Author Topic: Hacking the Rigol MSO5000 series oscilloscopes  (Read 931987 times)
Offline ykurban
  • Country: tr
« Reply #1750 on: May 20, 2020, 01:23:37 pm »
the subject seems to be a little scattered.
can someone who made the last update collect all the files and the procedure under one post?
Offline ve2mrx
How to patch - again
« Reply #1751 on: May 20, 2020, 01:50:14 pm »
« Last Edit: May 20, 2020, 01:52:54 pm by ve2mrx »
The following users thanked this post: stenbror
Offline ykurban
  • Country: tr
« Reply #1752 on: May 21, 2020, 11:49:23 am »
thank you for your response ve2mrx
turns out, i was doing everything right, but there is a problem with my flash memory.
when i restart my scope with usb plugged in, patch worked fine. Before that, i was getting "no package found" error
i used 3 files for patch, and attached a screenshot of my flash memory.
Offline santacruzjohn55
« Reply #1753 on: May 21, 2020, 09:22:10 pm »
Hi running into difficulties running the patch route through ssh. This is with the no-phone-home patch. When I reboot after below, it doesn't fully boot. I also tried the 3 files on a flash drive, but it keeps saying 'No package detected'. I notice that my .GEL file is 130kb, where as the screen shot above shows 133kb. Any tricks I should be looking at?
<root@rigol>ls -l
total 22324
-rwxrwxr-x    1 root     root      22558088 May 22 03:41 appEntry
<root@rigol>md5sum /rigol/appEntry
2efa4605b83bf1af48bf6736bfae3255  /rigol/appEntry
<root@rigol>cp /tmp/appEntry /rigol/
60f1ca21475ffe9444213c2d9a571a99  /rigol/appEntry
Offline rodorr
« Reply #1754 on: May 21, 2020, 10:17:54 pm »
I just received my new MSO5074 and I updated everything and it all went very smoothly, thanks to all of the hard work others here on the forum have performed. I was just wondering if, at this point I should go ahead and run the built in calibration sequence or just leave it as is. By the way, I did not do a calibration before I did the updates. I am not noticing anything in particular being out of tolerance, just wondering what the consensus is regarding calibration. Thanks again to all of those who have helped on this forum.
Thanks,
rodorr
« Reply #1755 on: May 21, 2020, 10:37:26 pm »
Thanks,
rodorr
Run the calibration as you would normally ignoring the fact that you've upgraded. i.e. Run the calibration when you're using the scope at a significantly different temperature from when you last calibrated it (usually about 5º - see the manual for model specific details) or if it's 'too long' since you last ran it. For instance, it's about a month since I last ran a cal on mine, that's not 'too long', but the ambient temperate here now is 26.9ºC (England, at 23:30 hrs in May? You're kidding me, right?), it was probably 20ºC when I last ran it, so it's time for a cal when I next turn the scope on. You can't calibrate too often, unless it reaches OCD levels, but more than once a month or when temperature dictates is usually unnecessary.
Offline thm_w
  • Non-expert
« Reply #1756 on: May 21, 2020, 10:51:59 pm »
Thanks,
rodorr
I would run a cal when you have time, it takes quite a few minutes. Don't need to do it before the update.
Can be of some use to reduce DC offsets, eg if you notice a grounded signal is significantly off from 0V, etc.
Online Martin72
  • Testfield Technician
« Reply #1757 on: May 21, 2020, 10:57:06 pm »
Oh boys, how easy life is for a siglent owner... :-X 8)
Offline Gandalf_Sr
« Reply #1758 on: May 21, 2020, 11:02:59 pm »
OK, pray tell; how is life easy for a Siglent owner?
If at first you don't succeed, get a bigger hammer
Online Martin72
« Reply #1759 on: May 21, 2020, 11:11:54 pm »
Once hacked ( in an "easy" way), you never must fear about it when a next update appear.
Offline Gandalf_Sr
« Reply #1760 on: May 21, 2020, 11:43:00 pm »
I'm there already  ;D
« Reply #1761 on: May 21, 2020, 11:48:19 pm »
Can someone give me an md5sum of a working auto-updater .GEL file? I think my problems might be that or my USB stick.
