2c45d552e0]bicubic scaler, from yuv420p to abgr using C
[swscaler @ 0x3f2c45d552e0]No accelerated colorspace conversion found from yuv420p to abgr.
[swscaler @ 0x3f2c45d552e0]using unscaled yuv420p -> abgr special converter
Movie-Aspect is 1.60:1 - prescaling to correct movie aspect.
V: 8.4 201/201 3% 277% 0.0% 0 0
Exiting... (End of file)
Are you having trouble compiling or running it?
What exactly was the issue you ran into?
egl_x11 gl error: cannot create EGL window surface
vlc v3.0.12.1 doesn't show anything, it simply exits with this error../configure --disable-qt --disable-lua && make
and it just worked. X11 and fbdev support is included by default. If you don't even want X, then add `--without-x`.
They are designed for normal desktop systems
checking for egl... yes
checking for gl... yes
checking for X... libraries , headers
which is definitively wrong but somehow auto-detected even if "egl" and "gl" have been removed from the whole profile!
/usr/lib64/pkgconfig/egl.pc -> libglvnd
/usr/lib64/pkgconfig/gl.pc -> libglvnd
/usr/lib64/pkgconfig/opengl.pc -> libglvnd
/usr/lib64/libGLdispatch.so.0.0.0
/usr/lib64/libEGL.so.1.1.0
/usr/lib64/libGLX.so.0.0.0
/usr/lib64/libGL.so.1.7.0
/usr/lib64/libGLESv1_CM.so.1.2.0
/usr/lib64/libGLESv2.so.2.1.0
laying around orphaned for some reason
what does `eglinfo` say?
.Windows vlc
X11-client ==== net ===== X11-server
(mobaXterm) (embedded SBC)
/usr/lib64/libGL.so
libglvnd: the GL Vendor-Neutral Dispatch library. libglvnd is a vendor-neutral dispatch layer for arbitrating OpenGL API calls between multiple vendors. It allows multiple drivers from different vendors to coexist on the same filesystem, and determines which vendor to dispatch each API call to at runtime.
blah blah blah
NVIDIA
Code: [Select]# mpv sample.mpg
Video: no video
mpv fails. MobaXterm connected to a remote machine
int mpfmt = 0;
for (int fmt = IMGFMT_START; fmt < IMGFMT_END; fmt++) {
struct mp_imgfmt_desc desc = mp_imgfmt_get_desc(fmt);
if ((desc.flags & MP_IMGFLAG_HAS_COMPS) && desc.num_planes == 1 &&
(desc.flags & MP_IMGFLAG_COLOR_MASK) == MP_IMGFLAG_COLOR_RGB &&
(desc.flags & MP_IMGFLAG_TYPE_MASK) == MP_IMGFLAG_TYPE_UINT &&
(desc.flags & MP_IMGFLAG_NE) && !(desc.flags & MP_IMGFLAG_ALPHA) &&
desc.bpp[0] <= 8 * sizeof(unsigned long) &&
p->myximage[0]->bits_per_pixel == desc.bpp[0] &&
p->myximage[0]->byte_order == MP_SELECT_LE_BE(LSBFirst, MSBFirst))
// desc.comps[] uses little endian bit offsets, so "swap" the
// offsets here.
if (MP_SELECT_LE_BE(0, 1)) {
// Except for formats that use byte swapping; for these, the
// offsets are in native endian. There is no way to distinguish
// which one a given format is (could even be both), and using
// mp_find_other_endian() is just a guess.
if (!mp_find_other_endian(fmt)) {
for (int c = 0; c < 3; c++) {
desc.comps[c].offset =
desc.bpp[0] - desc.comps[c].size -desc.comps[c].offset;
if (p->myximage[0]->red_mask == MAKE_MASK(desc.comps[0]) &&
p->myximage[0]->green_mask == MAKE_MASK(desc.comps[1]) &&
p->myximage[0]->blue_mask == MAKE_MASK(desc.comps[2]))
mpfmt = fmt;
break;
if (!mpfmt) {
MP_ERR(vo, "X server image format not supported, use another VO.\n");
return false;
As far as I understand, Shared Memory (MIT-SHM) extensions for X11 only work if the client and server are on the same physical boxCode: [Select].Windows vlc
I am on MobaXterm from a remote of baresip
You rather mean vice versa, i.e. MobaXterm as X server on a Windows machine, and vlc as X11 client on the embedded side?
