Author Topic: What did you buy today? Post your latest purchase!  (Read 2818758 times)
gamalot, djadeski, PlainName, shapirus and 38 Guests are viewing this topic.
Offline caprider
« Reply #11125 on: April 17, 2022, 02:08:18 pm »
Desoldering station https://eleshop.eu/desolderingstation-zd-915.html
And a few JBC soldering tips like C245-766 and C245-908.
Offline impetus_maximus
« Reply #11126 on: April 18, 2022, 05:46:09 pm »
got a mini iSesamo 'spudger'
1465873-0
sadly it's not as pictured in the sellers page. it has the re-sellers name plastered on both sides.  :palm:
i don't want to advert for them in my future videos.
here is what i thought i was buying.
1465879-1
sharpy will be replaced with hockey stick tape when i get a fresh roll.
« Reply #11127 on: April 18, 2022, 05:51:29 pm »
Just heat it up to around 100C in boiling water, and the labels will fall off after about 10 minutes.
« Reply #11128 on: April 18, 2022, 05:54:44 pm »
along with the grips, no?
« Reply #11129 on: April 19, 2022, 04:24:51 pm »
CLIFF 'CL1857 - Quicktest QT1 with 13A fuse and without cable. For U.S.A. and Canada' showed up today.
1466482-0
the USA & Canada model doesn't come with a cable/plug. i have some 14/3 Type SJ wire, and a Leviton (made in the U.S.A.) 15A grounded plug i'm going to wire to it.
[edit]all the plastic edges are a sharp. took some time to de-bur all the edges.  :-/O
« Last Edit: April 19, 2022, 06:43:58 pm by impetus_maximus »
Online Alex Eisenhut
  • Place text here.
« Reply #11130 on: April 19, 2022, 04:37:09 pm »
A snow shovel.
Offline jonpaul
« Reply #11131 on: April 19, 2022, 04:47:00 pm »
75 mm square photmultiplier tube with dynode divider and interface circuit
$20 ebay
« Last Edit: April 19, 2022, 04:49:27 pm by jonpaul »
Jean-Paul  the Internet Dinosaur
« Reply #11132 on: April 19, 2022, 08:41:29 pm »
it was snug to get the cord in the bottom. 14 gauge is as large as the connectors would fit. Quicktest is wired up.  :-/O
*sorry bout my crappy camera
1466677-0
1466683-1
1466689-2
other than the rough/sharp edges i'm impressed with the quality. the jumpers have a smooth positive feel to them.  :-+
i also love the old school neon indicator.
Offline DiTBho
« Reply #11133 on: April 19, 2022, 11:44:09 pm »
A complete set of Stanley's rotary conical cutters
The one I am using at the moment is the 4-24mm sta66105.
It's simply magic  :D
The opposite of courage is not cowardice, it is conformity. Even a dead fish can go with the flow
Offline jonovid
    • JONOVID
« Reply #11134 on: April 20, 2022, 03:31:39 am »
would someone like to explain why one seeks to detect photons , gamma rays. with a photomultiplier tube?
how is this different from say a geiger counter.
« Reply #11135 on: April 20, 2022, 04:56:24 am »
PMT will give you a measurable large current pulse from a single photon, by amplifying the electron count inside it to give a measurable amount. Also can be really low noise as well doing this. Also linear over a massive range.
The following users thanked this post: jonovid
Offline daqq
  • Country: sk
    • My site
« Reply #11136 on: April 20, 2022, 07:49:14 am »
For radiation: with a scintillator the sensitivity is MUCH higher. Also you can analyse the output signal and get an energy spectrum, which rather than just showing you something is present will tell you what exactly is present.
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #11137 on: April 20, 2022, 12:58:22 pm »
A pair of round tip pliers from Knipex. I hope it stands up to its hype around here (my first Knipex tool).  :-+
« Reply #11138 on: April 20, 2022, 01:00:38 pm »
'Made in Germany'
nice!
Offline Peter_O
« Reply #11139 on: April 20, 2022, 01:45:41 pm »
Long time there has been no preowned HP LCR-Meter on the market, that would meet my interests.
So i decided for the 'standard'. :-)
Offline DiTBho
« Reply #11140 on: April 20, 2022, 01:57:09 pm »
WOW, I am still looking for something similar  :o :o :o
The following users thanked this post: Peter_O
« Reply #11141 on: April 20, 2022, 02:51:35 pm »
Welcome to dee-dee-Dee-E-5000 club...  :-DD
 :-DMM
« Last Edit: April 20, 2022, 02:56:34 pm by mnementh »
Offline metrologist
« Reply #11142 on: April 20, 2022, 03:59:47 pm »
My DE-5000 did not come with a plastic molded case nor with the x-ceiver. But it's a good meter.  :-+
Offline Black Phoenix
  • Country: hk
« Reply #11143 on: April 20, 2022, 05:05:27 pm »
Heck, been a while, work stuff and life overall, not forgetting the family.
Electronics related stuff bought in the last months:
  • Fluke TL224 plus Fluke TP220 directly from a Fluke Authorized Dealer in Shenzhen (checked with Fluke China offices and was confirmed) that was closing because of the CoVID limitations that turn the business into more expenses than profit - 200RMB;
  • A set of 10x 4mm banana leads from ETA, model number ETA4363B - 240RMB;
"Supposedly" rated CATIII 1000V - 25A ( :-\). Construction overall is good, silicone cable as the normal test leads, with double insulation, white on the inside and colour on the outside. Plugs are robust, nickel plated copper with good construction and size/grip. Resistance of each lead under 0.08Ohm, measured in the High Res Mode of the Fluke 87V.
Cable markings are the following:
Yes they are not Stäubli MC, Hirschmann, Schützinger, Promona Electronics or Probemaster. But they are a step above the crap I see being sold in the Huaqiangbei markets.
« Last Edit: April 29, 2022, 04:52:31 pm by Black Phoenix »
The following users thanked this post: mnementh, Mortymore, syau
Offline rdl
« Reply #11144 on: April 20, 2022, 05:18:07 pm »
Where did you get a DE-5000 with that case?
« Reply #11145 on: April 21, 2022, 02:15:46 am »
They WERE all over eBay a while back... but it appears nobody has them right now, not even AliEx.  :o
An excellent plan B is to get a plastic pistol case from your local Sporting Goods store (Academy, Bass Pro Shops, even Wally World) like this one. They sell for $8-20 depending on how deluxe you get on the thickness of the eggcrate and the outer finish.
Of course, you can also spend a lot more on a similar Pelican or clone case as well. ;)
 :-DMM
« Reply #11146 on: April 21, 2022, 02:20:20 am »
a third option. spend more and get a free firearm with the case.  :P
Offline wasyoungonce
« Reply #11147 on: April 21, 2022, 07:09:44 am »
I opened the case and measured and all the rails had no output, so I took the power module out to check and didn't see or smell anything wrong. However, just when I tried to flip it over in order to inspect the bottom side of the PCB, I was shocked badly.  :scared:........
Repaired an old Akai AA-1040 for one of my kids....was aware of the power line capacitors....so used a discharge lead I had made, assumed it would discharge the tanks caps quickly.
Big mistake....I have the resistance way to high....took minutes to drain 50V DC rail.   I found out the hard way.   I had made it to disch microwave caps.   So had to make a new disch lead.
Lesson learned.
I'd forget my Head if it wasn't screwed on!
Offline vk6zgo
« Reply #11149 on: April 21, 2022, 08:29:51 am »
So you then have another hobby to waste time & money on, & still have to buy another case for the firearm.