Offline TK
« Reply #1762 on: May 21, 2020, 11:49:35 pm »
Doesn't Rigol require repatching and hacking after a firmware upgrade?
« Reply #1763 on: May 21, 2020, 11:53:40 pm »
Never mind, the 4th USB drive I tried worked.
Just had to learn how to use the 3 seashells ^H^H^H^H^H^H^H files.
Thanks to all the hard work, the auto-updater is definitely the way to go.
Offline Gandalf_Sr
« Reply #1764 on: May 21, 2020, 11:54:22 pm »
I'm not sure it does
Offline TK
« Reply #1765 on: May 22, 2020, 12:43:35 am »
As you are patching a specific executable (appEntry?), I think you do need to hack after a firmware upgrade, and of course you need someone keep the hack updated as it is specific for a firmware release
The following users thanked this post: Gandalf_Sr
Online tv84
  • Country: pt
« Reply #1766 on: May 22, 2020, 08:07:12 am »
The "easy" way is also available in Rigol, from the start, but patching became mainstream...
The following users thanked this post: KeBeNe, Martin72, Sighound36
Offline ebclr
« Reply #1767 on: May 22, 2020, 09:33:47 am »
What is the actual latest firmware hacked, Are this  available as unique gel file  , to be loaded on USB sticker, this path thing is confusing
Offline ykurban
  • Country: tr
« Reply #1768 on: May 22, 2020, 04:47:51 pm »
i uploaded a video of bode plot function
The following users thanked this post: thm_w, Fungus, MegaVolt, NED88, whatisthis, eklein
Online Martin72
« Reply #1769 on: May 22, 2020, 10:22:24 pm »
Could it be that bode plotting is much more faster than on the siglent sds2k+ ?
edit: forget it, it was played fast forwarding...
« Last Edit: May 23, 2020, 08:58:39 pm by Martin72 »
Offline texaspyro
« Reply #1770 on: May 23, 2020, 02:28:45 am »
What was your connection configuration for this test?
Online MegaVolt
  • Country: by
« Reply #1771 on: May 23, 2020, 02:13:14 pm »
 :-DD :-DD :-DD :-DD
https://youtu.be/2dHbGTSPTGg
P.S.  How do you build youtube videos?
« Last Edit: May 23, 2020, 02:20:23 pm by MegaVolt »
« Reply #1772 on: May 23, 2020, 10:27:31 pm »
Roughly this is what worked for me,
Get a new, brand name usb stick.
Go to the Rigol site and download the latest firmware. version: 01.03.00.01
Download the .GEL flie from the zip file to your usb stick, then do a local upgrade.
once complete, clear the data off the usb stick
Go here: https://www.eevblog.com/forum/testgear/hacking-the-rigol-mso5000-series-oscilloscopes/msg3024342/#msg3024342
download the zip file in that post. unzip the contents, (2 files) to your USB stick
Go here: https://www.eevblog.com/forum/testgear/hacking-the-rigol-mso5000-series-oscilloscopes/msg3025330/#msg3025330
download the file. rename it, removing the .DOC, copy that to your usb stick.
Your usb stick's contents should look like the file listing here, https://www.eevblog.com/forum/testgear/hacking-the-rigol-mso5000-series-oscilloscopes/msg3077233/#msg3077233
So, now you have a freshly upgraded scope that has been rebooted.
Insert your usb stick.
Select local upgrade.
. The screen should turn white with black text. It should ask you to press a button on the scope to upgrade.
After this completes, i think you have to press any button twice.
If you get a 'package not found', try another usb stick.
Or verify that the files look exactly like  the pictures.
The following users thanked this post: ebclr, serg_77
Offline ve2mrx
« Reply #1773 on: May 24, 2020, 01:12:15 am »
@tv84 What is the "easy" way you mention? I have read too much in this thread to remember!
Martin
Offline ve2mrx
« Reply #1774 on: May 24, 2020, 01:25:08 am »
To everyone contributing to this thread, Thanks!
I DID read all 72 pages of it and bought the MSO5074 :-) It will stay stock, I don't need more than 70MHz for now and I have the promo bundle (the most valuable part of the hack for me). Who knows, maybe I have backups...
Again, thanks!
Martin