Do you mean that the display is connected to a remote machine (192.168.1.12)?
echo $DISPLAY
192.168.1.12:0.0
Maybe your X server does not support a suitable visual? Check with xdypinfo what's available
# xdpyinfo
name of display: 192.168.1.12:0.0
version number: 11.0
vendor string: Moba/X
vendor release number: 12004000
maximum request size: 16777212 bytes
motion buffer size: 256
bitmap unit, bit order, padding: 32, LSBFirst, 32
image byte order: LSBFirst
number of supported pixmap formats: 7
depth 1, bits_per_pixel 1, scanline_pad 32
depth 4, bits_per_pixel 8, scanline_pad 32
depth 8, bits_per_pixel 8, scanline_pad 32
depth 15, bits_per_pixel 16, scanline_pad 32
depth 16, bits_per_pixel 16, scanline_pad 32
depth 24, bits_per_pixel 32, scanline_pad 32
depth 32, bits_per_pixel 32, scanline_pad 32
keycode range: minimum 8, maximum 255
focus: PointerRoot
number of extensions: 20
BIG-REQUESTS
Composite
DAMAGE
DOUBLE-BUFFER
GLX
Generic Event Extension
Present
RANDR
RECORD
RENDER
SHAPE
SYNC
Windows-DRI
X-Resource
XC-MISC
XFIXES
XINERAMA
XInputExtension
XKEYBOARD
XTEST
default screen number: 0
number of screens: 1
screen #0:
dimensions: 1024x768 pixels (271x203 millimeters)
resolution: 96x96 dots per inch
depths (7): 24, 1, 4, 8, 15, 16, 32
root window id: 0xf4
depth of root window: 24 planes
number of colormaps: minimum 1, maximum 1
default colormap: 0x20
default number of colormap cells: 256
preallocated pixels: black 0, white 16777215
options: backing-store WHEN MAPPED, save-unders NO
largest cursor: 32x32
current input event mask: 0x80004
ButtonPressMask SubstructureNotifyMask
number of visuals: 72
default visual id: 0x21
visual:
visual id: 0x21
class: TrueColor
depth: 24 planes
available colormap entries: 256 per subfield
red, green, blue masks: 0xff0000, 0xff00, 0xff
significant bits in color specification: 8 bits
visual:
visual id: 0xad
class: TrueColor
depth: 24 planes
visual:
visual id: 0xae
class: TrueColor
depth: 24 planes
visual:
visual id: 0xaf
class: TrueColor
depth: 24 planes
visual:
visual id: 0xb0
class: TrueColor
depth: 24 planes
visual:
visual id: 0xb1
class: TrueColor
depth: 24 planes
visual:
visual id: 0xb2
class: TrueColor
depth: 24 planes
visual:
visual id: 0xb3
class: TrueColor
depth: 24 planes
visual:
visual id: 0xb4
class: TrueColor
depth: 24 planes
visual:
visual id: 0xb5
class: TrueColor
depth: 24 planes
visual:
visual id: 0xb6
class: TrueColor
depth: 24 planes
visual:
visual id: 0xb7
class: TrueColor
depth: 24 planes
visual:
visual id: 0xb8
class: TrueColor
depth: 24 planes
visual:
visual id: 0xb9
class: TrueColor
depth: 24 planes
visual:
visual id: 0xba
class: TrueColor
depth: 24 planes
visual:
visual id: 0xbb
class: TrueColor
depth: 24 planes
visual:
visual id: 0xbc
class: TrueColor
depth: 24 planes
visual:
visual id: 0xbd
class: TrueColor
depth: 24 planes
visual:
visual id: 0xbe
class: TrueColor
depth: 24 planes
visual:
visual id: 0xbf
class: TrueColor
depth: 24 planes
visual:
visual id: 0xc0
class: TrueColor
depth: 24 planes
visual:
visual id: 0xc1
class: TrueColor
depth: 24 planes
visual:
visual id: 0xc2
class: TrueColor
depth: 24 planes
visual:
visual id: 0xc3
class: TrueColor
depth: 24 planes
visual:
visual id: 0xc4
class: TrueColor
depth: 24 planes
visual:
visual id: 0xc5
class: TrueColor
depth: 24 planes
visual:
visual id: 0xc6
class: TrueColor
depth: 24 planes
visual:
visual id: 0xc7
class: TrueColor
depth: 24 planes
visual:
visual id: 0xc8
class: TrueColor
depth: 24 planes
visual:
visual id: 0xc9
class: TrueColor
depth: 24 planes
visual:
visual id: 0xca
class: TrueColor
depth: 24 planes
visual:
