Author Topic: Siglent Technical Support join in EEVblog  (Read 529369 times)
Offline maginnovision
Re: Siglent Technical Support join in EEVblog
« Reply #1300 on: February 03, 2020, 08:13:39 pm »
It'd be nice if there were options like on the Rigol DP832  for brightness and screensaver. For now I have the display disconnected. It's powering voltage references and the logging pi. Wasting energy on the full brightness display seems pointless as it never needs to be touched. I needed my channels from the Rigol back though(it's in a better position) On the Rigol I only use the screensaver so that it turns off the display which I keep brightness down on as well.
Offline tautech
« Reply #1301 on: February 03, 2020, 08:28:28 pm »
Ok, so I guess you have a X or X-E model PSU.
Thanks, I'll send through a request that more display management options be added into one of the front panel button menus.
It seems logical it be added into the Timer button as a Display submenu and use the Left/Right buttons for navigation and the encoder for value changes.
Care to think through and offer a display management menu structure ?
« Reply #1302 on: February 03, 2020, 09:21:58 pm »
Sure, when I have some time I'll reconnect the display and see what would work best, in my opinion.
Offline Ihor
  • Country: ua
« Reply #1303 on: February 19, 2020, 11:06:19 pm »
Hello everyone!
Sorry for my poor English, I am not a native speaker, but will try to explain the problem clearly.
I have the Siglent SDS1102CML+ oscilloscope. The issue is that the oscilloscope does not boot. It is frozen after turning on and shows only "Siglent" logotype. The buttons light up, but nothing happens. The version of firmware is 6.01.01.21R2 (Release Date 09.25.19 ). Did anybody deal with this issue? Are there any ways to recovery the oscilloscope? It looks like the firmware was corrupted. I see that on main board the sd-card slot exists. Is it possible to use it to flash firmware?
Thanks!
Regards, Ihor
Offline tautech
« Reply #1304 on: February 19, 2020, 11:48:58 pm »
Hello everyone!
Thanks!
Welcome to the forum.
Press Math repeatedly and rapidly when booting.
Try multiple times if this fails at first.
The following users thanked this post: Ihor
Offline Ihor
  • Country: ua
« Reply #1305 on: February 20, 2020, 12:03:20 am »
I tried to do it multiple time, but it gives no result :( I read that this can work on Siglent SDS1102CML, but my oscilloscope is Siglent SDS1102CML+
Regards, Ihor
Offline tautech
« Reply #1306 on: February 20, 2020, 12:10:11 am »
It is the standard boot freeze recovery method for all CML, + or otherwise.
The Math button presses must be fast and many.
Please try again and report back.
If zero success I do have a CML+ USB recovery package of 12 MB but I will need your email address so please PM me with it.
Offline Ihor
  • Country: ua
« Reply #1307 on: February 20, 2020, 01:02:00 am »
tautech, I thank you a lot! The recovery pack helped me to repair oscilloscope. It works now!!) I am really glad that I found this forum!
Regards, Ihor
Offline klausES
  • restore Sony ES/Esprit era
« Reply #1308 on: February 20, 2020, 01:30:32 am »
May I ask for which Siglent device types "this type of recovery" is possible ?
SDM3055 and SDG1062X too ?
regards klaus. "Art is when you can't do it ... because if you can, it's not art"
Offline tautech
« Reply #1309 on: February 20, 2020, 01:34:28 am »
Yes.....and others.
Offline klausES
« Reply #1310 on: February 20, 2020, 01:36:42 am »
Thank you.
Good to know.  ^-^
I would be interested in how the process of this type of recovery is handled ?
Offline tautech
« Reply #1311 on: February 20, 2020, 01:51:24 am »
Thank you.
Good to know.  ^-^
Depends on the product and its firmware status/version but initial attempts are via USB files auto uploaded at boot to replace/repair the OS if the currently installed firmware supports it.
Older non updated devices (with old firmware) may require access to the internal SD card slot to use the same file fix/replace process however a different recovery package (SD or USB) is required for each process.
These recovery files are available only on request and are NOT to be shared or made available to the general public.
Offline koba30
  • Country: co
« Reply #1312 on: March 02, 2020, 11:55:56 am »
I have this unit that was returned to the factory for startup failures, now no more start issues, but the voltage measurements are wrong, shows 70% of actual voltage. DC and AC are same, I tried with different probes, I made several calibrations but it's still the same.
SDS1104x-e, upgrade to 1204 on factory when repair startup failure.
Software version 8.1.6.26. with the last firmware 6.1.33 the measurement voltage is wrong, same value 70%
FPGA version 2018-07-26
Hadware version 01-04
Thanks in advance for yours comments.
« Last Edit: March 02, 2020, 12:09:08 pm by koba30 »
Offline tautech
« Reply #1313 on: March 02, 2020, 12:28:12 pm »
Reset to factory defaults and redo measurements please. Pay attention that probe and channel attenuations match.  ;)
The following users thanked this post: koba30
Offline koba30
  • Country: co
« Reply #1314 on: March 02, 2020, 02:37:36 pm »
I reset to default, the probe and channel attenuation are same, the measurements are wrong still.
I will be attentive for any indications
Offline StillTrying
  • Country: Broken Britain
« Reply #1315 on: March 02, 2020, 05:43:05 pm »
"I will be attentive for any indications"
Well here's a couple of random ideas. :)
Edge trigger's not the best for capturing DC levels, use AUTO or AC LINE to keep the DC trace updating.
Eliminate the probes, it's safe to hold a bit of wire between the scope's 3V 1kHz and the center of the BNC, - don't force it in, to see if the 1kHz is 3Vpp.
« Last Edit: March 02, 2020, 05:45:09 pm by StillTrying »
Offline koba30
  • Country: co
« Reply #1316 on: March 02, 2020, 06:34:25 pm »
Hi, thanks for you help, with the wire the result is the same, wrong voltage measuerement, I use a fluke 192 to check the Siglent Cal signal, the measuremet is exactly 3Vpp.
Offline StillTrying
« Reply #1317 on: March 02, 2020, 06:56:16 pm »
Check the other channels, I can't think of any sensible reason why it's showing amplitudes only 68% of what they should be. :-//
Offline McBryce
« Reply #1318 on: March 02, 2020, 07:19:37 pm »
68 - 70%... Not far off RMS?
McBryce.
Offline tautech
« Reply #1319 on: March 02, 2020, 07:46:32 pm »
Yep, there's something wrong with that screenshot as the probe Cal signal is 3V p-p.
Contact your dealer and send him that screenshot and ask for another scope or this one to be repaired with possibly a new mainboard under warranty.
But first, are all other channels the same and measure low ?
Offline koba30
  • Country: co
« Reply #1320 on: March 02, 2020, 07:58:23 pm »
All channels are same. it's a strange fault
Offline tautech
« Reply #1321 on: March 03, 2020, 02:03:48 am »
Tech support have been alerted to this.
Offline tautech
« Reply #1322 on: March 03, 2020, 04:28:12 am »
Yes, we think there is a calibration problem.
When Autocal is entered there is a warning that all leads must be removed.
Can you confirm Autocal was run with all probes and leads removed ?
Offline koba30
  • Country: co
« Reply #1323 on: March 03, 2020, 04:32:54 am »
Yes all probes and leads are removed as indicate the instructions, I run the Autocal several times with the same result, wrong voltage measurments.
Offline tautech
« Reply #1324 on: March 03, 2020, 04:35:23 am »
OK, thanks. Expect a PM with contact details and more info that Siglent need.
