Even faster than you think
Just checked the extended system info (menu,menu,force,menu) on my recently purchased 1054Z and I get the following versions:-Software 00.04.04.00.07
Quote from: StuUK on September 23, 2016, 12:39:35 pmJust checked the extended system info (menu,menu,force,menu) on my recently purchased 1054Z and I get the following versions:-Software 00.04.04.00.07That's the previous one.
Looks like they're reading this forum...
Just checked the extended system info (menu,menu,force,menu) on my recently purchased 1054Z and I get the following versions:-Software 00.04.04.00.07Firmware 0.2.3.11So a little confused as to what the latest actually is?
Quote from: Fungus on September 23, 2016, 12:29:32 pmLooks like they're reading this forum... ... but are you?
I have a vague recollection that there is still Pluses spelling and a couple things about offset math trace, but I forget which one now, one of the filters or something about when downloaded via scpi?
Do any of these fix the lockup bug that some of us are afflicted with? For reference, there's a thread on the issue here: https://www.eevblog.com/forum/testgear/rigol-ds1054z-freeze-up-bug/
Quote from: metrologist on September 23, 2016, 05:02:40 pmI have a vague recollection that there is still Pluses spelling and a couple things about offset math trace, but I forget which one now, one of the filters or something about when downloaded via scpi?It's all a lie. There's no new version (yet!)I actually downloaded it without looking too hard at the number. When I plugged in the USB stick in it gave me the "That's the same version as before!" message. This version is the one that fixed the RMS bug.
Well, I don't really care if it's "pluses", as long as it counts them right For some reason I thought I've seen "faster FFT" in changelogs somewhere. It's strange that they made full memory FFT, but left all the protocol decoders restricted to on-screen memory. I guess this was done on purpose to make higher end models more attractive.
I read that new versions of firmware don't allow you to downgrade and make the scope less responsive, so I haven't updated for a long time. Is it still true for the latest firmware?My scope has no freeze bug or any other issues, but I want the pulse counter and faster FFT
Think I'm bang up to date now, so the latest firmware date was 23rd Aug 2016 according to the build date...
@StuUK Where did you get the files you used for the update? The files available at http://beyondmeasure.rigoltech.com/acton/fs/blocks/showLandingPage/a/1579/p/p-0019/t/page/fm/0 are older.
There is NEW Firmware available now for the MSO/DS1000Z Oscilloscopes FW Version: 00.04.04.01.01Released: 2016/09/14 o Added support for the multi-inteface of LXI o Fixed bugs with Auto-Measurement functionshttp://int.rigol.com/File/ProductSoftWare/20160914/DS1000Z(ARM)update.rarEdit: I see now (thanks to 'alsetalokin4017') that 'IAmBack' reported this firmware release in 'Reply #2878' on September 14, 2016. https://www.eevblog.com/forum/testgear/new-rigol-ds1054z-oscilloscope/msg1026216/#msg1026216 I don't know how I missed seeing this. If you go back and read the reply's after his post you will see responses to the fixes.