visual id: 0xcb
class: TrueColor
depth: 24 planes
visual:
visual id: 0xcc
class: DirectColor
depth: 24 planes
visual:
visual id: 0xcd
class: DirectColor
depth: 24 planes
visual:
visual id: 0xce
class: DirectColor
depth: 24 planes
visual:
visual id: 0xcf
class: DirectColor
depth: 24 planes
visual:
visual id: 0xd0
class: DirectColor
depth: 24 planes
visual:
visual id: 0xd1
class: DirectColor
depth: 24 planes
visual:
visual id: 0xd2
class: DirectColor
depth: 24 planes
visual:
visual id: 0xd3
class: DirectColor
depth: 24 planes
visual:
visual id: 0xd4
class: DirectColor
depth: 24 planes
visual:
visual id: 0xd5
class: DirectColor
depth: 24 planes
visual:
visual id: 0xd6
class: DirectColor
depth: 24 planes
visual:
visual id: 0xd7
class: DirectColor
depth: 24 planes
visual:
visual id: 0xd8
class: DirectColor
depth: 24 planes
visual:
visual id: 0xd9
class: DirectColor
depth: 24 planes
visual:
visual id: 0xda
class: DirectColor
depth: 24 planes
visual:
visual id: 0xdb
class: DirectColor
depth: 24 planes
visual:
visual id: 0xdc
class: DirectColor
depth: 24 planes
visual:
visual id: 0xdd
class: DirectColor
depth: 24 planes
visual:
visual id: 0xde
class: DirectColor
depth: 24 planes
visual:
visual id: 0xdf
class: DirectColor
depth: 24 planes
visual:
visual id: 0xe0
class: DirectColor
depth: 24 planes
visual:
visual id: 0xe1
class: DirectColor
depth: 24 planes
visual:
visual id: 0xe2
class: DirectColor
depth: 24 planes
visual:
visual id: 0xe3
class: DirectColor
depth: 24 planes
visual:
visual id: 0xe4
class: DirectColor
depth: 24 planes
visual:
visual id: 0xe5
class: DirectColor
depth: 24 planes
visual:
visual id: 0xe6
class: DirectColor
depth: 24 planes
visual:
visual id: 0xe7
class: DirectColor
depth: 24 planes
visual:
visual id: 0xe8
class: DirectColor
depth: 24 planes
visual:
visual id: 0xe9
class: DirectColor
depth: 24 planes
visual:
visual id: 0xea
class: DirectColor
depth: 24 planes
visual:
visual id: 0xeb
class: DirectColor
depth: 24 planes
visual:
visual id: 0x44
class: TrueColor
depth: 32 planes
visual:
visual id: 0xec
class: TrueColor
depth: 32 planes
visual:
visual id: 0xed
class: TrueColor
depth: 32 planes
visual:
visual id: 0xee
class: TrueColor
depth: 32 planes
visual:
visual id: 0xef
class: TrueColor
depth: 32 planes
visual:
visual id: 0xf0
class: TrueColor
depth: 32 planes
visual:
visual id: 0xf1
class: TrueColor
depth: 32 planes
visual:
visual id: 0xf2
class: TrueColor
depth: 32 planes
# xdpyinfo
focus: PointerRoot
BIG-REQUESTS
Composite
DAMAGE
DOUBLE-BUFFER
GLX
Present
RANDR
RECORD
RENDER
SHAPE
SYNC
Windows-DRI
X-Resource
XC-MISC
XFIXES
XINERAMA
XInputExtension
XKEYBOARD
XTEST
screen #0:
visual:
visual id: 0x21
class: TrueColor
depth: 24 planes
visual:
visual id: 0xad
class: TrueColor
depth: 24 planes
visual:
visual id: 0xae
class: TrueColor
depth: 24 planes
visual:
visual id: 0xaf
class: TrueColor
depth: 24 planes
visual:
visual id: 0xb0
class: TrueColor
depth: 24 planes
visual:
visual id: 0xb1
class: TrueColor
depth: 24 planes
visual:
visual id: 0xb2
class: TrueColor
depth: 24 planes
visual:
visual id: 0xb3
class: TrueColor
depth: 24 planes
visual:
visual id: 0xb4
class: TrueColor
depth: 24 planes
visual:
visual id: 0xb5
class: TrueColor
depth: 24 planes
visual:
visual id: 0xb6
class: TrueColor
depth: 24 planes
visual:
visual id: 0xb7
class: TrueColor
depth: 24 planes
visual:
visual id: 0xb8
class: TrueColor
depth: 24 planes
visual:
visual id: 0xb9
class: TrueColor
depth: 24 planes
visual:
visual id: 0xba
class: TrueColor
depth: 24 planes
visual:
visual id: 0xbb
class: TrueColor
depth: 24 planes
visual:
visual id: 0xbc
