Author Topic: What did you buy today? Post your latest purchase!  (Read 2819508 times)
Homer J Simpson, Gary350z and 18 Guests are viewing this topic.
Online beanflying
« Reply #12400 on: August 23, 2023, 02:29:15 am »
Ordered one of them as I have a small lot of cables to do with a new 10Gig run to the shed (buying that one already made, gel filled & shielded 6A) but then 2.5Gig so moving from 5e to 6 mainly. Locally patch cables or mid length ones are not a thing so a roll of CAT6 is coming too.
Finished up going with OM4 fiber and a pair of SFP+ modules because it was cheaper than doing it with Cat6A and modules that would use more power as well :o $90 AUD inc tax and delivery. Still conduit and some fixing costs on top of this but I would still need most of that with the wire option.
Offline armandine2
« Reply #12401 on: August 23, 2023, 01:38:54 pm »
..for upcoming work on my 19-inch 3U enclosure  :palm:
went for the Bosch version (06019C500) of the Dremel tool, today
- I have batteries and charger from other Bosch 12V tools
Funny, the things you have the hardest time parting with are the things you need the least - Bob Dylan
Offline armandine2
« Reply #12402 on: August 23, 2023, 01:48:24 pm »
.. before anyone queries 10.8V  ::)
The following users thanked this post: PA0PBZ, Mortymore
Online PA0PBZ
« Reply #12403 on: August 23, 2023, 03:41:35 pm »
Ha, just had a discussion with my son about this, my Makita says 10.8V and his Bosch says 12V, both hold clearly the same 3 Li-ion cells  :D
The following users thanked this post: armandine2
Online RAPo
« Reply #12404 on: August 24, 2023, 01:14:42 pm »
Got a new in the box Rohde & Schwarz (Hameg) HMO1024 oscilloscope.
Offline mendip_discovery
« Reply #12405 on: August 24, 2023, 03:26:28 pm »
Pi 4 with 8G RAM.
This means I can retire another Pi from its tasks and use this to take over, with the added feature of the BME280 to log conditions.
Motorcyclist, Nerd, and I work in a Calibration Lab :-)
So everyone is clear, Calibration = Taking Measurement against a known source, Verification = Checking Calibration against Specification, Adjustment = Adjusting the unit to be within specifications.
Offline gamalot
  • Correct my English
    • Youtube
« Reply #12406 on: August 24, 2023, 04:07:23 pm »
Hioki L2101 kelvin clip lead.
After several years of use, I am very happy with the L2101 test leads that came with my Hioki RM3545 resistance meter, so I bought another one as a spare.
Offline jonovid
    • JONOVID
« Reply #12407 on: August 25, 2023, 11:30:32 am »
100 meter VGA video & audio CAT5 extender
so I can have PC video & audio on my TV
I am yet to determined the isolation level between PC & TV.
as this can be a problem with more then 20 meters.
« Last Edit: August 25, 2023, 09:34:13 pm by jonovid »
Offline DiTBho
« Reply #12408 on: August 25, 2023, 12:20:56 pm »
how good is it? compared to RIGOL
The opposite of courage is not cowardice, it is conformity. Even a dead fish can go with the flow
Online RAPo
« Reply #12409 on: August 25, 2023, 01:31:01 pm »
The postman delivered it 10 minutes ago ;-).
I applied the keygen for the options.
I bought it for the following reasons:
  -form factor
  -xy +z-axis setup
  -builtin component tester
  -quick view for all measurements.
All these options are not in my RIGOL MSO5104.
Now I only need to find an HO3516 logic probe.
The following users thanked this post: DiTBho
Offline gamalot
    • Youtube
« Reply #12410 on: August 26, 2023, 07:29:58 am »
I can't believe I made such a stupid mistake, I ordered a BR-2/3A lithium battery without solder tabs to replace the dead one in my power meter.  :palm:
Offline Smokey
  • Not An Expert
« Reply #12411 on: August 26, 2023, 09:16:49 am »
... but now you "have" to buy a battery terminal spot welder :)
Online woody
« Reply #12412 on: August 26, 2023, 09:18:12 am »
Your subconscience made you do it to give you a solid reason to get one of these:
https://www.eevblog.com/forum/projects/guesses-on-what-i-am-attempting-here/
 ;D
Oops, too late, beaten by Smokey
Offline gamalot
    • Youtube
« Reply #12413 on: August 26, 2023, 09:25:24 am »
 ;D
This time I will make a battery holder, of course I also think I need a spot welder, I have bought more than a hundred electrolytic capacitors, I want to try a capacitor array instead of batteries.  :popcorn:
Offline wkb
« Reply #12414 on: August 26, 2023, 03:03:08 pm »
An adequate soldering iron like a Metcal will solder wires to that battery. Use flux and be quick. Been there, done that succesfully.
Offline wkb
« Reply #12415 on: August 26, 2023, 03:04:22 pm »
Complete R&S measuring antenna set in case. :)
Fleamarket ~ 86$
- Rod antenna missing
+ 'Tastantenne' with coding plug for ESH-3
+ ext. PSU (looks like R&S, but seems homemade)
Been to Bad Bentheim today?
So was I 😉
Offline McBryce
« Reply #12416 on: August 26, 2023, 06:14:18 pm »
I'm not sure what's worse. Ordering the wrong part or having to openly admit that you don't own a battery spot welder. I'm going to go with the spot welder admission.  :D
McBryce.
Online RAPo
« Reply #12417 on: August 27, 2023, 05:03:02 pm »
The ARRL Handbook for Radio Communications 100th Edition Six-Volume Set.
Online RAPo
« Reply #12418 on: August 27, 2023, 05:05:25 pm »
I am interested in (old) calculators. The book Empire of the Sum: The Rise and Reign of the Pocket Calculator is a great history lesson.
Offline Smokey
  • Not An Expert
« Reply #12419 on: August 28, 2023, 02:27:28 am »
https://www.amazon.com/ARRL-Handbook-Radio-Communications-100th/dp/1625951582
$62.96 is actually really reasonable for something like that.  I was expecting the cost to be way more.
Online RAPo
« Reply #12420 on: August 28, 2023, 06:27:36 am »
Yep, that's the one I bought.
Offline gamalot
    • Youtube
« Reply #12421 on: August 28, 2023, 11:02:32 am »
McBryce.
I made an adapter using the terminals I removed from the old battery and a small piece of prototype board. It looks kind of ugly, but with this I think I can use almost any type of battery, which means I can save a lot of money!
The spot welder is still on the list, plus some small size 2 and 3 pin connectors.
Offline grumpydoc
« Reply #12422 on: August 31, 2023, 09:59:48 am »
Terrible crimp job on the cable in that photo though  :)
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #12423 on: August 31, 2023, 11:05:19 am »
That's why they need to test it!  ;)
The following users thanked this post: grumpydoc
Online beanflying
« Reply #12424 on: August 31, 2023, 11:53:38 am »
Even my practice ones aren't that bad  >:D Tester is in the country so I will test it's TDR or not qualities sometime next week I guess.
The shielded CAT6 is a bit of a fiddle compared to the 5E ones I have chopped up to test the crimper but the ones I made so far have got data going in and coming out so that is a start I guess.
** shielded plugs and boots coming too for the proper leads.