class: TrueColor
depth: 24 planes
visual:
visual id: 0xbd
class: TrueColor
depth: 24 planes
visual:
visual id: 0xbe
class: TrueColor
depth: 24 planes
visual:
visual id: 0xbf
class: TrueColor
depth: 24 planes
visual:
visual id: 0xc0
class: TrueColor
depth: 24 planes
visual:
visual id: 0xc1
class: TrueColor
depth: 24 planes
visual:
visual id: 0xc2
class: TrueColor
depth: 24 planes
visual:
visual id: 0xc3
class: TrueColor
depth: 24 planes
visual:
visual id: 0xc4
class: TrueColor
depth: 24 planes
visual:
visual id: 0xc5
class: TrueColor
depth: 24 planes
visual:
visual id: 0xc6
class: TrueColor
depth: 24 planes
visual:
visual id: 0xc7
class: TrueColor
depth: 24 planes
visual:
visual id: 0xc8
class: TrueColor
depth: 24 planes
visual:
visual id: 0xc9
class: TrueColor
depth: 24 planes
visual:
visual id: 0xca
class: TrueColor
depth: 24 planes
visual:
visual id: 0xcb
class: TrueColor
depth: 24 planes
visual:
visual id: 0xcc
class: DirectColor
depth: 24 planes
visual:
visual id: 0xcd
class: DirectColor
depth: 24 planes
visual:
visual id: 0xce
class: DirectColor
depth: 24 planes
visual:
visual id: 0xcf
class: DirectColor
depth: 24 planes
visual:
visual id: 0xd0
class: DirectColor
depth: 24 planes
visual:
visual id: 0xd1
class: DirectColor
depth: 24 planes
visual:
visual id: 0xd2
class: DirectColor
depth: 24 planes
visual:
visual id: 0xd3
class: DirectColor
depth: 24 planes
visual:
visual id: 0xd4
class: DirectColor
depth: 24 planes
visual:
visual id: 0xd5
class: DirectColor
depth: 24 planes
visual:
visual id: 0xd6
class: DirectColor
depth: 24 planes
visual:
visual id: 0xd7
class: DirectColor
depth: 24 planes
visual:
visual id: 0xd8
class: DirectColor
depth: 24 planes
visual:
visual id: 0xd9
class: DirectColor
depth: 24 planes
visual:
visual id: 0xda
class: DirectColor
depth: 24 planes
visual:
visual id: 0xdb
class: DirectColor
depth: 24 planes
visual:
visual id: 0xdc
class: DirectColor
depth: 24 planes
visual:
visual id: 0xdd
class: DirectColor
depth: 24 planes
visual:
visual id: 0xde
class: DirectColor
depth: 24 planes
visual:
visual id: 0xdf
class: DirectColor
depth: 24 planes
visual:
visual id: 0xe0
class: DirectColor
depth: 24 planes
visual:
visual id: 0xe1
class: DirectColor
depth: 24 planes
visual:
visual id: 0xe2
class: DirectColor
depth: 24 planes
visual:
visual id: 0xe3
class: DirectColor
depth: 24 planes
visual:
visual id: 0xe4
class: DirectColor
depth: 24 planes
visual:
visual id: 0xe5
class: DirectColor
depth: 24 planes
visual:
visual id: 0xe6
class: DirectColor
depth: 24 planes
visual:
visual id: 0xe7
class: DirectColor
depth: 24 planes
visual:
visual id: 0xe8
class: DirectColor
depth: 24 planes
visual:
visual id: 0xe9
class: DirectColor
depth: 24 planes
visual:
visual id: 0xea
class: DirectColor
depth: 24 planes
visual:
visual id: 0xeb
class: DirectColor
depth: 24 planes
visual:
visual id: 0x44
class: TrueColor
depth: 32 planes
visual:
visual id: 0xec
class: TrueColor
depth: 32 planes
visual:
visual id: 0xed
class: TrueColor
depth: 32 planes
visual:
visual id: 0xee
class: TrueColor
depth: 32 planes
visual:
visual id: 0xef
class: TrueColor
depth: 32 planes
visual:
visual id: 0xf0
class: TrueColor
depth: 32 planes
visual:
visual id: 0xf1
class: TrueColor
depth: 32 planes
visual:
visual id: 0xf2
class: TrueColor
depth: 32 planes
-V x11 or -V glx are IMO your only options
#vlc sample .mpg --vout x11
VLC media player 3.0.12.1 Vetinari (revision )
[80a21890] main audio output error: no suitable audio output module
[809bb4d0] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
Remote control interface initialized. Type `help' for help.
[80a1fb10] xcb_x11 vout display error: shared memory (MIT-SHM) not available
[80a379e0] blend blend error: no matching alpha blending routine (chroma: BGRA -> I420)
[80a379e0] main blend error: blending BGRA to I420 failed
[80a1fb10] xcb vout display error: X server failure
#vlc sample.mpg --vout glx
[81cea890] main audio output error: no suitable audio output module
[81c844d0] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
[81cf8640] main video output error: video output creation failed
[b6c13a40] main decoder error: failed to create video output
[mpeg2video @ 0xb6c26dc0] get_buffer() failed
[mpeg2video @ 0xb6c26dc0] thread_get_buffer() failed
[mpeg2video @ 0xb6c26dc0] get_buffer() failed (-1 (nil))
#vlc sample.mpg --vout opengl -vv
[815094d0] main libvlc debug: VLC media player - 3.0.12.1 Vetinari
[815094d0] main libvlc debug: Copyright © 1996-2020 the VideoLAN team
[815094d0] main libvlc debug: revision
[815094d0] main libvlc debug: configured with ./configure '--prefix=/usr' '--build=i686-pc-linux-gnu' '--host=i686-pc-linux-gnu' '--mandir=/usr/share/man' '--infodir=/usr/share/info' '--datadir=/usr/share' '--sysconfdir=/etc' '--localstatedir=/var/lib' '--disable-dependency-tracking' '--disable-silent-rules' '--docdir=/usr/share/doc/vlc-3.0.12.1' '--htmldir=/usr/share/doc/vlc-3.0.12.1/html' '--with-sysroot=/' '--libdir=/usr/lib' '--disable-aa' '--disable-optimizations' '--disable-rpath' '--disable-update-check' '--enable-fast-install' '--enable-screen' '--enable-vcd' '--enable-vlc' '--disable-a52' '--disable-alsa' '--disable-aom' '--disable-archive' '--disable-aribsub' '--disable-fribidi' '--disable-harfbuzz' '--disable-bluray' '--disable-libcddb' '--disable-chromaprint' '--disable-chromecast' '--disable-microdns' '--disable-neon' '--disable-altivec' '--disable-mmx' '--disable-sse' '--disable-dav1d' '--disable-dbus' '--disable-kwallet' '--disable-dc1394' '--disable-debug' '--disable-directx' '--disable-d3d11va' '--disable-dxva2' '--disable-dca' '--enable-dvbpsi' '--disable-dvdnav' '--disable-dvdread' '--enable-sout' '--enable-vlm' '--disable-faad' '--disable-fdkaac' '--enable-avcodec' '--enable-avformat' '--enable-postproc' '--enable-swscale' '--disable-flac' '--disable-fluidsynth' '--disable-fontconfig' '--enable-libgcrypt' '--disable-gme' '--disable-secret' '--disable-gst-decode' '--disable-dv1394' '--disable-jack' '--enable-jpeg' '--disable-kate' '--disable-libass' '--disable-caca' '--disable-notify' '--enable-samplerate' '--disable-libtar' '--disable-tiger' '--disable-linsys' '--disable-lirc' '--disable-live555' '--disable-lua' '--disable-osx-notifications' '--disable-mad' '--disable-matroska' '--disable-mod' '--enable-mpg123' '--enable-libmpeg2' '--disable-mtp' '--disable-mpc' '--enable-ncurses' '--disable-nfs' '--enable-ogg' '--disable-omxil' '--disable-omxil-vout' '--disable-optimize-memory' '--disable-opus' '--enable-png' '--disable-projectm' '--disable-pulse' '--disable-qt' '--disable-freerdp' '--enable-run-as-root' '--disable-smbclient' '--disable-sdl-image' '--disable-sftp' '--disable-shout' '--disable-sid' '--disable-skins2' '--disable-soxr' '--disable-speex' '--disable-srt' '--enable-gnutls' '--enable-svg' '--enable-svgdec' '--disable-taglib' '--disable-theora' '--disable-tremor' '--disable-twolame' '--disable-udev' '--disable-upnp' '--enable-v4l2' '--disable-libva' '--disable-vdpau' '--disable-vnc' '--enable-vorbis' '--disable-vpx' '--disable-wayland' '--with-x' '--enable-xcb' '--enable-xvideo' '--enable-x264' '--enable-x26410b' '--enable-x265' '--enable-libxml2' '--disable-avahi' '--disable-zvbi' '--enable-telx' '--with-kde-solid=/usr/share/solid/actions' '--disable-asdcp' '--disable-coverage' '--disable-cprof' '--disable-crystalhd' '--disable-decklink' '--disable-gles2' '--disable-goom' '--disable-kai' '--disable-kva' '--disable-libplacebo' '--disable-maintainer-mode' '--disable-merge-ffmpeg' '--disable-mfx' '--disable-mmal' '--disable-opencv' '--disable-opensles' '--disable-oss' '--disable-rpi-omxil' '--disable-schroedinger' '--disable-shine' '--disable-sndio' '--disable-spatialaudio' '--disable-vsxu' '--disable-wasapi' '--disable-wma-fixed' '--disable-freetype' 'build_alias=i686-pc-linux-gnu' 'host_alias=i686-pc-linux-gnu' 'CFLAGS=-O2 -march=i686 -pipe -fno-stack-check' 'LDFLAGS=-Wl,-O1 -Wl,--as-needed -L/usr/lib/sidplay/builders/' 'CPPFLAGS=' 'CXXFLAGS=-O2 -march=i686 -pipe -std=c++11' 'CCASFLAGS=' 'BUILDCC=i686-pc-linux-gnu-gcc'
[815094d0] main libvlc debug: searching plug-in modules
[815094d0] main libvlc debug: loading plugins cache file /usr/lib/vlc/plugins/plugins.dat
[815094d0] main libvlc debug: recursively browsing `/usr/lib/vlc/plugins'
[815094d0] main libvlc debug: plug-ins loaded: 386 modules
[815094d0] main libvlc debug: opening config file (/root/.config/vlc/vlcrc)
[815096f0] main logger debug: looking for logger module matching "any": 3 candidates
[815096f0] main logger debug: using logger module "console"
[815094d0] main libvlc debug: translation test: code is "C"
[8155c100] main keystore debug: looking for keystore module matching "memory": 2 candidates
[8155c100] main keystore debug: using keystore module "memory"
[815094d0] main libvlc debug: CPU has capabilities MMX MMXEXT SSE SSE2 SSE3 SSSE3 SSE4.1 FPU
[815533a0] main input debug: Creating an input for 'Media Library'
[815533a0] main input debug: Input is a meta file: disabling unneeded options
[815533a0] main input debug: using timeshift granularity of 50 MiB
[815533a0] main input debug: using default timeshift path
[815533a0] main input debug: `file/directory:///root/.local/share/vlc/ml.xspf' gives access `file' demux `directory' path `/root/.local/share/vlc/ml.xspf'
[8155c020] main input source debug: creating demux: access='file' demux='directory' location='/root/.local/share/vlc/ml.xspf' file='/root/.local/share/vlc/ml.xspf'
[81556c60] main demux debug: looking for access_demux module matching "file": 9 candidates
[81556c60] main demux debug: no access_demux modules matched
[81556d80] main stream debug: creating access: file:///root/.local/share/vlc/ml.xspf
[81556d80] main stream debug: (path: /root/.local/share/vlc/ml.xspf)
[81556d80] main stream debug: looking for access module matching "file": 22 candidates
[81556d80] main stream debug: using access module "filesystem"
[81557780] main stream debug: looking for stream_filter module matching "prefetch,cache_read": 25 candidates
[81557780] cache_read stream debug: Using stream method for AStream*
[81557780] cache_read stream debug: starting pre-buffering
[81557780] cache_read stream debug: received first data after 0 ms
[81557780] cache_read stream debug: pre-buffering done 296 bytes in 0s - 4817 KiB/s
[81557780] main stream debug: using stream_filter module "cache_read"
[815580b0] main stream debug: looking for stream_filter module matching "any": 25 candidates
[815580b0] playlist stream debug: using XSPF playlist reader
[815580b0] main stream debug: using stream_filter module "playlist"
[815580b0] main stream debug: stream filter added to 0x81557780
[8155a720] main stream debug: looking for stream_filter module matching "any": 25 candidates
[8155a720] main stream debug: no stream_filter modules matched
[81559730] main stream_directory debug: looking for stream_directory module matching "any": 0 candidates
[81559730] main stream_directory debug: no stream_directory modules
[8155c020] main input source debug: attachment of directory-extractor failed for file:///root/.local/share/vlc/ml.xspf
[8155a720] main stream debug: looking for stream_filter module matching "record": 25 candidates
[8155a720] main stream debug: using stream_filter module "record"
[81556c60] main demux debug: looking for demux module matching "directory": 47 candidates
[81556c60] main demux debug: using demux module "directory"
[815638a0] main demux meta debug: looking for meta reader module matching "any": 0 candidates
[815638a0] main demux meta debug: no meta reader modules
[815533a0] main input debug: `file/directory:///root/.local/share/vlc/ml.xspf' successfully opened
[8155c5c0] main xml reader debug: looking for xml reader module matching "any": 1 candidates
[8155c5c0] main xml reader debug: using xml reader module "xml"
[815533a0] main input debug: EOF reached
[81556c60] main demux debug: removing module "directory"
[8155a720] main stream debug: removing module "record"
[815580b0] main stream debug: removing module "playlist"
[81557780] main stream debug: removing module "cache_read"
[81556d80] main stream debug: removing module "filesystem"
[81561a50] main playlist debug: creating audio output
[8156f920] main audio output debug: looking for audio output module matching "any": 3 candidates
[8156f920] main audio output debug: no audio output modules matched
[8156f920] main audio output error: no suitable audio output module
[b6d00690] main input debug: Creating an input for preparsing 'sample.mpg'
[815638a0] main interface debug: looking for interface module matching "hotkeys,none": 10 candidates
[815638a0] main interface debug: using interface module "hotkeys"
[815536b0] main interface debug: looking for interface module matching "globalhotkeys,none": 10 candidates
[815536b0] main interface debug: using interface module "xcb_hotkeys"
[815094d0] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
[81553c90] main interface debug: looking for interface module matching "any": 10 candidates
[81553c90] main interface debug: using interface module "oldrc"
[81561a50] main playlist debug: processing request item: null, node: Playlist, skip: 0
[81561a50] main playlist debug: rebuilding array of current - root Playlist
[81561a50] main playlist debug: rebuild done - 1 items, index -1
[81561a50] main playlist debug: starting playback of new item
[81561a50] main playlist debug: resyncing on sample.mpg
[81561a50] main playlist debug: sample.mpg is at 0
[81561a50] main playlist debug: creating new input thread
[b6b0f720] main input debug: Creating an input for 'sample.mpg'
[81556350] main meta fetcher debug: looking for meta fetcher module matching "any": 0 candidates
[81556350] main meta fetcher debug: no meta fetcher modules
[81556350] main art finder debug: looking for art finder module matching "any": 1 candidates
[b6b0f720] main input debug: using timeshift granularity of 50 MiB
[b6b0f720] main input debug: using default timeshift path
[81556350] main art finder debug: no art finder modules matched
[81561a50] main playlist debug: requesting art for new input thread
[b6b0f720] main input debug: `file:///mnt/disk3/video-samples/sample.mpg' gives access `file' demux `any' path `/mnt/disk3/video-samples/sample.mpg'
[b66025e0] main input source debug: creating demux: access='file' demux='any' location='/mnt/disk3/src/video-samples/sample.mpg' file='/mnt/disk3/src/video-samples/sample.mpg'
[b6602730] main demux debug: looking for access_demux module matching "file": 9 candidates
[b6602730] main demux debug: no access_demux modules matched
[b6602ad0] main stream debug: creating access: file:///mnt/disk3/src/video-samples/sample.mpg
[b6602ad0] main stream debug: (path: /mnt/disk3/src/video-samples/sample.mpg)
[b6602ad0] main stream debug: looking for access module matching "file": 22 candidates
[b6602ad0] main stream debug: using access module "filesystem"
[b6602c80] main stream debug: looking for stream_filter module matching "prefetch,cache_read": 25 candidates
[b6602c80] cache_read stream debug: Using stream method for AStream*
[b6602c80] cache_read stream debug: starting pre-buffering
[b6602c80] cache_read stream debug: received first data after 0 ms
[b6602c80] cache_read stream debug: pre-buffering done 1024 bytes in 0s - 15625 KiB/s
[b6602c80] main stream debug: using stream_filter module "cache_read"
[b6602f50] main stream debug: looking for stream_filter module matching "any": 25 candidates
[b6602f50] main stream debug: no stream_filter modules matched
[b6603770] main stream_directory debug: looking for stream_directory module matching "any": 0 candidates
[b6603770] main stream_directory debug: no stream_directory modules
[b66025e0] main input source debug: attachment of directory-extractor failed for file:///mnt/disk3/src/video-samples/sample.mpg
[b6602f50] main stream debug: looking for stream_filter module matching "record": 25 candidates
[b6602f50] main stream debug: using stream_filter module "record"
[b6602730] main demux debug: looking for demux module matching "any": 47 candidates
[b6603460] main xml reader debug: looking for xml reader module matching "any": 1 candidates
[b6603460] main xml reader debug: using xml reader module "xml"
[b6602730] webvtt demux debug: subtitle demux discarded
[b6602730] ts demux debug: TS module discarded (lost sync)
[b6604bb0] main demux packetizer debug: looking for packetizer module matching "any": 23 candidates
[b6604bb0] main demux packetizer debug: using packetizer module "mpegvideo"
[b6b0f720] main input debug: selecting program id=0
[b6602730] main demux debug: using demux module "mpgv"
[b6b0f720] main input debug: looking for a subtitle file in /mnt/disk3/video-samples/
[b6604420] main packetizer debug: looking for packetizer module matching "any": 23 candidates
[b6604420] main packetizer debug: using packetizer module "mpegvideo"
[b6603e00] main decoder debug: looking for video decoder module matching "any": 12 candidates
[b6b05590] main meta fetcher debug: looking for meta fetcher module matching "any": 0 candidates
[b6b05590] main meta fetcher debug: no meta fetcher modules
[b6b05590] main art finder debug: looking for art finder module matching "any": 1 candidates
[b6b05590] main art finder debug: no art finder modules matched
[b6603e00] avcodec decoder debug: using ffmpeg Lavc58.91.100
[b6603e00] avcodec decoder debug: CPU flags: 0x00001003
[b6603e00] avcodec decoder debug: allowing 3 thread(s) for decoding
[b6603e00] avcodec decoder debug: codec (mpeg2video) started
[b6603e00] main decoder debug: using video decoder module "avcodec"
[b6603980] main demux meta debug: looking for meta reader module matching "any": 0 candidates
[b6603980] main demux meta debug: no meta reader modules
[b6b0f720] main input debug: `file:///mnt/disk3/video-samples/sample.mpg' successfully opened
[b6604bb0] mpegvideo demux packetizer debug: size 320x200/320x208 fps=23.976
[b6b0f720] main input debug: Buffering 0%
[b6604420] mpegvideo packetizer debug: size 320x200/320x208 fps=23.976
[b6b0f720] main input debug: Buffering 4%
[b6b0f720] main input debug: Buffering 8%
[b6603e00] main decoder debug: restarting module due to input format change
[b6b0f720] main input debug: Buffering 12%
[b6603e00] main decoder debug: removing module "avcodec"
[b6b0f720] main input debug: Buffering 16%
[b6b0f720] main input debug: Buffering 20%
[b6b0f720] main input debug: Buffering 25%
[b6603e00] avcodec decoder debug: available software decoder output format 0 (yuv420p)
[b6b0f720] main input debug: Buffering 29%
[b6b0f720] main input debug: Buffering 33%
[b6b0f720] main input debug: Buffering 37%
[b6b0f720] main input debug: Buffering 41%
[b6d143b0] main spu text debug: looking for text renderer module matching "any": 2 candidates
[b6b0f720] main input debug: Buffering 45%
[b6b0f720] main input debug: Buffering 50%
[b6b0f720] main input debug: Buffering 54%
[b6b0f720] main input debug: Buffering 58%
[b6b0f720] main input debug: Buffering 62%
[b6b0f720] main input debug: Buffering 66%
[b6b0f720] main input debug: Buffering 70%
[b6b0f720] main input debug: Buffering 75%
[b6b0f720] main input debug: Buffering 79%
[b6b0f720] main input debug: Buffering 83%
[b6b0f720] main input debug: Buffering 87%
[b6d143b0] main spu text debug: using text renderer module "svg"
[b6d15150] main scale debug: looking for video converter module matching "any": 14 candidates
[b6b0f720] main input debug: Buffering 91%
[b6b0f720] main input debug: Buffering 95%
[b6b0f720] main input debug: Stream buffering done (1001 ms in 2 ms)
[b6d15150] swscale scale debug: 32x32 (32x32) chroma: YUVA -> 16x16 (16x16) chroma: RGBA with scaling using Bicubic (good quality)
[b6d15150] main scale debug: using video converter module "swscale"
[b6d39440] main scale debug: looking for video converter module matching "any": 14 candidates
[b6d39440] yuvp scale debug: YUVP to YUVA converter
[b6d39440] main scale debug: using video converter module "yuvp"
[b6d11c80] main video output debug: Deinterlacing available
[b6d11c80] main video output debug: deinterlace -1, mode auto, is_needed 0
[b6d12070] main window debug: looking for vout window module matching "any": 2 candidates
[b6d12070] main window debug: resized to 320x200
[b6d12070] main window debug: using vout window module "xcb_window"
[b6d00a30] main inhibit debug: looking for inhibit module matching "any": 1 candidates
[b6d00a30] main inhibit debug: using inhibit module "xdg"
[b6d11c80] main video output debug: Opening vout display wrapper
[815544b0] main vout display debug: looking for vout display module matching "opengl": 9 candidates
[b6d12070] xcb_window window debug: unhandled event 19
[815544b0] main vout display debug: VoutDisplayEvent 'resize' 320x200
[b6d12070] xcb_window window debug: unhandled event 149
[81556750] main gl debug: looking for opengl module matching "any": 2 candidates
[81556750] egl_x11 gl debug: EGL version 1.4 by Mesa Project
[81556750] egl_x11 gl debug: extensions: EGL_KHR_config_attribs EGL_KHR_create_context EGL_KHR_create_context_no_error EGL_KHR_get_all_proc_addresses EGL_KHR_no_config_context EGL_KHR_reusable_sync EGL_KHR_surfaceless_context EGL_EXT_pixel_format_float EGL_MESA_configless_context
[81556750] main gl debug: using opengl module "egl_x11"
[815544b0] main vout display debug: using vout display module "gl"
[b6d11c80] main video output debug: original format sz 320x224, of (0,0), vsz 320x200, 4cc I420, sar 1:1, msk r0x0 g0x0 b0x0
[b6d143b0] main spu text debug: removing module "svg"
[b6603e00] main decoder debug: Received first picture
if (!mpfmt) {
return false;
That's precisely the error I was expecting, but I don't see it in the debug console.
